CANADA Canada
Old 11-22-2013, 03:07 AM   #281
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
Bit of a bump (sorry).
I too scoured the internets for tire+wheel deals, including 1010tires and tirerack. While I was searching, I found PMCtires.com, located in Sherbrooke QC.
For reference, my last two sets of winter tires (on an Acura EL) were BFG Winter Slaloms and Michelin XIce2s. I found both were great for my 45 km highway commute (each way).
I did all the tire research I could, and decided on the Yokohama IceGuard IG52c (205/55) on Subaru 16" silver steel wheels. PMC wanted $135 per tire, $45 per wheel, $13 each to mount+balance them, and a mere $15.33 to have Purolator bring 172 lbs of kit from Sherbrooke directly to my door in Moncton. Since I've been doing my own wheel changes spring and winter for years, I didn't even have to load them up and take them anywhere. Grand total: $879, but there's a $70 MIR from Yokohama in progress.
I called 12 shops trying to buy locally, but the best I could do, tires + wheels + balanced + installed, was $945 (less $40 MIR) for Goodyear Ultra Grips (UG Ice WRT were $1134 less $80 MIR) and $960 for Kumho I'Zen KW22s (less $MIR) or Cooper WeatherMaster ST2 ($30 VISA prepaid card). By contrast, the Toyota/Scion dealer wanted $1285 and said the wheels were for the Camry, so I'd need new lug nuts too!
PMCtire.com advises 3-7 business days for delivery; anything longer and they'll notify. I got a tracking number the next day when the order was processed, but after 8 business days of Purolater showing they didn't have the tires en route, and nothing from PCM, I e-mailed PMC to see what was going on. I quickly got a reply saying that stock has been limited ("they are new this year and Yokohama is making them as fast as they can") but I'd have my order on the way next day at the latest. They were on the way the next day, and arrived the day after that.
I only put them on last night so have only made one 90 km round trip on them, but I'm really happy with them. I've already admitted in other thread to driving like a granny (and a slow one of those) but I didn't feel any squirm or slipping like others have described on whatever their new winter tires were.
I actually like the silver more than black.
I skipped the TPMS sensors; ignoring the dash light won't bother me.
I considered an "inexpensive" set of alloys to keep the car looking its best, but we get an awful lot of salt and sand on the roads in the Maritimes, and I just don't know how well alloys would fare. I would like to get something to cover the hub and nuts, but I've found the plastic wheel covers are cheap and break way too easily, needing to be replaced too often. I'm open to suggestions.
Thanks for reading.
Captain Stall is offline   Reply With Quote
Old 11-22-2013, 10:44 AM   #282
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Originally Posted by Taro View Post
Looks like I might be one of the last ones to get winters installed. Appointment is in a week and a half.
I was going to wait until next week to put mine on, but I had a summer tire blow out yesterday (sidewall shredded all the way around the rim by a piece of road debris). Maybe 7 months on the tire with ~8,000km, and destroyed... So I ended up putting the winters on. I understand the need for them, but I hate them. On asphalt the car just feels floaty, and in the rain they skid on even slightly-above-average braking, and what would be normal acceleration with the summers on.
Brandon
thorlius is offline   Reply With Quote
Old 11-23-2013, 02:56 PM   #283
racoiaws
Drives: 2013 Raven FR-S
Yokohama Ice Guards 52c on stock rims. So far so good. This model are brand new this year so I will update on how well they do.
racoiaws is offline   Reply With Quote
Old 11-23-2013, 05:08 PM   #284
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
They are what I have on now. Found the first day in a light rain was very slippery, in the wet they were fine but not as good as our summer stocks are. I guess we will see how they do in the snow.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 11-23-2013, 06:25 PM   #285
Suberman
Drives: Subaru BRZ Sport Tech Satin White
New road tires take about 1,000 km to properly scrub in and deliver full grip. Before that they all feel slippery to some degree.
Suberman is offline   Reply With Quote
Old 11-24-2013, 09:57 PM   #286
FR Sports
FR Sports's Avatar
Drives: Ultramarine FRS 6MT
Tire Pressure Question
What tire pressure do you set our winter tires at? I know the manufacturer suggests 35psi but does it apply to non oem tires such as winter tires? My theory is that different tires have different compound, tread, and construction so not all of them would use the same pressure for optimal performance.
FR Sports is offline   Reply With Quote
Old 11-25-2013, 02:18 AM   #287
FLYFISHR
FLYFISHR's Avatar
I'm doing my best to make that happen.
Old 11-25-2013, 11:22 AM   #288
Suberman
I put mine on a month early, it's easier to drift the car on brand new snows. Scrubs em in nicely.
Old 11-25-2013, 11:27 AM   #289
Suberman
Same as for summer tires. If you fit XL spec then they can take a pound or two less because the sidewall is tougher. More important is to keep adding air as the temperature drops to maintain correct pressure.
Add 1 psi over spec to compensate for each 5C you expect the temperature to drop from the temperature at which you measure pressure. In a heated garage driving immediately into zero C you need to have 37 psi as measured in the garage to ensure you have 35 psi while parked at Safeway. In Canada this means your tires will be over pressure for most of the winter to ensure they are to spec early in the morning.
Remember to adjust downwards as ambient temperatures rise towards spring.
Here in Calgary this game gets monotonous quickly as we have spring regularly, tomorrow eg all my cars will have 4 psi too much in their tires by noon and back to spec by sundown.
Old 11-25-2013, 11:35 AM   #290
ZionsWrath
Thanks
ZionsWrath's Avatar
I think you are being a bit overzealous. 4 psi will not likely change much. I used to drive an ambulance and with the sirens on I always drove the speed limit, while other colleagues drove considerably faster. I have never had a patient die because I drove slower. The same will be true with your tire pressure, you aren't going to crash because you have 10% different tire pressure as long as you are not trying to be an 11/10ths rally driver.
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires Chuynh207 Wheels and Tires 3 11-06-2012 02:19 PM
snow tires debs0712 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2012 01:58 PM
what tires will you be using this winter for snow? denverizzles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 08-02-2012 12:20 AM
How effective are snow tires? theredtape Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-18-2012 08:49 PM
Snow tires? smbrm CANADA 12 05-27-2012 02:20 AM
