CANADA Canada
Old 11-25-2013, 06:21 PM   #15
brzr
brzr's Avatar
Drives: 2013 frs
Originally Posted by Monogram View Post
Studded tires work great. Tire chains work great, and the new style cable chains are quick and easy to install. As stated earlier, carry a shovel. The snow type shovels are too flimsy, so carry a folding pack shovel or short handled steel shovel.
I've had friends use their floormats to get moving.
too bad it's illegal to use studded tires here
but the floormats idea is pretty great when you have nothing else to use
brzr is offline   Reply With Quote
Old 11-25-2013, 06:25 PM   #16
brzr
brzr's Avatar
Drives: 2013 frs
Originally Posted by Kfresh23 View Post
You should absolutely turn off the traction control when stuck. This happened to me last winter when I had parked on the street and a snow plow hade made a snow "lip" around my car. I also have winter tires on but needed to rock it back and forth (which is easy with a manual transmission) and then eventually get a push. It was also hard to "plow" through with the front end being so low as it just digs into the snow if it's piled up in front.
I also have put 4 70lb sand bags in the trunk for traction (weight), and as other's have said, kitty litter works just as well.
A little shovel might also be a good investment.
I personally think the BRZ/FRS are horrible winter cars....the traction control system is sub-par compared with other RWD vehicles I have owned, and the super light weight is just not suited to any winter conditions at all! I made my chioce and only have the one vehicle, but I will be saving up for a 4wd winter vehicle as it is just not woth the spin out/getting stuck headaches!
One question for (brzr).....why is your forum name and your license plate say brzr if you drive a Scion FRS???????
i'm loving the car in the snow, once it gets going heh
yes....the plates.......
http://www.ft86club.com/forums/showt...95#post1009295
Old 11-25-2013, 06:26 PM   #17
brzr
brzr's Avatar
Drives: 2013 frs
Originally Posted by Captain Stall View Post
Two tips on cat litter: 1) make sure you don't get the clumping kind! 2) put it in some kind of container with a cover rather than leave it in the bag, else you risk a trunk full of loose litter!
no, the litter is not the clumping.......it's one of those wheat shells, flushable types, and worked well i guess
having a trunk full of litter would suck
Old 11-25-2013, 08:33 PM   #18
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by brzr View Post
carpet strips are a great idea
i was looking at some rubber strips yesterday and didn't feel like paying $40 for just one.......but i'm sure i can find some garbage carpet strips somewhere, and use those
my tires are hankook w409 i-pike, first time using that brand
Let us know how effective they are. Hankook ice bears got good reviews.
Suberman is offline   Reply With Quote
Old 11-25-2013, 09:06 PM   #19
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
The W409 is a great deep snow tire but struggles a little in the ice, which it seems is what you were having problems with. The snow around the car will just act as a wall to get over while your tires fight to grip anything they can.
For ice, you need something like the Blizzak WS70 or Conti ExtremeWinterContact. Both have more sipes to help grip the ice.
And like others have said, flip track off or go to sport mode to gain some control over the car in these conditions.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
The Following User Says Thank You to that_guy For This Useful Post:
brzr (11-25-2013)
Old 11-25-2013, 09:24 PM   #20
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Did you shovel that snow on the front? I'm amazed you were stuck, that is nothing. I've never been stuck in the snow in my car and I drove through some heavy crap.
So what I'm thinking here is:
You definitely want to turn off Traction Control in a few inches of snow, or you'll get nowhere...as you found out.
Rayme is offline   Reply With Quote
Old 11-25-2013, 09:45 PM   #21
brzr
brzr's Avatar
Drives: 2013 frs
in snow pretty good.....but as this is my first rwd i can't figure out how they compare to my old michelin ice i had on my golf......yet
they are quiet, which is nice
my husband has some pirelli winter tires that are noisy as hell......don't like that
Old 11-25-2013, 09:46 PM   #22
brzr
brzr's Avatar
Drives: 2013 frs
oh yeah.....all the snow was shoveled away before i tried moving the car. especially around the rear wheels...
once i moved the car i could see tires were sitting on two blocks of ice
Old 11-25-2013, 11:40 PM   #23
Suberman
That's often the issue: when you park the warm tires actually create that ice. In really bad conditions those warm tires also create little cups which hold onto those tires.
You can help your grip by putting sand, salt or gravel on both sides of the rear tires and spin them a bit to get it worked under the tires.
The Following User Says Thank You to Suberman For This Useful Post:
brzr (11-26-2013)
Old 11-26-2013, 10:39 AM   #24
Kfresh23
Kfresh23's Avatar
Drives: 2013 WRB Subaru BRZ
The plate makes sense now.....apologies
I have had many different vehicles (both FWD and RWD) through many different winters and here are some of my favorite tires.
I have had 2 types of Brigestone Blizzaks (can't remember which model(s) exactly), and both were excellent. I also had a very in-expensive set of General tires as well and they were just as good, if not better than the Blizzaks!
I have also had Continental Winters and now the Michelin X-ice.....both leave me wishing I had one of the first two I mentioned. Just my opinion from my experience.
Have fun out there in the white stuff....going to be a long one.........
Kfresh23 is offline   Reply With Quote
The Following User Says Thank You to Kfresh23 For This Useful Post:
brzr (11-26-2013)
Old 11-26-2013, 10:59 AM   #25
Suberman
In my experience the Continental ExtremeWinter Contact is the best snow tire you can buy, better than any Bridgestone. Check this out:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=167
Note that the Conti outperformed the Michelin in every meaningful performance test except ice. Bear in mind that the ice test is done on a hockey rink so unless you drive a Zamboni.....
daiheadjai (11-26-2013)
Old 11-26-2013, 01:21 PM   #26
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I've got Conti ExtremeWinter Contacts now.
Not bad - I just regret going down to 16s a little bit...
daiheadjai is offline   Reply With Quote
Old 11-26-2013, 03:28 PM   #27
that_guy
Dances with Cones
that_guy's Avatar
For everyone turning tration off, I would suggest simply toggling into sport mode if this is your first RWD car. It'll save you in the event something goes array but will give you that little bit of extra human control over the car for the drive home in the afterwork mess.
How so? This is what I drive on and aside from the hideous look of 16" steel wheels, this is a much better combo than a 17" option would be. Tire flex in winter is king.
Old 11-26-2013, 08:42 PM   #28
Suberman
Going down a size helps a little on ice but hurts a lot all of the rest of the time.
Not worth doing in my opinion but it is just opinion. Depends which is your priority.
A more important choice is studless rubber or performance winters.
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 02:45 PM
WTB: DC Exhaust Tips or Other Tips Xdragonxb0i Engine, Exhaust, Bolt-Ons 2 05-10-2013 07:36 AM
Snow! Jo-P NY / NJ / CT / PA 4 03-09-2013 12:51 PM
BRZ in snow swift996 BRZ First-Gen (2012+) — General Topics 135 02-10-2013 05:44 PM
BRZ vs. Snow? serith BRZ First-Gen (2012+) — General Topics 45 08-28-2012 08:26 PM
