Old 10-22-2013, 05:44 PM   #1
Whiteout_FRS
Whiteout_FRS's Avatar
Drives: 2013 Scion FRS
What Suspension Will Go The Lowest On Our Cars?
Comparing a few different suspension setups before I look to buy. If you could post pics of your lowered FR-S or BRZ, what you are sitting on, wheel size, how much you are dropped, and how much you have left to go if any...
Whiteout_FRS is offline   Reply With Quote
Old 10-22-2013, 06:11 PM   #2
Whiteout_FRS
bump
Old 10-22-2013, 06:18 PM   #3
dehydratedH2O
Drives: 2014 BRZ Limited DGM
bumped in less than 30 minutes? someone is impatient...
dehydratedH2O is offline   Reply With Quote
The Following User Says Thank You to dehydratedH2O For This Useful Post:
wparsons (10-23-2013)
Old 10-22-2013, 06:26 PM   #4
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
BC Racing BR Extreme Low Coilovers with Swift Springs. (14k/16k rates)
All the way down, removed one collar in the rear. To go lower, you could remove front collars, and/or get Stance rear LCA's. The Stance rear LCA's lower the rear 25mm's.
And here's with 18's. (18x9.5 +35, 235/35)
moomoopanda is offline   Reply With Quote
Old 10-23-2013, 01:49 AM   #5
Hmongfrs
Drives: Red
I'm on bc also but not the extreme drop....the front still have about 1/2 inch left without removing any collar and rear max out still can go lower if I loose up he preload but don't want to do that...miro 368 18x10 +25 all around tires is Nanking 225/45/18
This pic is when rear max out and camber at -6.4
This pic. The rear is not camber or max out but the front still have about 1/2 inch to go..also front camber is -4
Hmongfrs is offline   Reply With Quote
Old 10-23-2013, 07:34 PM   #6
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Yeah, you're probably going to be best served with a set of the BC Racing coilovers. They can be had with custom options like extreme drop, stiffer rates etc.
We have done custom setups on these for a couple local customers and they like them.
Circuit Motorsports is offline   Reply With Quote
Old 10-23-2013, 07:36 PM   #7
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
BC Racing Extreme drop 10k From @Circuit Motorsports
Stance LCA's in the rear
Traaaaaa
Rotiforms nue on frs by smsalsuwaidi, on Flickr
Old 10-23-2013, 07:53 PM   #8
Circuit Motorsports
@SmsAlSuwaidi - That thing be low!
Old 10-24-2013, 09:52 AM   #9
Whiteout_FRS
Looks good guys! I've been between Megan EZ Street and the BC Extreme Drops, will probably just pay the extra money for the BC's
Old 10-24-2013, 09:52 AM   #10
Whiteout_FRS
Any more pics would be appreciated
Old 10-24-2013, 10:08 AM   #11
CBR600RR
Drives: Raven Black
Air bag suspension will get you right to the floor - AKA - the lowest of them all
Old 10-24-2013, 11:00 AM   #12
Whiteout_FRS
I'm sure it would, it just wouldn't be the most practical suspension for where I live. If a bag or line were to bust I would be S.O.L. back in the country.
Old 10-24-2013, 12:24 PM   #13
Circuit Motorsports
The EZ's run a little softer and you don't have the option of swapping out the springs for a stiffer rate, which you will probably want if you are slamming the car.
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
Whiteout_FRS (10-24-2013)
Old 10-24-2013, 12:34 PM   #14
CBR600RR
Drives: Raven Black
and being 2-3 inches off the ground in BC coils won't cause you any clearance issues living in the country?
The Following User Says Thank You to CBR600RR For This Useful Post:
ATL BRZ (10-25-2013)
