#1541 | |
Drives: WR Blue Mica Subaru BRZ
The car will be finished by Saturday or Monday as they are painting some parts of the body kit. I will post pictures tomorrow -unfinished state with the rims / wheels etc. Thanks. Last edited by WhitePlainsBRZ; 10-02-2013 at 10:42 PM. |
#1542 |
Drives: pearl white eighty six
@WhitePlainsBRZ yup almost 200k less the total is more than fair enough considering the car has never been driven with the modded parts in it, parts are pratically bnew, if u dont mind can u pm me d price of the hks sc
A bit of questions guys 1. does upgrading your IHE void the warranty? and to those who hav had theirs upgraded already how much milage did u have when u did the upgrade? 2. how much would be the gain in IHE upgrade w/ and w/o tune? 3. Is it even worth the 100k something for the gain, or is it more logical to just go w/ FI, either a low boost turbo, or SC w/ a low pully, maybe just to go around 230ish? but that wont happen until i put some serious milage on the car but the thing with the darkside is once u go that route thers no turning back hehe, hav had 2 turbos before, and my experience is u can never crank up that boost controller enough hehe TIA have a great week end
#1543 |
On warranty, I was told that if I upgrade the ICE of my BRZ they will only void that. Other parts of the car will still be covered by warranty.
For those living in the Philippines which would you choose? The VW Tiguan TDI or the Forester XT? |
#1544 |
@pearlhatchiroku, since these are engine mods, im assuming if anything happens to your engine, casa will not cover it but if anything else goes wrong like sa suspension, they should still cover it even with IHE.. for the gains and from what i'm seeing, parang around 200whp lang with IHE kaya alot are going with FI since gains are higher compared to how much you'll be spending
@Alabang BRZ, i've always been a fan of the FXT lalo na the previous body pero if i'll be concerned with the gas, i'd go with the VW since its a diesel |
#1545 | |
Now, crunching numbers the more expensive Tiguan will be cheaper by P145,750 after running 100,000km. Assuming P43.xx for diesel and P53.xx for petrol and the Tiguan is sold at 1.99m and the Forester at 1.868m. Forester starts being more expensive after 45,645km... Last edited by Alabang BRZ; 10-06-2013 at 07:35 AM. |
#1546 |
@Alabang BRZ, maintenance can be expensive for Subarus lalo na if casa kaya i opted for the 86 rather than the BRZ
though i wonder how is the maintenance of the VW.. and even though diesel is cheaper, maintenance costs are higher afaik
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
| The Following User Says Thank You to pcuerpo For This Useful Post: | Alabang BRZ (10-07-2013) |
#1547 |
Drives: Toyota 86
with the cost... my vote goes to FI...
#1548 |
anybody here who has done a squared setup and placed 265/35/18 up front? the rims im looking at is +40 and 9.5 wide.. i'll be on stock shocks with Eibach lowering springs if ever.. will it fit and would i have any problems?
#1549 | |
#1550 | |
Drives: Subaru BRZ
depends on what your criteria is, if you want power then the XT is the most powerful in it's class. if you want comfort or luxury then i'd go with tiguan. the current XT's ride is a bit stiff compared to the previous gen XT's, plus the interior isn't as well built as the tiguan. but since the tiguan is a euro car and a diesel, i'm sure maintenance and parts will be more expensive than the XT. oh and you have to consider the cvt of the new XT, not a big fan of cvt's since they cause problems in the long run. |
#1551 | |
Tiguan comes across to me as entry level with cloth seats vs the Forester's leather ones. Driver seat of the Tiguan is manual vs Forester's automatic seat. Electronics on the Tiguan are really lacking in comparison to the Forester. |
#1552 | |
Drives: RED BRZ
With a 265/35/18 up front and a +40 offset, the tires will stick out of the fender well and will also hit the front struts. The rears though would be fine. If you want to make the 265's fit the front, you will have to switch to coil-overs, stretch and pull the front fenders and go with massive negative camber. Aside from all the work needed to make the 265s fit, they are not advisable for the fronts as: a) they are heavy b) they will affect the steering feel adversely c) make your car slower. Maximum advisable for the fronts would be 245s. Hope this helps you out. |
| The Following User Says Thank You to NIKDENG For This Useful Post: | melon (10-08-2013) |
#1553 | |
Drives: Subaru BRZ
#1554 | |
Drives: RED BRZ
1. Upgrading your IHE will void the warranty of your original IHE. The rest of your engine warranty will still stand unless the casa can prove that an engine failure can be directly attributed to the IHE modifications. Started upgrading intake and exhaust after the break-in period. 2. Just bolting on IHE will net you little gains. The 4U-GSE boxer engine doesn’t like bolt-on modifications and the stock ECU tune is the limiting factor as it is set to run significantly rich across the powerband to make the engine last longer. Installing a good quality straight 2.5 inch exhaust system: catback exhaust, catless front pipe, overpipe and the 4-1 catless header with no ECU tuning will gain you just about 8-12whp and 8-10ft-lb of torque. Compare that to ECU tuning alone to make the system run a little leaner on a completely stock system which can easily gain you 10-12whp. Tuning the ECU with the IHE should net you another 10-15 whp and 8-10ft-lb of torque for a total of about 18-27whp / 16-20ft-lb of torque. 3. It is more logical to go straight to FI as you will never really be fully satisfied with the gains from IHE and ECU tuning which will be hard pressed to break 200whp which usually requires leaning out the fuel mixture to near limits which would be detrimental to engine longevity. Last edited by NIKDENG; 10-08-2013 at 04:28 AM. |
