Old 11-12-2013, 03:47 PM   #15
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Originally Posted by HunterGreene View Post
Hope the car is back in working order soon!
On a side note, what the hell do they make the cones out of in CA? Titanium?
Or it could be the balsa wood used for the front grille
ntron1 is offline   Reply With Quote
The Following User Says Thank You to ntron1 For This Useful Post:
mitosis (11-14-2013)
Old 11-12-2013, 04:10 PM   #16
HunterGreene
Hail Magnet
HunterGreene's Avatar
Hey, need to save weight, right?
Kidding aside, a cone puncturing the grille and still having enough force to puncture the radiator too is pretty shocking.
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
mitosis (11-14-2013), ntron1 (11-12-2013)
Old 11-12-2013, 07:11 PM   #17
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Originally Posted by mitosis View Post
Thanks, that makes me feel a lot better
How did you do that pressure test? I've used the kind before where it's like a pump that attaches in place of the radiator cap and has a pressure gauge on it so you just look to see if the pressure drops after pumping it up. It's been a long time since I used one though, so I don't know if that's still considered the right tool for the job or if there's a better way to do it now. If that is the right tool then what pressure should I pump it to and how long should I let it hold at that pressure?
I did a cylinder pressure test on the block to make sure that the head gaskets are not leaking. Unfortunately Subaru does not have a great history with head gaskets and I just had to change them in my Legacy. But the pressure test will tell you if you blew the head gasket or warped a head as it will leak.
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Old 11-13-2013, 05:32 AM   #18
insertnamehere
Drives: FT86 GTS
Given that you need to lift the engine to change the spark plugs on a BRZ/FR-S (by the manual), would it be practical to do a pressure test?
insertnamehere is offline   Reply With Quote
The Following User Says Thank You to insertnamehere For This Useful Post:
Old 11-13-2013, 07:11 AM   #19
Accurate Race Shop
Drives: Scion FR-S
Most shops will do them for cheap or free because if your head gasket is blown you are going to spend a bunch of money. I didn't pay anything for mine and it only took a couple hours. It's a way better idea to get it tested than to drive it with a leaking head gasket.
Old 11-13-2013, 07:37 AM   #20
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
250 oil temp is nothing, Im in the 280's on track with a great OUA afterwards.
However, with that being said, 240+ water temp is high; highest water temp I've ever seen was 217 I think on track in July - even under track conditions my water temp is around 207-212. Better get it checked out just to be safe.
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
Old 11-13-2013, 08:58 AM   #21
Mikem53
Drives: FR-S 6MT
hmmmm.......that's too bad .....
I figure that if, after the radiator is replaced, the system holds coolant without leaking and doesn't overheat ..... you may be good to go.
Heck, back in the day, cars overheated lots of times .... and some duct tape and water from a creek fixed them up just fine .... till ya got a new hose.....
Ah.. The good ole days... But they didn't have aluminum heads that are easy to warp when things overheat..
But in this case... Sounds like the OP will be fine.. Nothing seemed too excessive..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Old 11-13-2013, 10:41 AM   #22
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Was going to say the same thing, this is an all aluminum block, not cast iron. But like everyone else is saying the only thing you can do now is repair the damage, get the car running again and see what happens.
lickitysplit is offline   Reply With Quote
The Following User Says Thank You to lickitysplit For This Useful Post:
Old 11-13-2013, 11:32 AM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you lost all the water then that temp sensor was probably reading air temp and not water temp at that point. When I lost a radiator hose on my SpecE30 and didn't realize it till I was down on power on the straight away, I managed to damage the rings and compression in the back two cylinders. That is why I now have my oil pressure idiot light installed in my water jacket so if I lose water pressure I will know immediately and shut her down. My advice would be to do a compression and leak down test prior to pulling things apart, but if you lost all the water and ran the car for 8 minutes you have probably damaged things in the motor.
Old 11-13-2013, 11:42 AM   #24
celica73
Even if the engine is toast, this should be covered by your auto insurance. Road debris damaged the car, you drove it to a safe place and it didn't survive. This shouldn't be your bill to pay (except the deductible). Document everything.
The Following User Says Thank You to celica73 For This Useful Post:
Old 11-14-2013, 01:21 PM   #25
mitosis
mitosis's Avatar
Drives: 2013 FR-S, 2008 Fit
Originally Posted by Dezoris View Post
248F for coolant is hot enough to warp the heads/block for extended time periods. Did you boil the coolant or did it all leak out?
I think it all pretty much dumped out immediately, by the time I stopped there was maybe a half gallon left that continued to leak out onto the ground.
Actually they're made from recycled surf boards, hemp, and organic tomatoes... with an unobtanium base.
The dealer has been given the go-ahead from the insurance company to start repairs as of yesterday, so I went over there to talk to the service manager in the afternoon and he said the parts for what they could see in their preliminary inspection were already ordered and would be there today.
I pointed out the notoriety of Subaru head gaskets and asked him about doing a compression and leak-down test and he said that first they've got to get the coolant system repaired so they can drive the car and evaluate it further. He said they'd be able to check the ECU to see what kind of temperatures were present for how long and at what speed I was travelling and that they'd be able to tell if there was any heat damage from that. He also said that the ECU will throw an error code if there are compression problems so they'll know more after driving the car for a while and seeing if it has any drivability issues or error codes.
The service manager who's taking care of me is a really nice guy and he completely understands my desire to be as thorough as possible and he even said something like "yeah it's a brand-new car, so you shouldn't have to even miss a beat" and seemed to be on board with the whole concept of it being a sports car that should be able to handle being driven like a sports car and not have to worry about any future problems because of some stupid flying cone.
He said if there are any issues that crop up down the road that he'd be able to help me prove to the insurance company that the issues were caused by this incident so I would be able to re-open the claim and have the further repairs covered by this insurance claim.
With any luck everything will check out OK and I'll be getting my car back this afternoon. Then I've just gotta get it over to my body shop for a new bumper, grill, and bottom dust cover.
mitosis is offline   Reply With Quote
Old 11-18-2013, 08:12 AM   #26
Muskokan
Drives: white Sport-tech
BRZ grilles are uglier, but i hope they protect better!
Muskokan is offline   Reply With Quote
Massive Sound upgrade on GT86 labskaus Electronics | Audio | NAV | Infotainment 39 08-28-2015 06:11 PM
Hit a massive pothole, now things feel slightly 'off' StarshipPoopers Issues | Warranty | Recalls / TSB 7 09-23-2013 04:56 PM
Massive Vehicle Recall (multiple auto makers) Chewie4299 Other Vehicles & General Automotive Discussions 2 04-11-2013 06:09 PM
Pulled battery for 5 minutes, now massive gas pedal slop post_break Issues | Warranty | Recalls / TSB 9 10-11-2012 02:12 AM
Maybe the FT-86 doesnt need massive power........ TriggerTRD Scion FR-S / Toyota 86 GT86 General Forum 67 07-01-2011 12:58 AM
