Old 04-05-2013, 11:02 PM   #57
awlllwa
awlllwa's Avatar
Drives: '89 XT6 '03 Outback '13 BRZ Limited
Just about to install mine. I painted my housing white to match the body. I'll post pics when I'm done.
Sent from my Galaxy Nexus using Tapatalk 2
awlllwa is offline   Reply With Quote
Old 04-06-2013, 12:06 AM   #58
Timmy_Jones
Spun
Drives: 23' Supra
Why install these horns? Are they louder?
Timmy_Jones is offline   Reply With Quote
Old 04-06-2013, 12:18 AM   #59
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Much louder
Via my Note 2
Freeman is offline   Reply With Quote
Old 04-06-2013, 01:04 AM   #60
zooki
Drives: waiting on a 2021...
I managed to install these horns without pulling off the front bumper, but I have a lift in my garage. You can unbolt the plastic piece from the bottom and have enough room to work if the car is off the ground. I also disassembled the horns and painted the red parts black so they wouldn't show through the grill.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
DAEMANO (12-05-2014)
Old 04-06-2013, 05:33 AM   #61
killercl0wnfish
Drives: fr-s
drilled right into the support they line up perfect with the grill and not uncenterd
killercl0wnfish is offline   Reply With Quote
Old 04-17-2013, 10:09 PM   #62
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Ill get you guys a sound clip in outdoors and in a home garage soon. I need to redo the spade connection, that grease is annoying and the spade slips out. Going to solder that b*tch together.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 05-28-2013, 10:52 AM   #63
awlllwa
awlllwa's Avatar
Totally forgot to update my post with a pic... Here ya go
Sent from my Galaxy Nexus using Tapatalk 4 Beta
The Following User Says Thank You to awlllwa For This Useful Post:
illicitstylz (07-10-2014)
Old 06-04-2013, 02:29 PM   #64
The Tengu
The Tengu's Avatar
Drives: 2013 Whiteout FR-S (MT)
I used this DIY to install my horns. No need to take the bumper off though. Just get it up on stands and access from under the front of the car. I used this horn instead:
[ame="http://www.amazon.com/PIAA-85115-Superior-Bass-Horn/dp/B0060ZB43G/ref=sr_1_3?ie=UTF8&qid=1370224201&sr=8-3&keywords=PIAA+horn"]Amazon.com: PIAA 85115 Superior Bass Horn: Automotive[/ame]
Thought I'd post this here so people could hear the difference a new horn makes on this car.
[ame]http://youtu.be/o86kRYWHOzQ[/ame]
Thanks again for the DIY!
The Tengu is offline   Reply With Quote
The Following 10 Users Say Thank You to The Tengu For This Useful Post:
DAEMANO (12-05-2014), illicitstylz (07-10-2014), Khyron686 (03-18-2014), Mooseknuckle44 (07-11-2014), nix (07-25-2013), Pat (12-06-2014), Splat (06-18-2013), toysub (07-10-2014), tracerit (06-09-2013), ts87 (12-02-2013)
Old 06-09-2013, 12:54 AM   #65
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I must be missing something here because my friend and I found a really easy way to do this. Note: This only works for people that don't care about "showing off" the horns.
For the low horn, plug the factory connector into the supertone and add a ground wire with a spade connector and ground to the factory mounting point. Done.
For the high horn, cut off the factory connector and add spade connectors to the ends of the power and ground. Loosen the factory horn bracket and flip it so the horn goes the other way (closer to drivers side). That's it.
One of the horns is still on display which I'm OK with but I painted the "grills" black for stealth factor anyways. In the end, the horns are in the stock location.
Only thing is...I could be wrong but I think the horn will no longer beep when pressing the lock button on the remote 3 times. Doesn't bother me
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following 3 Users Say Thank You to Laika For This Useful Post:
chas3wba0 (08-30-2016), DAEMANO (12-05-2014), GT86_PRAGUE (12-09-2014)
Old 06-18-2013, 12:50 AM   #66
thedude9009
Drives: Scion FR-S
I created an account to say thank you. This was a much easier install.
thedude9009 is offline   Reply With Quote
The Following User Says Thank You to thedude9009 For This Useful Post:
Laika (06-18-2013)
Old 06-30-2013, 04:17 AM   #67
Grey
Ghost
Grey's Avatar
Drives: FR-S (Whiteout)
Question: I mounted in the same location as most of the Hellas here, and I just noticed today after having them for a long time that they're not symmetrical vertically. As in, one is higher and one is lower. It's like my lower grille has a lazy eye.
Is that how anyone else's is? Is one bolt lower than the other?
Grey is offline   Reply With Quote
Old 06-30-2013, 10:14 AM   #68
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
My low pitch horn went out, it sounds like a bicycle horn now
Perihelion is offline   Reply With Quote
Old 07-03-2013, 02:05 PM   #69
Alfalasy
2013 BRZ
Alfalasy's Avatar
I'm having the same issue but I didn't try to fix it
Alfalasy is offline   Reply With Quote
Old 09-13-2013, 06:17 PM   #70
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
Here is mine. I left my stock horns in place, and tapped into the wire at the horn to trigger a relay to turn these horns on.
And I made my own brackets to get them where I wanted.
WRB-DZA-BRZ is offline   Reply With Quote
BRZ/FR-S Coilover Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 64 02-21-2020 06:30 PM
Hella Supertones. 636 Cosmetic Modification (Interior/Exterior/Lighting) 10 08-09-2012 01:16 AM
Suspension Installation Warning!!!! Don@Accelerated Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-20-2012 07:44 PM
TRD parts installation manual Nardi330 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 05-21-2012 04:19 AM
chrome fender trim installation taosracer Cosmetic Modification (Interior/Exterior/Lighting) 1 05-15-2012 04:13 PM
