Old 09-27-2013, 08:54 AM   #1
CBR600RR
Drives: Raven Black
Aftermarket tails, condensation?
So I am on my second set of stock tail lights and condensation is building up inside of them again.
If I were to buy aftermarket tail lights, I'd likely go with the Tom's style or Crystal eyes.... or any brand that doesnt get condensation really.
has anyone had issues with the aftermarket tails getting condensation like the stockers?
:happy0180:
Old 09-27-2013, 09:39 AM   #2
encity5
encity5's Avatar
Some have with certain lights, but most ( including toms and valentis) come with new gaskets that seal it better and prevent condensation.
In fact in the DIY section, you can make your own new gasket and stop the stock ones from condensation
http://www.ft86club.com/forums/showthread.php?t=26217
encity5 is offline   Reply With Quote
Old 09-27-2013, 11:53 AM   #3
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I have crystal eyes, no issues with condensation at all. My stock ones had condensation, tried dealer fix no dice, made my own gaskets and still didn't work. After crystal eyes I haven't looked back.
FRSfan111 is offline   Reply With Quote
Old 09-27-2013, 12:55 PM   #4
CBR600RR
Drives: Raven Black
Awesome!
Anyone else???
Old 09-27-2013, 01:00 PM   #5
dt's ft86
Drives: 2013 ft86
For some strange reason after 3 weeks of condensation it just stopped out of the blue...weird but im not complaining...
dt's ft86 is offline   Reply With Quote
Old 09-27-2013, 01:18 PM   #6
wrohdejr
Drives: 2013 subaru limited wrb brz
No condensation in my spyder tails. I have only had them for 2 months though.
wrohdejr is offline   Reply With Quote
Old 09-27-2013, 01:49 PM   #7
Burrcold
Drives: Subaru BRZ Limited
Didn't have condensation on either my old Crystal Eye's or my new TOM's.
Old 09-27-2013, 02:30 PM   #8
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
JDM Tom's are condensation free for me.
Remember, if you over-tighten/torque the bolts on the lamp you can also cause this problem for yourself.
Old 09-27-2013, 02:31 PM   #9
ExtremeAutowerks
ExtremeAutowerks's Avatar
Drives: Scion FRS
TOM's has a one year warranty on it
ExtremeAutowerks is offline   Reply With Quote
Old 09-29-2013, 10:51 PM   #10
Nu_era
Drives: 13 FRS 10series/94 Supra Turbo 6spd
Seems like some guys here have had luck. I usually keep it stock but my brother has 3 Vehicles with expensive Aftermarket LED tails and they ALWAYS have issues a year plus down the line. Condensation/moisture building up happens first but I hate to spend money then have an expensive part like that fail. I'm in AZ and it's hot and dry so that condensation tells me it's bad build quality usually. Most Aftermarket Tails look great so maybe a DIY to make them more durable would help....
2013 Scion FR-S "10" series 6-speed Manual- Daily Driver
2006 Lexus 400H - Family Car
1994 Toyota Supra Single Turbo 6-speed- Weekend Driver
www.affordablewindowtinting.com<---- My services
Nu_era is offline   Reply With Quote
Old 09-30-2013, 10:20 AM   #11
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
I have condensation in my Crystaleyes. It started on the passenger side and the company I bought them from swapped it out. Now it has happend on the drivers side and they are swapping it out as well.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Old 09-30-2013, 11:19 AM   #12
RFB
RFB's Avatar
Drives: FRS
Aftermarket Tail Condensation
My warranty swapped OEM tail lights also got condensation.
One of my Crystal eyes started showing minor leakage so I looked closely with the trunk lid open and saw suds accumulating at the base of the trunk lift mechanism.
Its an obvious water channel that continually assaults the top of the tail lights, which can eventually lead to tail light contamination of any tail light.
So - for 99 cents I got a pack of snowman snot (sticky gum for fridge post it notes) and made a dam that channels the water away from the top of the tail lights.
Seems to work so far , waiting for more temp and humidity extremes to be sure. Will post pics soon.
:happy0180:
RFB is offline   Reply With Quote
Old 09-30-2013, 11:21 AM   #13
svodka
Drives: 2013 BRZ 6MT
As others mentioned, condensation is caused by the gaskets and not usually an issue with the taillight itself.
Call your dealer, they will replace both gaskets under warranty. Believe there was a bulletin that went out for this issue quite a while back so the dealer will be aware of this.
svodka is offline   Reply With Quote
Old 09-30-2013, 12:49 PM   #14
RFB
RFB's Avatar
Drives: FRS
Condensation
Condensation is caused by water. Water which makes its way into the tail light through, around, etc., the gaskets on a continual basis.
The concept of my fix is to remove the water by flowing it away from the gaskets.
So far so good - :happy0180:
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
DRL condensation. Superhatch BRZ First-Gen (2012+) — General Topics 16 10-20-2013 02:13 PM
WTT: MY USDM Tails for your JDM/ADM/UKDM Tails ZC6BRZ Exterior Parts (Aero, Lighting, Etc.) 2 01-16-2013 11:24 AM
LED DRL Condensation ngabdala Issues | Warranty | Recalls / TSB 3 11-22-2012 09:38 AM
Condensation on the BRZ DRL mechaghost Issues | Warranty | Recalls / TSB 2 10-20-2012 09:39 PM
