Old 01-28-2012, 07:39 AM   #57
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by switchlanez View Post
^Same tire manufacturer and dimensions as the Prius optional tires, yes, but different tire model and tread compound. Don't quote me on that; this is what I vaguely recall reading somewhere on this forum. Calling them "Prius tires" is a misconception.
Other way around, it's the same tire model as the Prius optionals, but wider.
Old 01-28-2012, 08:24 AM   #58
Boil
Drives: CX500 Cafe Bobber
I would swap the Prius tires for some Bridgestone Potenza RE-11s…
Boil is offline   Reply With Quote
Old 01-28-2012, 08:30 AM   #59
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Everybody will swap the tires especially when they get new rims.
SUB-FT86 is offline   Reply With Quote
Old 01-28-2012, 10:19 AM   #60
Argent6978
Argent6978's Avatar
Drives: '05 Focus ZX3, soon '13 Scion FR-S
I'm probably going to tear up the stock tires on the autocross and use that as an excuse to get new tires later.
Argent6978 is offline   Reply With Quote
Old 01-28-2012, 10:30 AM   #61
Giccin
Giccin's Avatar
Yep.
That is--after there is enough saved money for spankin' new Wheels.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 01-28-2012, 02:38 PM   #62
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Originally Posted by 4agze View Post
Last year they called the 2011 mini cooper s stale and needs to be redesign & golf gti needs to go back to its roots.
And not to forget they bashed the Jaguar XK-R for being too much of a 'track' car instead of it being more of a Super GT.
Yes children, Jeremy bashed a British car. It does happen.
OldSkoolToys is offline   Reply With Quote
Old 01-28-2012, 04:38 PM   #63
Steve
Steve's Avatar
Drives: 6MT
Originally Posted by Jordo! View Post
Last I heard, the same ones that are on the Prius.
Are they offering something stickier now? If so, then I recant.
The AMG vid was pretty neat, but I still personally prefer grip over sliding around. And again, we're talking about on the road here...
Oh man stock tire debate brought back to life a little, and I'm probably repeating some points already brought up, but I want to rant.
For anyone who still thinks the stock tires do not suite this car, I think the ideas brought up in that video switchlanez posted show fairly well why the FR-S/BRZ has the stock tires it has. With all the engineering that went into this car, does anyone really think they put no thought, if not just as much into the stock tire selection???? The stock tires are skinny and do look skinny compared to other sports cars, but not without reason.
Look at it this way. The tires are balancing two main things. Performance numbers being a far behind number (3.)
1. Safety (its a globally marketed car, which is meant to double as a daily commuter)
2. Fun (and driving pleasure, the whole point of this car)
(1.)The tires should have grip to be SAFE on public roads even with spirited driving and safe enough on the track. So drivers with little experience aren't going to slide around too much and too easily causing accidents. MORE GRIP = GOOD
(2.)The tires should have little enough amount of grip to have FUN with the car and slide it around. Face it, in dryish conditions, the car will not have enough stock power to throw the back-end out and slide around on demand ONCE you throw tires on with significantly more grip. And in my opinion that can only lower fun and enjoyment. LESS GRIP = GOOD
MORE + LESS = AVERAGE (or something like that). A purpose built sports car with just average grip, skinny tires???? Mind = Blown. I know right. The car was built for affordable fun, not affordable performance and numbers. The stock tires help achieve this.
Now for performance. Many seem to be under the illusion that this car is going to get noticeably better laptimes/performance with just more tire grip. IT'S NOT, until you get significantly more power out of the engine (ie a lot more than just bolt ons, so pretty much FI.) In fact once the amount of grip and tire width become excessive, not only is the fun factor going to be ruined, but overall performance will noticeable decrease. I think its safe to say now, that it is well known fact that if you buy this car expecting impressive laptimes/0-60/quarter-mile and all that stuff, without A LOT of modification, then you just bought the wrong car.
I think Toyota/Subaru did a good job in picking a tire with enough grip to drive to work safely and have a blast on the weekend. For the reasons above ill probably be looking for less expensive, comparable tires to the stock ones. (since they will definitely need to be replaced fairly often compared to most average commuters)
Okay done ranting, and stating nothing new, with my first try-hard post.
