Old 10-01-2013, 03:04 PM   #925
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Oil fed compressor upgraded should be here in a week or two. Can't wait!
Nolan
pheoxs is offline   Reply With Quote
Old 10-01-2013, 03:34 PM   #926
DJCarbine
Thupercharged
DJCarbine's Avatar
Just a standard unit converted to oil fed? Going to run moar boost?
I'm debating getting the 12psi upgrade pulley/belt from fa20club, or possibly upgrading the compressor
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-01-2013, 03:39 PM   #927
ft86me
ft86me's Avatar
Drives: 2013 FRS
I eventually want to go that route with fa20 and see how i like that. I'm just worried about internals because of our high comp
ft86me is offline   Reply With Quote
Old 10-01-2013, 04:27 PM   #928
GUYVER116
GT86
GUYVER116's Avatar
Drives: Whiteout FR-S:(5/14/12)
My suspicions were correct, the pulley you remove during the vortech kit install FITS in the spot of the plastic pulley that seems to have failure issues.
You simply turn the pulley around and use the spacer that came off the plastic pulley.
A nice steel housing, OEM pulley. I am still going to swap to the ACDelco/Gates pulley when I get them, this is just temporary "get the car running" rigging but I think it would work long term as well.. the pulley is slightly larger (3-4mm diameter) but there seem to be no issues. Just started it up and everything is good. Belt tension seems about the same even though the pulley is slightly bigger.
Very useful if your pulley dies and you still have your OEM one.
What is the part number for the ACDelco/Gates pulley replacement your going with?
FR-S Whiteout
GUYVER116 is offline   Reply With Quote
Old 10-01-2013, 04:51 PM   #929
DJCarbine
Thupercharged
DJCarbine's Avatar
Gates/ACDelco 38006
2013 FRS
Vortech V3 11psi
Old 10-01-2013, 05:47 PM   #930
pheoxs
That's correct. Plan is to run the 14psi pulley and limit boost with a wastegate for now to 9psi until the block gets built.
Sent from my Nexus 4 using Tapatalk 4
Nolan
Old 10-01-2013, 05:57 PM   #931
skatery1989
Drives: BRZ Limited
Good luck with that they've had mine for going in three weeks.
skatery1989 is offline   Reply With Quote
Old 10-01-2013, 09:28 PM   #932
skatery1989
Drives: BRZ Limited
Nevermind that it's finally here.
The Following User Says Thank You to skatery1989 For This Useful Post:
pheoxs (10-02-2013)
Old 10-01-2013, 09:54 PM   #933
DJCarbine
Thupercharged
DJCarbine's Avatar
I found higher-rpm bearings (~65K max), I wonder if we can just swap bearings and keep the internal oil system..... probably not, but it would be nice lol
I've been looking for a reason to tear down the blower anyways, its apparently quiet easy to get parts and rebuild these things with bearings/seals etc.
If i'm going to throw on a 12psi pulley I'm going to look into the higher speed bearings
2013 FRS
Vortech V3 11psi
Old 10-02-2013, 09:41 AM   #934
pheoxs
Mind taking pics of the install and sharing them with me? In particular tapping the valve cover? Would like to know if there's anything else I need to expect to get this back up and running. Gem have me a good idea (thanks man) but a second option is always good
Nolan
Old 10-02-2013, 09:45 AM   #935
DJCarbine
Thupercharged
DJCarbine's Avatar
Valve cover tapping for oil return I'm assuming?
2013 FRS
Vortech V3 11psi
Old 10-02-2013, 10:00 AM   #936
skatery1989
Drives: BRZ Limited
Will do hopefully start installing today and drop the valve cover off tomorrow.
pheoxs (10-02-2013)
Old 10-02-2013, 10:05 AM   #937
pheoxs
How do the instructions look? Decent or on par with the instructions for the original install haha
Planning to run E85 and more boost or?
I'm stuck with 94 octane so until I build the engine can't do much but wanna get everything but the block working great and then we'll see which project gets attention this winter. Part of me is thinking just drive it as is for a year and make sure everythings reliable before I tear apart the block. Also to make sure no one has issues doing internals (aka crawford blowing a block up already)
Nolan
Old 10-03-2013, 12:43 PM   #938
pheoxs
My roommate text me yesterday at work saying I had something from vortech. Come home to find an envelope with the invoice, fuuuu got so excited haha
Nolan
The Following User Says Thank You to pheoxs For This Useful Post:
charged86 (10-03-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
