Old 09-28-2013, 02:44 PM   #57
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Update: I went back to the dealer and talked to the excellent service rep that I originally set up the repair with. He said none of his notes were present, which is what I suspected. He said the regional parts manager made them put that clause in and say it wasn't warranty, probably to cover their ass. I asked for her name and contact info, and he said they weren't allowed to give it out, but to call SOA back and make sure to follow up.
At this point I don't know who changed the wording in the description of the problem from mine to something way more severe. He also confirmed it was her that said "the car's not designed to be shifted at 7000k RPM." What a crock.
This is going to be a pain in the ass to fix, and I don't know exactly who a BBB complaint would be against if it was a regional parts manager who's screwing me.
DoomsdayJesus is offline   Reply With Quote
Old 09-28-2013, 02:49 PM   #58
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
LOL @ car is not designed to be shifted at 7k rpm. Maybe they should of lower the redline to 5k rpm and market the car with 150hp instead of 200hp.
Muaddib is offline   Reply With Quote
The Following User Says Thank You to Muaddib For This Useful Post:
sprintertrueno86 (11-26-2013)
Old 09-28-2013, 05:45 PM   #59
DoomsdayJesus
I also just took a look at the service manual, which clearly says only use GL-3 in the manual trans and GL-5 in the rear dif.
They clearly put the wrong gear oil in my MT if it's not a typo. What used to be a grind in 4th now just has pretty rough/notchy shifting all over, especially going into 3rd (although no grind).
I'm beyond fed up with this process and them screwing me/my car. I'm going to take it back and have them put the correct gear oil in, my bet is if they fill these stock with GL-4 or GL-5 that's one of the problems.
Old 09-28-2013, 06:05 PM   #60
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
at this point, i wont trust the dealer and never take my car there. i would deal directly with SOA and visit different dealer. explain your situation and how shitty that previous dealer is.
Old 09-28-2013, 09:56 PM   #61
Gixxer86
Drives: Scion FR-S (Asphalt)
Just thought I'd throw this out there. I have the same issue with my trans and have been getting the run around as well with the dealership. I'm not sure about with the BRZ, but my FRS has a three small booklets about warranties and maintenance that are with the service manual. All of them mention that there is a specific association to report to first that handles disputes with dealerships, lemon laws, and lawsuits. I'll take a look at see what the name was. might check in your manual to see if it says the same thing...
Gixxer86 is offline   Reply With Quote
Old 09-28-2013, 11:13 PM   #62
DoomsdayJesus
Originally Posted by lazyluka View Post
@DoomsdayJesus
Sorry to chip in so late, just saw this thread.
My transmission was grinding in 5th gear at normal motorway speeds. Anyway by the time I talked to Toyota about it and they wanted the car in I had a track day lined up so I said I would come after the weekend.
Funny thing is, after taking it to the track the problem fixed itself.
Still using factory fill, but yeah, the transmission is now wonderful. Not saying this would work for you, but in my case giving it a proper thrash seems to have resolved the issue for me.
Good luck getting it sorted.
I've been wanting to reply to this and forgot about it, you still need to drain your gear oil and check it. Even if it smoothed out there could be some serious problems and dirty oil/debris.
Usually that depends on the state since every state has different lemon laws. I've checked out WAs, and they have arbitration clauses that are handled by the state attorneys. Not to mention, usually in the military we have JAG offices/SJA reps that will cover our asses in large dollar screw-over issues. Although if I'm not mistaken they usually handle shitty landlords and people breaking lease agreements, there may be no coverage for lemon laws.
Old 09-30-2013, 09:46 AM   #63
andrew20195
Drives: 2013 Subaru BRZ
Technically the service manual recommends "MG gear oil special II
(API GL-3, SAE 75W-90)", but any GL-3 or later 75w-90 can be substituted. So GL-5 is acceptable.
andrew20195 is offline   Reply With Quote
Old 09-30-2013, 10:50 AM   #64
DoomsdayJesus
You're right, but I've read numerous places that GL5 shouldn't be used in transmissions with brass parts. At this point I'm on the fence about replacing my fluid until the problem is resolved.
Sent from my Marconi Telegraph
Old 09-30-2013, 12:52 PM   #65
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
This is a little more accurate:
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
Dipstik-sportech (10-01-2013)
Old 09-30-2013, 01:58 PM   #66
dehydratedH2O
Drives: 2014 BRZ Limited DGM
Originally Posted by Hawaiian View Post
Took my car to the dealer for this and the tech who drove my car granny shifted and said he couldn't replicate it under "normal driving" and that the car isn't meant to be speed shifted despite being a sports car.
hate to threadjack, but this is why import drivers have such a bad image...
dehydratedH2O is offline   Reply With Quote
The Following 2 Users Say Thank You to dehydratedH2O For This Useful Post:
Dipstik-sportech (10-01-2013), strat61caster (09-30-2013)
Old 09-30-2013, 02:31 PM   #67
Dezoris
Dezoris's Avatar
Seeing these threads constantly are a huge downer. The mass market dealers and companies don't have much interest in dealing with the enthusiast crowd.
However, I don't expect anything else from a 25k car regardless of the manufacturer.
Old 09-30-2013, 03:31 PM   #68
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
character assassinate much?
You have no idea how i drive or shift. The speed shift was his term not mine, and I definately dont slam into gear on shifts like that. The tech however shifted slower than my 16 yead old auto civic winter beater.
You can shift quickly without beating on the trans.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 09-30-2013, 04:32 PM   #69
n2oinferno
Praise Helix!
n2oinferno's Avatar
Originally Posted by Dipstik-sportech View Post
I think this sums it up quite well
This isn't fair. I redline our Camry every single day.
The Following User Says Thank You to n2oinferno For This Useful Post:
DylanFRS (10-01-2013)
Old 10-01-2013, 01:26 AM   #70
DoomsdayJesus
I think I love you
5th Gear "Mini-Grind" BRianZ Issues | Warranty | Recalls / TSB 63 07-18-2015 06:12 AM
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 01:08 AM
New "Drive Clean" on wheel repair and fitment SkAsphalt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-10-2013 06:59 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
16" Subaru Steelies $39.99ea limited to 4 sets Stav Canada Classifieds 5 01-04-2013 12:15 AM
