Old 08-22-2013, 11:37 AM   #85
raytrix
Drives: Series 10 FR-S
Can you do a fender drop down option where Rocket Bunny Fenders is an option. Front adds 40mm and rear adds 65mm. It'll be cool if you can simulate that in the calculator for those that are potentially buying the Rocket Bunny kit to gauge the wheel size they need to fit that kit.
raytrix is offline   Reply With Quote
Old 09-11-2013, 07:58 AM   #86
SortaFlushed
SortaFlushed's Avatar
Drives: Raven Black
Thanks brotha
SortaFlushed is offline   Reply With Quote
Old 09-23-2013, 11:07 AM   #87
itdansharpe
itdansharpe's Avatar
Hi all, just wanted to mention we have over 150 registered wheel / tire fitments, with lots of different variations to camber, ride height, etc. This is great to see, thanks for the support! If there are other tools that you can suggest to help out the community, please let me know.
Some interesting stats:
Widest (legitimate) tire: 275/20R18 on 10.5" +30 (@kennethluy)
There are 7 members with 265/35R18 (including me!)
Narrowest sidewall goes to @Blaiz, with 245/30R19s.
Cheers.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
The Following User Says Thank You to itdansharpe For This Useful Post:
Sportsguy83 (09-23-2013)
Old 09-23-2013, 01:44 PM   #88
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
This is a great tool to visualize the potential tire choice. However, if I may point out one problem: the unit for tread height. It should be percentage (%) rather than millimeter (mm) since it is the percentage of the tread width. I would assume the calculation is done correctly and this may be just a labeling error.
If I may offer some suggestions:
1. In the Tire Diameter (mm) field, calculate the difference between the new value vs OEM in percentage with 2 significance (x.xx%). This number means how much variance of your speedo with the new tire setting. This variance can come in handy to mentally adjust your speedo you read from the car based on the new tire setting.
2. If you can high-light the distance you are calculating (e.g. fender gap, or offset from flush, etc) on the main display it will clearly show which is which. To simplify the display, you can simply use numbers in your text like 1 for Sidewall height and 2 for tire diameter and so on and display the numbers, if possible with two bars to show the ends. This will clearly present the distances to be measured and easier to convey the message.
3. Forgive my ignorance, have you calculated whether a choice of tire would rub the side wall (does not fit)? You might want to calculate the theoretical side wall gap based on the tire choice. This can come in handy.
Anyway, this is a great tool and thank you for that.
Keep up the good work!
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 10-27-2013, 01:26 PM   #89
86holic
Drives: 2014 lighting red 86
It helped me alot. I salute you
86holic is offline   Reply With Quote
The Following User Says Thank You to 86holic For This Useful Post:
itdansharpe (10-28-2013)
Old 11-05-2013, 02:30 PM   #90
Ray_32
Ray_32's Avatar
Drives: '12 Toyota 86 (RED) MT
Amazing tool! Really helps decision-making when it comes to wheels and tires. Kudos to the creator.
Ray_32 is offline   Reply With Quote
Old 01-14-2014, 11:51 AM   #91
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Why the HECK is this not a sticky anymore???
@itdansharpe
@Guff @Dave-ROR @ichitaka05 can we make this a sticky again? It's extremely helpful.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
Guff (01-14-2014), itdansharpe (01-14-2014), Marchy (01-14-2014), sklimo (01-14-2014)
Old 01-14-2014, 02:23 PM   #92
Sportsguy83
Drives: Limited BRZ
Thanks @Guff!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Guff (01-14-2014)
Old 04-17-2014, 04:12 PM   #93
phrosty
This appears to be offline.
phrosty is offline   Reply With Quote
Old 04-17-2014, 04:17 PM   #94
itdansharpe
Yea, my server is down right now. I will have it back up and running around 5PM EST.
phrosty (04-17-2014)
Old 04-17-2014, 04:35 PM   #95
phrosty
Cool. My wheels & tires were stolen off my car today so figure I'll replace them with something more interesting.
Old 04-17-2014, 04:36 PM   #96
itdansharpe
That's awful! What did you have, and what are you considering?
Old 04-17-2014, 08:39 PM   #97
phrosty
Stock. Cheaper to upgrade than to buy the OEs lol.
I'm thinking 18" bronze Enkei SR6 on my Whiteout will look pretty sweet if I remove my red mudflaps. Sadly I had week-old Pilot Super Sports on the wheels. I'll likely get more of those
Old 04-17-2014, 09:52 PM   #98
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Are there spacers made to fix specific offset "issues"?
Based on my setup, here's where my offset from flush ends up. Am I aiming for 0, or is a little desired/normal?
Front: -7
Rear: -14
B-R-Z is offline   Reply With Quote
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 164 02-09-2026 01:48 AM
Auto Fitment Calculator itdansharpe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-28-2012 02:09 PM
FR-S Speed/RPM Calculator FR-S #2637 Engine, Exhaust, Transmission 8 09-19-2012 12:41 PM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 12:31 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
