Old 10-17-2013, 10:56 PM   #351
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by shiv@vishnu View Post
The Stivo EL header in our car triggered the same code so it's pretty common. That code is disabled in the Stg2 OTS map that we are about to release.
I've been waiting on stg 2 before purchase and wanted to get the same headers you used, but I can find no info on the Stivo EL. Anyone know where these can be purchased?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 10-17-2013, 11:13 PM   #352
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Call or email Wheeldude. They may have a few more units in stock. Like mine, they are early product units but they fit and work well. That's who I got them from.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 10-17-2013, 11:36 PM   #353
fstlane
fstlane's Avatar
Drives: BRZ Limited
Is it advisable to still run an o2 sensor spacer on a catless header with OFT stage 2 or does the tune eliminate both P0171 and P0420 CEL codes? I'm installing a Borla uel header this weekend and want to try and eliminate any potential issues. Thanks again for the awesome work!
fstlane is offline   Reply With Quote
Old 10-18-2013, 12:40 AM   #354
yuicebox
Drives: Asphalt FRS
Forgive my ignorance but why all the obscure mods? Like air raid and stivo EL? Anything the community can do to get some more common parts supported? Also how far out is datalogging? Really want to order soon but feeling a bit timid
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
yuicebox is offline   Reply With Quote
Old 10-18-2013, 10:16 AM   #355
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Questions???
Some tuners have been telling that temperatures from puerto Rico and elevation affect the tuning if I use one from US. Will I be able to tune with a tune from the website and have the same results? I know is a noob quetion but there it is... Can I pick up a tune placed on my FRS and works perfectly here at 90 or 100 degrees? Do I need to change something on the tune? Thanks
kombatlion is offline   Reply With Quote
Old 10-18-2013, 10:19 AM   #356
qoncept
qoncept's Avatar
Originally Posted by kombatlion View Post
Questions???
The ECU makes corrections based on temperature and atmospheric pressure and tons of other things. It'll be fine. You could see some very (very) minor gains for being tuned for very specific weather, but it gets cooler at night. I say load the OTS tune.
qoncept is offline   Reply With Quote
Old 10-18-2013, 12:27 PM   #357
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
I came here to ask this exact question. As soon as my front pipe arrives it's gonna be go time.
VR46 is offline   Reply With Quote
Old 10-18-2013, 01:24 PM   #358
Shiv@Openflash
Drives: 2013 FRS
I don't think there is any need to do an 02 sensor spacer if you are running the OFT since you can disable the emissions code routines. But I have not tried removing the o2 sensor spacer in my header to confirm this. I should have the Stage 2 map (for cars with catless header) released early next week which should work quite well with your new mod
Old 10-18-2013, 01:27 PM   #359
Shiv@Openflash
Drives: 2013 FRS
The mods I tested came from our friends at Wheeldude.com. But I can say that the stock air box with aftermarket panel filter and snorkel removal works at least as well as any aftermarket intake at a fraction of the cost. The MAF readings are also more stable and consistent which is the biggest advantage of running the stock airbox. I no longer run the AirRaid airbox for this reason.
Datalogging isn't too far out. The programmers are working it out right now from what I've been told. I've tested some beta versions of it and I think everyone will be pleasantly surprised.
Shiv
Old 10-18-2013, 01:31 PM   #360
yuicebox
Drives: Asphalt FRS
edit: Thank you lol
Old 10-18-2013, 03:35 PM   #361
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Hey @shiv@vishnu,
I thought I remember you saying that you could load a brzedit tune (unlocked) with the oft. Am I remembering this correctly, or am I nuts? Or is there something else I have to do?
Installed Mods:
Old 10-18-2013, 05:26 PM   #362
Anorax
Drives: '13 BRZ SS
Ordered today, thanks Shiv from CO
Anorax is offline   Reply With Quote
Old 10-18-2013, 09:16 PM   #363
Shit Luck
Drives: red frs
Still can't get the launch control setting altered with out causing a no start....
Am I that dumb or what???
Shit Luck is offline   Reply With Quote
Old 10-18-2013, 10:33 PM   #364
Hagbard
Hagbard's Avatar
Not sure if this helps but it did work for me, i set it to 4500rpm, What i did was open the rom save it as a new file with new name so id know it was the one i was messing with, change the LC RPM Delta to 3100.00 hit the little Disk Icon in the LC RPM Delta to commit the changes, saved the rom again to make sure, then uploaded the ROM to the OFT then flashed car.
Hagbard is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
