Should I check for injector damage?
I've read through all the threads about injector failures and I realize the problem isn't extremely widespread however from what I gather, the stock tune does have some issues that cause knocking in areas that CAN cause damage to the injector seals, and possibly the motor itself.
My car is relatively high-mileage at this point with 23,000 miles already clocked. I can only get crappy Cali 91. It's my daily driver, which involves 30 miles of canyon roads daily and another 50 of mixed city/hwy. So while I don't drive the piss out of it, she has plenty of fun. So should I be worried enough to check for injector damage? I have a tune on the way that's supposed to fix those knock areas. The car seems to drive just fine. Yeah, I've heard a bit of knock in a few places or during certain shifts, but nothing extreme. I've never had a CEL. My on-board display MPG average since new reads 30.2, which is closer to 29 calculated at the pump, but still...seems good. I've never really had idle issues...yeah a few dips here and there but never too often. Of course my fuel pump chirps when temps are hot...though not as loudly as when the car was newer. Any thoughts are appreciated.
#2 |
Drives: FRS
I wouldn't worry about it. There are a lot of these threads.... My opinion is this: no need to pull them unless you are getting symptoms.
#3 |
Drives: '15 STi Ltd
Stop looking for a problem if you don't have a problem: you'll go nuts.
#4 |
Seems Legit
Drives: Toyota
BEST...ADVICE...EVER!!!!
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#5 | |
With the Vishnu tune I'll have next week I'm pretty confident the quirky aspects of the stock tune will be corrected. But if I've already done any damage already, I'd prefer to know about it. [kkocks on wood] -- this car has been dead nuts reliable so far. All my issues are trivial and the car returns fantastic mileage while also keeping a smile on my face. I just want to keep it that way.
#6 |
Drives: I own an FR-S. . . whatelse!
#7 |
I have a code reader. I check stuff...no codes.
#8 |
#9 |
If your fuel avg. display is reading 30.2 you are in no way driving this car hard enough to be worrying about DI failures.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
#10 |
Drives: SWP BRZ
#11 | |
![]() I'm actually pretty amazed by it. That is a global average that even includes all my AutoX days. Since I drive mostly downhill on the way TO work, I do a lot of coasting with engine braking, which I know generally has injectors turned off or nearly off. My way HOME from work is mostly uphill (obviously), so that's where I have tons of fun. I don't wring it out to redline all day every day, but trust me...I have plenty of fun. My global average is only 1MPG worse than my last car, a BMW 335d.
#12 |
I DD car and readout is 25.1
well below average for mostly stock....
#13 |
No symptoms no problems.
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Injector Seals went Bad while tuning my car | whitefrs | Forced Induction | 128 | 08-20-2013 12:19 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 06:54 AM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 09:31 AM |
