Old 10-15-2013, 09:25 PM   #1
rskdsk
Drives: series 10 FR-S (2361)
What is this Windshield number / code
Can anyone tell me what is this number in the windshield? You can only see it when view at a certain angle and it is on the lower drivers side. My car is a series 10, but I do not recognize the number. I tried to see if it can be removed through washing the windshield, but it seems to be ingrained into it. You can not see it when driving or look at it straight on ... only at an angle.
rskdsk is offline   Reply With Quote
Old 10-15-2013, 09:40 PM   #2
mrceltic
Drives: 2013 Hot Lava Scion FR-S
I don't know what it might be for, but it's probably wax marker, guessing it'll come off over time. If you do try to scrub it off don't use anything abrasive, I've got some small swirl marks from trying to get a residue off of my windshield.
RainX makes a cleaner that works great. A clay bar is another option I've heard positive reviews about.
mrceltic is offline   Reply With Quote
Old 10-15-2013, 09:46 PM   #3
rskdsk
I have tried windex and clay bar ... still there. In fact, they did absolutely nothing! The numbers seem to be in the windshield.
Old 10-15-2013, 09:51 PM   #4
rskdsk
It is not a big deal because it can not be seen unless really looking for it or if the windshield has condensate on it and you look at an angle ... just curious about the number
Old 10-15-2013, 09:54 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Probably written as an easy to read ID during shipping so it can be unloaded and routed to your dealer quickly. Mine had it as well, was gone after the third or fourth hand washing.
ineedyourdiddly
Old 10-15-2013, 10:01 PM   #6
Hardrock4445
Hardrock4445's Avatar
They all had them, will come off over time.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 10-15-2013, 10:02 PM   #7
rskdsk
OK ... I guess it will go sooner or later ... but with 1000 miles on the car, a couple of washes and a good windshield cleaning ... it seems firm
Old 10-16-2013, 12:27 AM   #8
Mine has some sort of number I can barely see if I'm washing the windshield ....
Maybe a NSA/CIA/FBI/ICE/ATF/KGB ..... tracking number .. ?? ...
Old 10-16-2013, 01:24 AM   #9
torqdork
torqdork's Avatar
Drives: RV-7
I believe you're right. Except "quickly" turned into a month long stop sale waiting for the Toyota IT wonks to generate accurate window pricing labels while the routing numbers etched into the glass at the POE's.
I've tried everything mentioned. Nothing worked, but it's only been three months and a half-dozen washes. Next I'll try Griot's glass polish and a machine buffer. If that doesn't work, I'll try to ignore it.
However, a little twist is that at my last track day they used shoe polish to write running numbers on the small side rear windows. I washed it off easily the next day but it's doing the same thing as the windshield effect so will hit all the windows with the buffer and hope for the best.
torqdork is offline   Reply With Quote
Old 10-16-2013, 01:26 AM   #10
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
Got the same thing on my 10 series. Only saw it once, when it was foggy. I'm guessing it's some kind of marker that was removed but left something hydrophobic/oleophobic .. haven't tried buffing it out yet.
rishi is offline   Reply With Quote
Old 10-16-2013, 07:27 AM   #11
rskdsk
Buffing did not work for me ... so I'll just give it time. Here in FL the sun may do the trick after a few months.
Old 10-16-2013, 09:15 AM   #12
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I had the same thing. It will go away over time.
whaap is offline   Reply With Quote
Old 10-16-2013, 09:28 AM   #13
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Mark uh duh beast.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
bestwheelbase (10-16-2013)
Old 10-16-2013, 09:37 AM   #14
Minhtyfresh
Drives: Whiteout fR-S
Use bon ami powder and water. That should get rid of it. Bon ami is sort of the go-to windshield cleaning product for many manufacturers and businesses.
Minhtyfresh is offline   Reply With Quote
Windshield wipers NMMI89 Cosmetic Modification (Interior/Exterior/Lighting) 34 09-22-2016 12:26 AM
Windshield Decal Cameronghanson Cosmetic Modification (Interior/Exterior/Lighting) 37 05-25-2014 09:47 PM
Windshield IloveBaldEagles Mid-Atlantic 3 12-05-2012 02:19 AM
Windshield Repair Blake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-03-2012 05:18 PM
Foggy windshield? Phaedrus29 BRZ First-Gen (2012+) — General Topics 11 07-29-2012 08:54 PM
