Old 10-09-2013, 04:09 PM   #29
TurboBrett
Drives: 13 BRZ
Add me to the list, done it since day one and goes away after a couple of turns. It makes me worry the fluid isn't doing it's job or it's missing the proper additives. Good to know I'm not the only one.
Has anyone talked to a dealer about this?
TurboBrett is offline   Reply With Quote
Old 10-10-2013, 09:18 AM   #30
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
So just an update, I noticed that it would take a little longer for the noise to go away; instead of just the first left turn out of my neighborhood, I noticed it did it for another 5 miles (did a bunch of u-turns to see if it was still making the noise), before it was quiet.
I just changed the diff fluid yesterday (@ 4,000 miles), and the OEM fluid wasn't too dirty, but there was a lot of metallic "gunk" on the magnet. Replaced it with Motul Gear 300, and will post up if I notice any difference in the noise.
smbstyle is offline   Reply With Quote
Old 10-20-2013, 12:34 PM   #31
smbstyle
smbstyle's Avatar
UPDATE:
So after changing the diff fluid, I haven't had any more noise when cold. I've got about 500 miles on the diff fluid change; i'll report if it comes back.
The Following User Says Thank You to smbstyle For This Useful Post:
TurboBrett (10-21-2013)
Old 10-21-2013, 01:23 PM   #32
TurboBrett
Drives: 13 BRZ
Well now that is quite interesting and promising. Really hope you continue to give us more updates as you add mileage.
Old 10-21-2013, 02:24 PM   #33
smbstyle
smbstyle's Avatar
Will do!
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 01:54 PM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 04:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 03:54 AM
