Drives: Subaru BRZ
Bad Catch Can?
I installed a Mishimoto catch can yesterday. Since there is one input and one output, I tough it would be easy. When I started my engine today, the idle was REALLY roughh. It was going from 500 rpm to 2700 rpm then get back to almost normal before to stop. If I touched the gaz, the engine would also stop.
I reconnected the way it was stock and my car is now running normally. It was installed on the circuit in the back of the engine ( the one that start from the head and goes into the intake manifold. I didn't have any leak... Am I the only one who got such issue? |
#2 |
Drives: 2005 Toyota Camry
You have a vacuum leak somewhere. Most likely the can or the tubing.
-alex |
#3 |
That or your containing the system.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#4 |
Could be blocked airflow. Report back.
#5 |
Drives: red subaru brz limited
not doubting you.. but did you hook it up to create a proper vacuum?
#6 |
Drives: Subaru BRZ
I corrected the problem for now, I uninstall it... I will try to find to change it's location...
#7 |
Drives: GT86
#8 |
Drives: Subaru BRZ
The best place I found was to delete the filup windshield washer conduct and put it there.
| Catch Can | ArKiTeCkT | Engine, Exhaust, Transmission | 31 | 09-15-2013 04:07 PM |
| FS: Cusco Oil Catch Can | JPxM0Dz | Canada Classifieds | 8 | 04-21-2013 12:46 PM |
| Oil Catch Can? | eblamble3 | Engine, Exhaust, Transmission | 4 | 03-15-2013 11:58 AM |
| Oil Catch Can.? | Cjs_ | Engine, Exhaust, Transmission | 18 | 03-01-2013 12:58 AM |
| Catch Can Help | wootwoot | Engine, Exhaust, Transmission | 2 | 12-02-2012 03:35 AM |
