Old 09-17-2013, 11:47 AM   #1
dstupich
Drives: 2013 scion fr-s
Question post accident seatbelt tensioner fix
I recently bought a salvage FR-S as a project car--it had a front impact with airbag deployment on the driver steering wheel. It is coming along pretty well but I am getting into seatbelt and airbag replacement issues which I do not know much about. I will likely not repair the airbag on the steering wheel because I want to put on a momo wheel. However, I need to get the seat belts working--I want to release the tensioners and replace them if necessary. Any suggestions on how to proceed? Do I need to replace the srs control unit?
dstupich is offline   Reply With Quote
Old 09-17-2013, 06:36 PM   #2
Panman
Panman's Avatar
Drives: 86 GTS
You need to replace the seatbelts in total - they are designed to stretch in the case of a major impact (ie setting off the bags), they are absolutely NOT reusable.
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
BRZ_Lawyer (12-29-2013)
Old 09-17-2013, 08:20 PM   #3
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Tensioners need to be replaced and many times the actual airbag control module needs to be replaced. Also check the clock spring. Sometimes they burn up
Old 09-17-2013, 09:01 PM   #4
dstupich
Ok thanks, I will purchase new seat belts. Also, I found an airbag control service that repairs the unit. Does anyone know the location of the unit?
airbag, belt, seat, tensioner
Need V-belt tensioner torque value... cobrabyte Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-10-2014 11:47 AM
Perrin LWCP tensioner wabble NickFRS Engine, Exhaust, Transmission 8 04-02-2013 09:23 PM
Has the seatbelt 'burned' you yet? Rob_g Scion FR-S / Toyota 86 GT86 General Forum 22 07-17-2012 03:01 PM
driver belt tensioner Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 3 07-10-2012 06:44 PM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 05:25 AM
