Drives: 2013 FRS Asphalt
RCE Springs Koni Yellow inserts Video at work.
Here is video of some RCE springs and Koni yellow inserts at work. @Racecomp Engineering
[ame]http://youtu.be/4PToOkNim7I[/ame]
2013 Scion FR-S AT Picked up 5/30/2012
| The Following 5 Users Say Thank You to feldy For This Useful Post: | Anthonytpt (10-21-2013), Burrcold (10-20-2013), clickfiveZ (10-22-2013), fstlane (10-21-2013), Wepeel (10-22-2013) |
#3 |
Drives: Your Car
Lol @ the cone in 1:06.
| The Following User Says Thank You to Squishy86 For This Useful Post: | Anthonytpt (10-21-2013) |
#4 |
Drives: Subaru BRZ Limited
That video ruled!! Lol'd at the cone too. That exhaust hanger looks like it's made out if jelly.
#5 |
That's the Perrin Hangers and perrin catback. @PERRIN_Chris These do like to shake a lot huh
#6 |
86-er
Drives: BRZ tS
Fail on the cone lol. Great video though. What settings u on
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
#7 |
front and rear on the konis 1 full turn from full stiff. We run on concete but I have ran this on blacktop and asphalt. 28 psi front 25 psi rear 245/40/rs3s on 17x9 rpf1s. -2.5 camber up front -1.9 camber rear toe a little out in the front a little in on the rear.
#8 |
Very cool!
You can see how much the rear subframe moves around. Those tire pressures are awfully low... - Andy |
#9 |
Those tire pressures are spot on if you don't over drive the tires.
This weekend I ran the rears at 24 psi. Remember this is autocross not track days. I got 204 runs and about 4k street miles on these. on the street I run them at 33 psi all day. Right size rims helps a lot and alignment and the driver. These are 245s on 17x9 rims. So the shoulder has no pinch and a very slight stretch keeping the sidewalls more stiff. Last year when I ran 225/45/17s on my stock rims I had to run them at 35 psi. When I was driving my FWD car on RS3s I had to run them at 40psi in the front not to roll over. Andy I will be doing another video with your tarmac prototype springs in the spring.
| The Following User Says Thank You to feldy For This Useful Post: | Racecomp Engineering (10-21-2013) |
#10 | |
Whenever I dropped below 30PSI on -2.0F it went from grip to slop. (autox) I like the video a lot it shows two things, as mentioned by RCE subframe movement and sway bar load.
#11 |
The video reminded me of this one of Aussie V8 supercars. This is a front wheel obviously.
Completely not a comparable car/situation, but just fun to see. V8 Supercars run a lot of camber, very stiff suspension, and soft tire pressures (in the same range of @feldy or softer). I don't know much else about the cars. But...cool video. [ame="http://www.youtube.com/watch?v=1SFAt9cqZyU"]V8 Supercars 2009 Hidden Valley Jamie Whincup Tyre Cam - YouTube[/ame] - Andy |
#12 | |
Some of its just driving style. I know a ton of str guys that run the same kind of pressures I do. what works for me not work for you. for me I found a setup that is predictable to my driving style 100 percent of the time no questions. I took one ftdi event this year and the car was not sloppy at all.
#13 | |
#14 |
Drives: 13 Whiteout
Cool vid...I have a taller side walls (225/50-16) but I find 35 F is the lowest I can go before to much roll over.... and 32 R w/ almost no roll over on my RS3's.
Seeing this vid also remindes me I need rear sub frame bushings.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
| DIY: Cutting OEM struts (front) for Koni Yellow inserts | mit_peid | DIY (Do-It-Yourself) Guides | 25 | 06-20-2014 01:16 PM |
| Review: RCE Yellow Springs and KONI shocks | Grimlock | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 81 | 03-27-2014 11:58 AM |
| F/S: Koni Yellow struts and H&R Supersport springs $650!! | MountainManFR-S | Brakes, Suspension, Chassis | 4 | 07-02-2013 08:06 PM |
| -Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! | OrbitalEllipses | Mid-Atlantic | 21 | 06-14-2013 01:10 PM |
| Koni inserts or wait for full Koni replacements | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-18-2013 06:48 PM |
