Old 10-01-2013, 02:17 PM   #211
3essess
Drives: frs
Originally Posted by qoncept View Post
You do it in the manager software somewhere while it's plugged in to the computer. I don't have it with me here at work so I can't remember exactly, but it's one of the 6 or so buttons on the left.
Thanks for the help...worked perfectly!
3essess is offline   Reply With Quote
Old 10-01-2013, 03:06 PM   #212
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I pray that this forum doesn't become filled with Virtual Dyno plots.
+1
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 10-01-2013, 03:10 PM   #213
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Some good logging to just a CSV file would be awesome right now. I don't really need graphs on the unit itself.
FrX is offline   Reply With Quote
Old 10-01-2013, 04:56 PM   #214
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread
On the ots tunes. What are the options for intakes, exhaust etc?
edit:
Nevermind just downloaded the tunes and just took a look.
Installed Mods:
Old 10-02-2013, 07:23 AM   #215
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
edit:
This raised a good question for me. By "options," I don't know if you mean tunable parameters in regards to different intakes, etc., or if you mean different canned tunes that are set up for certain aftermarket parts. Hopefully the latter, because that's what I'm hoping for. Noob-friendliness.
I'm at work right now on my gub'ment computer, so I wouldn't dare download .exe files unless I wanted you all to see me on Fox News portrayed as the latest insider terrorist. So I'm just going to ask... if I download TunerPro and the OTS maps from this page, even though I don't have the tablet yet, can I use my own computer to see various maps that are already tailored to specific aftermarket parts?
I'm under the impression/hoping that the zip file has a selection of mod-specific maps and you just select the one most similar to your setup, flash, and go.
If that's not how it works, I'd appreciate if someone could set me straight on how it does work. Thanks!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-02-2013, 07:45 AM   #216
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Sofar it consists of Stage 1 maps for stock and AirRaid intakes.
But these maps are available in various folders named as:
ZA1J700C
ZA1J900C
ZA1JA00C
ZA1JA01C
and i have no idea, what is the difference between these folders, while the maps are named the same way and are of the same size.
Could someone explain what these ZA1J... numbers/codes are standing for?
Ondreiko is offline   Reply With Quote
Old 10-02-2013, 07:53 AM   #217
Anthony
Weight Nazi
Anthony's Avatar
Is that in response to my question? If so, are you saying that's the only maps it contains?
Old 10-02-2013, 08:29 AM   #218
FrX
It's the calibration ID for the ROM that you are using. For OpenFlash, at least, it expects you to match it up with the calibration ID that your car is currently using. It will throw an error, otherwise. They want to prevent you from flashing in an incompatible ROM.
Canned tunes. There are only prebuilt tunes for the stock and AirRaid intakes so far. They have indicated that canned tunes for various other combinations of parts is coming in the future. As far as tunable parameters, there are well over 100 different maps, scales, and values that you can change to whatever you want if you are so inclined.
The Following User Says Thank You to FrX For This Useful Post:
Anthony (10-02-2013)
Old 10-02-2013, 08:37 AM   #219
Anthony
Weight Nazi
Anthony's Avatar
Awesome, thanks. And I suppose the v1 base map will still be better than the factory tune for the time being?
Old 10-02-2013, 08:39 AM   #220
FrX
Depends on your viewpoint and definition of better. But yes, empirically, it is definitely more fun to drive. Though that may just be the different throttle mapping lying to me.
Old 10-02-2013, 09:34 AM   #221
cnk
Drives: '13 DGM BRZ Limited
The nice thing is that you can open the stock rom you pulled before flashing and compare it to the new one to see the differences.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 4
Old 10-02-2013, 12:27 PM   #222
Ondreiko
RWD addicted
Ondreiko's Avatar
[QUOTE=FrX;1245704]It's the calibration ID for the ROM that you are using. For OpenFlash, at least, it expects you to match it up with the calibration ID that your car is currently using. It will throw an error, otherwise. They want to prevent you from flashing in an incompatible ROM.
Thank you for your kind explanations. It really clears my doubts.
Old 10-02-2013, 12:28 PM   #223
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by shiv@vishnu View Post
A couple days ago, I went to the local Toyota dealership and read the newest 6AT software version (ZA1JA01D).
Have you had a chance to see what has changed between 01C and 01D?
Old 10-02-2013, 02:27 PM   #224
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
Originally Posted by Rombinhood@OpenFlash View Post
Yes, launch control and no lift shift is enabled in the 6MT OpenFlash maps
Is the no lift shifting already activated when you flash the ecu?
nguyen_er is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
