Old 10-21-2013, 06:00 PM   #1
nix
nix's Avatar
Drives: AVO BRZ
Why not to buy imitation / fake wheels
Someone linked this to me on fb (top gear Philippines). ow.
nix is offline
Old 10-21-2013, 06:02 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Old news. Take it to 4283628173827 other threads that are already discussing this topic
TylerLieberman is offline
Old 10-21-2013, 07:29 PM   #3
Jimmy
Drives: White GTS MT
If you hit something hard enough, any wheel will break.
Jimmy is offline
The Following User Says Thank You to Jimmy For This Useful Post:
JSanders (12-04-2013)
Old 10-21-2013, 07:48 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
and this
[ame]http://youtu.be/EXs3e2n5zw4[/ame]
SmsAlSuwaidi is offline
Old 10-23-2013, 08:45 AM   #5
nix
nix's Avatar
Drives: AVO BRZ
Sure, I myself have had serious wheel damaging impacts on my cars over the years. But you want the tyre and outer section of the rim to deform without spoke damage or hub separation. In this example it seems the spokes have sheared without any impact damage to the tyre/rim.
Super dangerous and perfect example of why for $250-500 more per set you should consider even cast enkei/work/gram lights over rota or china brands.
nix is offline
Old 10-23-2013, 08:54 AM   #6
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I appreciate this thread since I missed the other 4263628173827 threads.
whaap is offline
Old 10-23-2013, 09:03 AM   #7
mrk1
Drives: Sterling BRZ Ltd
Anyone can google search pics of any broken wheels from any brands, no wheel no matter what brand or price is indestructible.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline
Old 10-23-2013, 09:48 AM   #8
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Here is a pic of real TE37. My friend took this pic. The car lost control and rushed into a lawn. My friend told me that the speed was less than 60mph.
There r lots of broken TE37 pics on Google. This one is not bad cuz the the car was not fast when it rushed into the lawn.
I read a thread long time ago and it showed that on street forging wheels may not be stronger than casting wheels(not fake wheels). They are just lighter, with the same strength level.
So I got Rotas now, and Im gonna save money for TE37s.
BTW Rota are good for DD.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline
Old 10-23-2013, 09:48 AM   #9
bfrank1972
Drives: 2013 FR-S Argento
Is there conclusive evidence that knock off brands (rota, xxr, etc) are dangerous? I see a lot of statement as "fact", but not much evidence. Also what conditions would you say cause such failures?
Sent from my iPad using Tapatalk - now Free
bfrank1972 is offline
Old 10-23-2013, 09:58 AM   #10
Figo
Figo's Avatar
See my post upper.
Rota are heavier. They are just a little bit lighter than OEM rims. My 18X8.5 Grid is 21 or 22 I think. Te37sl is 15 or 16 somthing. But they are strong enough for DD. My friend even use Rotas on track.
Anyway, they are heavier, but with the same strength level. And they are not fake wheels. Rota made OEM wheels also.
Figo is offline
Old 10-23-2013, 10:04 AM   #11
bfrank1972
Originally Posted by Figo View Post
See my post upper.
Yah that's what I was thinking - some allude to brands like these being dangerous, but I don't buy it. Nor do i see hard evidence. Just because they're inexpensive doesn't mean they'll fall apart. I like cheap wheels, allows me to spend my funds elsewhere regarding track use I'd imagine if they're good for street they'd be good for track - I'd imagine a decent size pothole puts a lot more stress on a wheel than on a smooth track under constant cornering load. All bets are off when you have an off track excursion though.
Old 10-23-2013, 10:12 AM   #12
Figo
Figo's Avatar
Wheels like RPF1 are good for the price. But I just like the TE37 design better. Te37s are way too expensive. So I got Rota Grids for now.
Forging can make wheels stronger than casting does. So Forging wheels can be lighter than casting wheels at the same strength level.
However, it does not means than a 15lbs forging wheel is stronger than a 21lbs casting wheels.
Say, aluminum is stronger than wood. But it will be easier to bend 1mm aluminum than to bend 1m wood.
Figo is offline
The Following User Says Thank You to Figo For This Useful Post:
bfrank1972 (10-23-2013)
Old 10-23-2013, 03:55 PM   #13
SmsAlSuwaidi
Boosted
Cracked OEM Scion Frs GT86 Brz Rim by smsalsuwaidi, on Flickr
Almost died from this accident with the stock wheels
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
denkigrve (10-23-2013)
Old 10-23-2013, 04:53 PM   #14
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline
The Following User Says Thank You to Cjymiller For This Useful Post:
Real wheels or "fake"wheels? Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 102 07-26-2013 03:43 PM
So, if i fake pissed on your car. Would you be mad? dem00n Off-Topic Lounge [WARNING: NO POLITICS] 44 04-17-2013 10:06 PM
Are these fake? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-11-2013 01:57 PM
Uh oh... here we go with the fake coilovers... DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 07-25-2012 10:49 PM
Imitation Alcantra? ForReal-Someday Electronics | Audio | NAV | Infotainment 13 05-01-2012 05:07 PM
