Old 11-10-2013, 01:14 PM   #407
mike the snake
I have your Premium stage 1 kit going on my car in a week or so.
On your site, the only options for injectors was the 1000cc upgrade, which I got along with the GTX28 turbo.
I am NOT going with E85, and I'm wondering if the 1000cc injectors will be too big for my application?
I'm going with the Hydra standalone EMS and their Hydramist WMI system but no E85, just 91 california gas.
In asking about the larger injectors, it was mentioned that injectors that are too large will be a pain to tune.
Should I be running smaller injectors? Like 750cc or 650cc?
If I would be better off with smaller injectors, can I send the 1000cc ones I bought from you back for some more appropriately sized injectors?
Old 11-10-2013, 01:23 PM   #408
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Mike, the 1000cc will be a little too big on pump gas alone. Please give us a call and we can figure it out for you.
FullBlown is offline   Reply With Quote
Old 11-10-2013, 01:32 PM   #409
mike the snake
Thanks very much for the quick reply!!
That's why I chose your outfit for my turbo kit. You guys have the best customer service record.
I'll call you first thing Tuesday, I figure you're probably at SEMA or home on Sunday and Monday's a holiday.
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
Dipstik-sportech (11-10-2013), FullBlown (11-10-2013)
Old 11-11-2013, 11:59 AM   #410
DeOppressorLiber
DeOppressorLiber's Avatar
Drives: FRS Full Blown Custom
FullBlown Motorsports definitely has my upmost respect in customer service. LJ is great to deal with and knows his job. He has sent me roms back within minutes! The kit is great and the people are great! Running the Premium Stage 1 kit. Some advise when installing, dont break the plug on the VVT sensors, they are real close to the Manifold and I broke one and it took me over a week to figure out what the hell was wrong with the car because the plug was still hanging in place but the contacts where broken!
The Trypticon Transformation in Progress!
DeOppressorLiber is offline   Reply With Quote
The Following 2 Users Say Thank You to DeOppressorLiber For This Useful Post:
Dipstik-sportech (11-12-2013), FullBlown (11-11-2013)
Old 11-12-2013, 04:57 PM   #411
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have been helping working on removing the engine of two STIs and both times someone/something broke one of the cam timing sensors. They are definitely sensative and special care needs to be taken to not damage them.
Old 12-20-2013, 12:45 PM   #412
mike the snake
My Full Blown Premium stage 1 kit is installed, and will be tuned in the next week or so.
The premium kit has the V-band clamps. I'm wondering about the fact that there's no brackets, or anything supporting the turbo system. The entire system is held on the car by the header and header bolts.
I haven't seen the base kit which uses the T3 flanges where a bracket can be bolted to and whether it has a bracket or not.
My question is, is there anything to worry about on my premium kit as far as need a bracket, or something to help support the turbo system on the car? Should I look into making a support bracket?
The header is super heavy, and connected to it are the turbo, downtube, over/front pipe, wastegate, it all weighs a lot.
Old 12-20-2013, 12:49 PM   #413
FullBlown
FullBlown's Avatar
Drives: Scion FRS
No need for brackets if they are properly welded. The premium manifolds are all schedule 10 back purged. VCMC has been running around with our manifold for awhile. Those guys put a beating on their car, more than anyone out there.
I wouldn't stress about it much.
Old 12-20-2013, 12:51 PM   #414
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Can't wait to see what it does on meth.
Old 12-20-2013, 01:10 PM   #415
mike the snake
OK Thanks! I won't worry.
I'm assuming the Hydra and Meth are set up correctly, my tuner has tuned with it before.
We are using the window washer bottle for double-duty for both window wash and meth tank. Hydra/Aquamist has a gauge making it easy to monitor levels in the tank.
I've talked with Element, and asked the tuner to work with Element when it comes time to tune.
I've really stressed to them what I've been told- that even though they've done big HP Subarus, it won't help them in tuning this car, so I'm hoping they talk to you and others to gather as much info as possible when tuning my car.
I'm confident they'll give me a safe tune. Hoping for the HP numbers to meet what I'm hoping for. I'm in CA on 91 crap.
We ordered a 3" catless over/front pipe from Nameless, but they sent a catted one, so we're just waiting on the catless pipe to show up, otherwise the car is done.
Old 12-20-2013, 01:57 PM   #416
pmccut
Drives: Blue Subarus
So close! Can't wait to swap rides. I have a big regret not getting the GTX28 like yours, and now I want the GTX3076. Let's see how much you can make out of it.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 12-20-2013, 04:16 PM   #417
mike the snake
I can't wait to see!
Unfortunately, I fear that with the delay from the over/front pipe from Nameless, that the whole thing is going to run into the holidays with Xmas and New Years and whatever days they take off for both, so it may still be a couple weeks.
FLI has been great, and I'm sure I'll get a good safe tune, Ryan has been trying to keep me in perspective as far as to what HP numbers we're going to see. I've told him some of the numbers I've seen here, and said that I'm hoping for 330+ ideally, but 300+ WHP would be great, and I went with the WMI to help with this goal.
What I think may happen is that since they haven't tuned one of these cars yet, I'll get a good, safe, conservative tune, with a bit of room to improve with more tuning by them, or someone who's got experience with eeking the last few horsies from the FA20 engine.
I hope they take Phil from Element Tuning's offer for help with tuning with the Hydra and Hydramist as well.
Old 11-16-2014, 07:08 PM   #418
Stevehan
Drives: 2015 Subaru BRZ blue.edition
Sorry for restarting this old thread up but I was wondering if someone can tell me how well this kit runs after many miles I want this kit a lot but this is my daily driver so I'll be driving this car for at least 5 more years so my question is how well this kit will hold up after a lot of driving thanks for the help.
Stevehan is offline   Reply With Quote
Old 11-16-2014, 07:37 PM   #419
Dipstik-sportech
Dipstik-sportech's Avatar
30,000+ miles and no problems to report, even the original fans are still going.
The Following 3 Users Say Thank You to Dipstik-sportech For This Useful Post:
civicdrivr (11-16-2014), D_Thissen (11-16-2014), itsibarra (08-03-2015)
Old 11-16-2014, 11:56 PM   #420
dabocx
dabocx's Avatar
Drives: Scion FRS
Whats the current best for the gtx2867?
dabocx is offline   Reply With Quote
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 10:32 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 10:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 11:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 04:04 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
