Old 09-26-2013, 04:55 PM   #15
ayau
Drives: Some rust bucket
Originally Posted by rice_classic View Post
You can see it around my tie-rod in this picture. It's just heat reflective tape so it cut to fit your application.
I'm cheap.. I use the "aluminum foil tape" but you can also use tape like this, which is probably better but...
Mr. Gasket 6323 Inferno Shield Heat Reflective Tape : Amazon.com : Automotive
It is basically the suspension parts with the rubber joints that should be taped?
Old 09-26-2013, 04:58 PM   #16
trackjunkie
Drives: Subaru BRZ Blue
Starting to receive the parts
The rotors, studs and open end lug nuts arrived. Can't wait for the air ducting...
trackjunkie is offline   Reply With Quote
The Following 2 Users Say Thank You to trackjunkie For This Useful Post:
DAEMANO (03-01-2014), rice_classic (09-26-2013)
Old 09-26-2013, 08:22 PM   #17
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The boots on the ball joints.
PRO86 | WTCC | STL
The Following 6 Users Say Thank You to rice_classic For This Useful Post:
Alabang 86 (02-28-2014), ayau (09-26-2013), DAEMANO (03-01-2014), glamcem (03-19-2014), normancw (03-23-2014), Sportsguy83 (09-27-2013)
Old 09-26-2013, 09:27 PM   #18
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Looks like you're doing everything right.
ARP: Check
Open lugs: Check
Brake ducting: Check
High temp fluid: Check
Some other ideas that might improve the longevity of some items:
1: put a little anti-seize on the wheel studs. It helps if you need to take the lugs off when things are really hot.
2: Wrap your ball joints/tie-rod joints in heat reflective tape so the heat from the brakes doesn't destroy the grease in them or destroy the boots around them.
3: Titanium backing plates can help as a thermal barrier between the inside brake pad and the pistons which can go a long way to keeping those dust boots in your calipers in tact.
4: HP PLUS!? I would definitely recommend a race pad considering your time on track and tire choice. Porterfield R4, Hawk DTC-70, Raybestos ST43 or 45. etc etc. Changing pads at the track requires a 14mm wrench and 5 minutes of your time... Might as well.
http://porterfield-brakes.com/index.php
Second this!!
With the ti-shims and TF Brake Cooling kit, I'm still on the stock front rotors that are in decent shape, running DTC-60s with life still in them, after 5 full track days (2 at Barber, 3 at Sebring). Ti-shims definitely saved my dust boots, they look like new still.
I have a write-up on the install of the TF Brake Cooling kit if you haven't checked it out yet.
Wrapped joints in heat tape and pics of the ti-shims below.
smbstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
amram (03-20-2014), rice_classic (09-26-2013)
Old 09-26-2013, 10:10 PM   #19
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
We have the same studs, lugs, and rotors.
Identical.
Fascinating.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 09-27-2013, 07:44 AM   #20
Stevo22
Stevo22's Avatar
Drives: GR86
Are those lugs supposed to be used with the OEM wheel? Total noob here but I thought most aftermarket lugs have a different seat type. My impression was that the OEM was ball type and aftermarket are the acorn type and using the acorn type on an OEM wheel can damage the lug.
Reference Picture:
Stevo22 is offline   Reply With Quote
Old 09-27-2013, 08:11 AM   #21
xwd
Subarus (and the FRS) use acorn seats.
The Following 4 Users Say Thank You to xwd For This Useful Post:
448hpsti (09-27-2013), amram (03-20-2014), Stevo22 (09-27-2013), Valentino (06-05-2015)
Old 09-27-2013, 08:35 AM   #22
DarkSunrise
DarkSunrise's Avatar
Some good information on this thread. Love tracking with this car too.
2022 BRZ Build
2013 FR-S Build
Old 09-27-2013, 08:50 AM   #23
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
ARP: Check
Open lugs: Check
The anti seize I use goes on the back of the wheel, against the rotor. I dunno, lube on lug and my driving style would sit in the back of my head all wrong I think, unless you tell me the carrier for the copper in the anti seize is not a petroleum base
Otherwise,
I agree with 2 3 &4 spot on
But I track hard
Don't have arp
Don't have open lug
Take a brass tooth brush from your tool box to the threads, make sure they are clean and be sure the rotor isn't rusting where the wheel contacts. I never have issues with lugs getting stuck, and i am anti impact pro tq wrench on lugs, most folk over tighten, I had a shop wind mine up to 100....
Now manifold, exhaust bolts, those get anti seize.
Failing at brakes so far and have yet to go pay Essex my wad.
My brakes aren't ducted, and they suck. So maybe you're onto something there! I just am not sure adding ducting will give me the thermal capacity I need, in the same physical volume of pad and rotor. I have only tried a ds2500 in stock size, are any of you convinced these setup plus track specific pads offer enough stop to not want a unrated brake kit for an Fi car?
I am on r comps with oe studs and steel lugs, no issue, do you guys think I should be worried about catastrophic failure of all five studs since I drive like an idiot on oe studs?
And yes, factory brake fluid in these cars is horse piss
448hpsti is offline   Reply With Quote
Old 09-27-2013, 08:57 AM   #24
ZionsWrath
Thanks
ZionsWrath's Avatar
Curious why you haven't got an aftermarket brake kit? Are you running in a class that prohibits it?
Old 09-27-2013, 09:03 AM   #25
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
No, just money, been doing all sorts of other shit with my time and coin summer here is too hot to track, now I'm looking at the dates and realizing I need to go bust out the coin for either ducts and pads or just bite bullet and drop a dollar amount with a comma etc like originally planned, rice's post was interesting to read
I don't have anything competitive planned, tho that may change, I'm just happy beating my last times, renting a transponder etc. theres a group by me that does a bunch of autox but I have yet to go out and play with others in a modified class, if that's what you were asking, it will happen in time.
Old 09-27-2013, 09:48 AM   #26
Dezoris
Dezoris's Avatar
Anything you do on the stock braking system is pretty much a waste. Doing pads and brake fluid is about as good as you can get. Only way to really cool them more is to run ducts but when you swap to AP kit it will overcool them so think about that.
Tried using DBA 4000 AND XP10 and it was bettet but still threw away 500$!
If you are crunched for now maybe get some blanks for front xp10 or xp12 bed the hell out of them. Swap fluid and just kill the rotors and swap every couple events for now.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
bedabi (02-28-2014), CSG Mike (09-27-2013)
Old 09-27-2013, 10:10 AM   #27
smbstyle
smbstyle's Avatar
I was considering the DBA rotors, but honestly, after 5 very hard days at Sebring and Barber, the OEM rotors are still holding up fine. Normal heat checking, but nothing that is of concern. I have a set of blanks ready to go, but am going to run these OEM rotors to see how far I can go with them.
I've been running the TF Brake Cooling kit and ti-shims since I started tracking, and I think they help contribute to extending the pad and rotor life. I know two guys whos OEM rotors were trashed after a day or two at Sebring.
Old 09-27-2013, 11:21 AM   #28
CSG Mike
CSG Mike's Avatar
It seems that the front brakes were not really designed to take the heat of constant hard braking. But that is a minor complaint; this car is just awesome at the track!
I've had ripped dust boots on my S2000 since my first track day... you won't have any issues unless you live in an area where they salt the roads.
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
86 brake calipers Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-17-2013 09:04 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
