Old 11-02-2013, 09:25 AM   #85
dvdmzjr
Drives: Scion FR-S
Haven't gotten them put on yet. Blizzaks and 16 inch Enkei rims. Don't care a great deal for the style, but I just hope it gets me through the season.
dvdmzjr is offline   Reply With Quote
Old 11-09-2013, 03:44 AM   #86
Dr Huston
Drives: Scion FR-S
my winter tire set up
I went with Michelin X-Ice 3 on 16" steelies. Selene is looking sexy in the setting sun.
Dr Huston is offline   Reply With Quote
Old 11-09-2013, 12:02 PM   #87
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Well, I returned the Dunlops on steelies and bought these instead...(205/55R-16 Pirelli WInter Sotto Zero II and 16x7, 45 mm offset Enkei M52)
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
The Following User Says Thank You to BRZNutt For This Useful Post:
ericmpena (11-15-2013)
Old 11-12-2013, 09:56 PM   #88
cbf
Drives: 2013 BRZ Limited, GBS
BRZNutt --
Why? I was about to get the Dunlops based on the TireRack ratings (and probably an Enkei -- but graphite color, not black). What made you decide to switch to Pirelli?
Another interesting question -- you went with 16" wheels (as TireRack recommends). I'm thinking of staying at 17" wheels -- I'm betting on only a handful of snow days in a typical Massachusetts winter (although I could well lose that bet), and figured the 17" wheel size would give me better dry road handling at the expense of some snow traction. Did you have the opposite thought?
cbf is offline   Reply With Quote
Old 11-13-2013, 05:52 AM   #89
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Originally Posted by cbf View Post
... figured the 17" wheel size would give me better dry road handling at the expense of some snow traction ...
I don't think you even lose traction in snow. I went with 16" wheels because I drive a lot on hard packed snow, and I wanted softer paws over that very rough surface. To achive that I sacrificed some stability on dry roads.
If you drive in loose snow and have traction problems under those condition, go for narrower wheels. They "plow" easier.
Old 11-13-2013, 08:06 AM   #90
BRZNutt
BRZNutt's Avatar
BRZNutt --
I don't think you can go wrong with the Dunlops. I just decided to try the Pirellis based solely on the fact that most of my "winter" driving will be on dry roads and I wanted something more tuned for that. I went with 16s for the same reasons that Sarlacc explained above. That and the fact that the 16" package was a lot cheaper. I also considered putting winter tires on my stock 17s and then getting some new 17" wheels in the spring. I decided that I really should wear the stock tires out first and I like the look of the stock wheels.
Old 11-13-2013, 08:22 AM   #91
ZionsWrath
Thanks
ZionsWrath's Avatar
Michelin Primacy HP
Review:
Old 12-17-2013, 12:33 AM   #92
Slipstream
Slipstream's Avatar
Drives: 14 WRB BRZ
Originally Posted by WRB-DZA-BRZ View Post
My winter setup:
205/60-16 Firestone Winterforce (non-studded) on WRX wheels.
This setup got me through a week of very icy weather last year that I would have had zero chance of getting through with the stock tires. I have yet to take this setup through very thick snow however, and since the tires are taller than stock, it leaves no room for cables/chains.
I picked up a set of these and test fit one on the front. The +55 offset is REEEEALLY tight (can barely get a finger between the tire and the strut); for you guys running OEM WRX wheels, any concerns or issues here? I normally prefer a bit more room to work with.
Slipstream is offline   Reply With Quote
Old 12-17-2013, 02:14 AM   #93
double0seven
Drives: FRS
Running on 16inch steelies using Goodyear ultragrip Ice WRT 205/55R16.
Wet grip isn't that great, but better than the stock michelins.
Cold and dry grip is good.
Didn't have any real snow in Vancouver yet so i'm not sure how they do in the snow.
double0seven is offline   Reply With Quote
Old 12-17-2013, 02:47 AM   #94
kALMIGHTY
Drives: TRD Ultramarine '13
Bridgestone Blizzak WS70s on stock plastidipped wheels. Got me through the immense amount of crap that did this to my car, so you can only imagine how great they are. Nothing has stopped these tires yet, and I've driven through snow deep enough to make my front bumper act as a snow plow.
Name:  Screen Shot 2013-12-15 at 8.37.22 PM.png
Old 12-18-2013, 02:17 PM   #95
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Another Calgary peep checking in - I'll probably go with blizzaks next time but these studded Hanooks are doing fine.
Khyron686 is offline   Reply With Quote
Old 12-18-2013, 04:15 PM   #96
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Any reviews on the GT Radial Champiro WinterPro HP? I've set up an appointment to get a set, but haven't heard anything about them. Apparently, they're new this year?
http://www.gtradial-us.com/en/CHAMPI...TERPRO_HP.html
JohnJuan is offline   Reply With Quote
Old 12-18-2013, 06:33 PM   #97
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Blizzaks fall short of the best, even the LM model:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=181
Bare road performance is pathetic. No real world advantage over the others in return for such poor bare road grip either.
Suberman is offline   Reply With Quote
Old 12-19-2013, 08:29 AM   #98
amram
amram's Avatar
Drives: 2013 FR-S AT
Hey brznutt, how are the sottozero working out for you?
Am considering those on 16" steelies from tirerack. Didn't see many reviews here. I like the idea of great cold dry and wet performance but am concerned about the lesser snow perf (than altimax or blizzak) for the about 2-5% ice/snow of my winter driving time that I would really need the winter tires for, given our mild winters here. (The stock bridgestones seem fine for the other 95% wet/dry time) Thanks in advance!
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Winter tire experiences? smbrm CANADA 10 11-06-2012 05:42 PM
What Winter Tire for NY Weather? ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 10-29-2012 08:02 PM
Winter tire Dub666 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 02:32 AM
Need some help picking a winter tire... jm1681 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-29-2012 02:14 PM
Contribute your review for California Scion/Subaru dealers DuMa Southern California 20 02-06-2012 12:59 PM