ON-TOPIC, glad they finally got to drive the 86, and put the nail into the coffin of the "BRZ better than 86" crap started by the Top Gear magazine article.
Steve is offline   Reply With Quote
The Following User Says Thank You to Steve For This Useful Post:
BMWDavid (01-03-2013)
Old 01-28-2012, 05:23 PM   #64
suprachica79
Drives: free Hyundai, 2006 Kawasaki ZX6R
Now for performance. Many seem to be under the illusion that this car is going to get noticeably better laptimes/performance with just more tire grip. IT'S NOT, until you get significantly more power out of the engine (ie a lot more than just bolt ons, so pretty much FI.) In fact once the amount of grip and tire width become excessive, not only is the fun factor going to be ruined, but overall performance will noticeable decrease. I think its safe to say now, that it is well known fact that if you bought this car expecting impressive laptimes/0-60/quarter-mile and all that stuff, without A LOT of modification, then you just bought the wrong car.
Phenomenal post Steve, I learned a lot
Originally Posted by old greg View Post
I'll be swapping out the FA for a twin turbo search engine.
Originally Posted by Longhorn248 View Post
Reminds me that I need to work on finding a JDM girlfriend, or maybe JDM modified for US use as I don't think I could learn Japanese.
suprachica79 is offline   Reply With Quote
Old 01-28-2012, 08:54 PM   #65
Infernal
NO FI?! (╯°□°)╯︵ ┻━┻
Infernal's Avatar
Drives: BMW e92 330D
+1 agree with steve
the tyres i imagine were also picked to increase the MPG figure quoted in the stats - us europeans ill get taxed less because of this
plus- these tyres are going to be cheap to replace in comparison to a 225/255 set up etc
I hope they do drive this car on the show though - looking forward to watching it tomorrow regardless :P
Infernal is offline   Reply With Quote
Old 01-28-2012, 10:29 PM   #66
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
Great post steve, makes a lot of sense. I guess it will be a matter of personal preference in a way. People that want a more planted, harder handling car can always increase the tire width slightly to 225 or 235. I still haven't decided if I'm gonna want to get bigger tires or not. Your post is making me reconsider. Guess I'll have to judge it once I drive it.
Subaruwrxfan is offline   Reply With Quote
Old 01-29-2012, 12:04 AM   #67
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Yeah great post Steve. Just want to rearrange your wording a bit: The average of MORE + LESS = OPTIMAL. We got what you were trying to say though. lol
Old 01-29-2012, 01:41 AM   #68
70NYD
70NYD's Avatar
Drives: RX8 S1
mm can't wait for a test drive
70NYD is offline   Reply With Quote
Old 01-29-2012, 02:11 AM   #69
renyeo
Rants About Cars
renyeo's Avatar
Drives: what car
Has Clarkson actually driven the GT86?
renyeo is offline   Reply With Quote
Old 01-29-2012, 05:59 AM   #70
miata
Drives: 2006 Miata 5 spd
I don't think people will go back to stock tires when they wear out. Honestly who would put the prius tires back on to have "fun"? Owners will put extreme performance tires if the weather permits. I would. Wouldn't you?
miata is offline   Reply With Quote
Your thoughts on Paddle Shifter sports cars? SevenTenSplit Other Vehicles & General Automotive Discussions 69 12-23-2011 06:12 PM
Top Gear Online Subaru BRZ review - if you enjoy driving, this is the car for you Hachiroku BRZ First-Gen (2012+) — General Topics 54 12-13-2011 07:32 PM
EVO First Drive Review of Toyota 86 - Calls it Brilliant! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 45 12-03-2011 03:07 AM
Leo Parente on Toyota Race Cars and Motor Sports (FT-86 included) Matador Scion FR-S / Toyota 86 GT86 General Forum 22 07-06-2011 10:07 AM
Toyota Chief Evokes James Bond in Push for Sports Cars Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 7 08-20-2010 11:39 PM
