Old 11-08-2013, 10:57 AM   #589
brn12345
brn12345's Avatar
Did a log of my cold start this morning to get a better idea of the resonance. Noticed that the ignition timing during that time is -8 and then moves to +20 when the resonance goes away. I am now more than sure that this is related to heating the cat on cold start. Looking into the tables, I found a table that apparently is for Timing after start. The values in that table are negative and I assume they would modify global timing to be significantly retarded. You might want to reduce the negative number in those tables say from -15 to -5. I think that would solve the resonance, but would it negatively impact something else I don't know.
Originally Posted by 3essess View Post
I've been playing with those tables...I presume those temps are in Celsius?
Also the temp vs maf is in g/s?
Do you have the link in romraider you mentioned....I've been searching their forums and only find older info.
brn12345 is offline   Reply With Quote
Old 11-08-2013, 01:10 PM   #590
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
The OFT is great for this platform with the available OTS map. These cars are NA so there are much less components that can cause issues like the 335i. Common issues with fuel pump, injectors, spark plugs, and etc are not common on these FRS/BRZ.
We are sold hundreds of tablets as of today and the results are super consistent. Even though 15whp and 12wtq doesn't sound like much in the n54 world, but it sure makes a whole lot of difference on this FA20.
Any questions feel free to let us know.
Originally Posted by bryce-o View Post
nice work, shiv. the OF tablet works very nicely on my 335i. i'm considering picking up an FR-S and it's nice to see you here supporting this platform. cheers
Robert@Openflash is offline   Reply With Quote
Old 11-08-2013, 07:41 PM   #591
jaf89f
jaf89f's Avatar
Drives: Raven MT
OFT Price Difference - FRS vs 335i
Hey Shiv/Robert,
Just curious, but what is the reason behind the $100 price difference for the OFT between the FRS ($495) and the n54 333i ($395)?
Hopefully I will be picking one up next month
Thanks!
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Old 11-08-2013, 08:01 PM   #592
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by jaf89f View Post
Hey Shiv/Robert,
Thanks!
To save them the time I can let you know it's to recoup the cost of developing it for this vehicle.
sierra is offline   Reply With Quote
Old 11-08-2013, 08:45 PM   #593
no chrome
She said member
Drives: fr-s firestorm
My first experiment was raising the idle in all of those tables to 2000 for everything below 50°F. That did work, however I think your right. There is more at play in the early morning resonance. Retarded timing and possibly early exhaust valve opening would make a lot of this noise trying to warm our non-existent catalysts.
Do we need a new thread to share research on this?
no chrome is offline   Reply With Quote
Old 11-08-2013, 10:22 PM   #594
mad_sb
Drives: 2013 Asphalt FR-S
Yes, this is the cat light off strategy, retarded timing (and probably late injection) heats the cat more quickly. Messing with the target idle in this area or the after start ignition timing is likely to cause a CEL.
In the past i tried setting the after start timing to 0 rather than -10, but that resulted in large cold start idle speed target errors, a higher cold start idle speed, and a longer wait time before it exits the cold start loop. It did reduce the volume level a little bit though.
Either not all the cold start logic tables are defined yet, or the cold start logic is not exposed to table inputs.
Old 11-09-2013, 03:01 AM   #595
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Can somebody please explain to me how this product can help prevent DI seal failure? How do the seals fail exaclty with the stock rom and how does the OFT take measure to correct it?
Thanks
@shiv@vishnu @Robert@vishnu
hmong337 is offline   Reply With Quote
Old 11-09-2013, 03:56 AM   #596
PantsDants
Drives: Scion FR-S A/T, Whiteout
Thanks
Check out this post: http://www.ft86club.com/forums/showp...48&postcount=5
Particularly this line: The fix in calibration A01 is to move the upper bound remit of the transient spark table from 5200 rpm to 10000rpm (e.g. always) and the actual table itself has been populated with some meaningful spark angles so it does its job up top now its actually activated.
My understanding is that all of the shelf tunes for the OFT have this modified transient spark table.
PantsDants is offline   Reply With Quote
Old 11-10-2013, 02:24 AM   #597
WRB5titch
Drives: WRBrz
Just placed an order!
WRB5titch is offline   Reply With Quote
Old 11-18-2013, 08:29 AM   #598
no chrome
She said member
I experimented again by just setting that timing retard after start to -5 from -15.
I got a higher cold idle, CEL and P050B code. But it is still much quieter
I'll try it again with something in between
Old 11-19-2013, 02:04 PM   #599
krulux
Drives: 2013 Scion FRS
Count me in as well,
Just ordered one also!!!
krulux is offline   Reply With Quote
Old 11-25-2013, 08:20 PM   #600
FRS_Jack
Duel Canister 2X the Fun
FRS_Jack's Avatar
Drives: 2013 scion frs
Hey guys,
My car is on 1.34b and it experiencing idle dip. When I'm on the break back down to zero the car's RPM will dip for a split second to 500 causing the car to jerk a little. Is this normal? Can I fix it? Do I have to reflash and bring into toyota.
I have stock air intake and evo 3 exhaust.
-J
FRS_Jack is offline   Reply With Quote
Old 11-25-2013, 08:43 PM   #601
RC51ed
RC51ed's Avatar
Originally Posted by FRS_Jack View Post
Hey guys,
-J
Is there any codes showing up?
RC51ed is offline   Reply With Quote
Old 11-25-2013, 09:02 PM   #602
FRS_Jack
FRS_Jack's Avatar
No sir.
J
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
