Old 09-11-2013, 10:10 AM   #43
Minhtyfresh
Drives: Whiteout fR-S
Its damn early to be thinking winter, mate!
Anyway, fellow Ontarionian(?) here. I ended up getting Blizzak WS series tire, and some 16" steelies. These tires honestly saved my life on a trip down 401 when the snow was fresh and unplowed. If you're getting new rims though, then feel free to just use your stock wheels with your winter tire.
The window's definitely got stuck ALOT during the winter. Sometimes you'll find that you can't operate them properly anymore (lights flashing on the window switches) when they get stuck. You'll need to force the window to fully closed position to get them working again. It's freezing at the lower edge of the window that you should be worried about, not the top edge by the door seal!
As for rust proofing, I have no experience with the stuff... I would reccomend it for peace of mind. Me personally, I'm gambling that the factory protection is good enough, coupled with a good underbody wash every other week
Minhtyfresh is offline   Reply With Quote
Old 09-11-2013, 10:16 AM   #44
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by aghuman View Post
Reprogramming windows from dealer to stop the auto roll down/roll up when opening doors.
You can do this?
DylanFRS is offline   Reply With Quote
Old 09-11-2013, 10:44 AM   #45
frs10
Drives: tezla
Originally Posted by DylanFRS View Post
You can do this?
yes, its called disconnecting your battery
frs10 is offline   Reply With Quote
Old 09-11-2013, 01:47 PM   #46
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by NOHOME View Post
Sorry. You are wrong. Disabled mine and no issues. Other than no light when you open door.
Its a stupid feature for a car that is used in winter. Would not be as stupid if it defaulted to up rather than down position.
So you have been able to do this? Is there a link to the DIY or just a general step by step if it was easy? Or did the dealer do it for you? When the function was turned off did it default to the fully up position or the partially down position it goes to when the door opens?
aghuman is offline   Reply With Quote
Old 09-11-2013, 03:01 PM   #47
Dezoris
Dezoris's Avatar
If you are worried about longevity don't drive in winter. My car is by far one of the worst I have had owned i terms of rust after even one year. Thing is a total shit box. Going to try and avoid this winter because of it.
The Following User Says Thank You to Dezoris For This Useful Post:
ZionsWrath (09-11-2013)
Old 09-11-2013, 03:05 PM   #48
NOHOME
Drives: RAVEN
If you search the warranty section of the board you will find it. Goes back to last December or January if I recall.
You are pulling a single wire from the door latch and the window will stay up all the time. Downside is that you don't get an interior light when you open the door because the car does not know the door is open. That is a pain, but not as much as a car full of snow like I had.
Rumours are that a new switch has been introduced and come next winter I will tell the dealer that I am still having the issue and hope the part is more than vapourware.
found the disable "HOW TO" http://www.ft86club.com/forums/showt...ghlight=window
I can see where the logic would leave the window up if it refused to move down, but to have it stay down after it was already down? I miss the logic. Not like it was frozen in place or it would not have come down in the first place.
Cant say that me and the Remon (wifes nickname for the car) are looking forward to winter again.
As an aside, since we are in winterizing mode and all.
While I do not wash the car, I do make a point of taking it to Krown for the oil based undercoat every year. Proof of its effectiveness can be seen by the band of oil that creeps out of all the cars seams and up the panels; the doors and trunk panel have a 2-3" band of rust protector oil around the perimeter. So, while kind of messy, stuff seems to work as advertized.
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
aghuman (09-11-2013)
Old 09-11-2013, 03:05 PM   #49
ZionsWrath
Thanks
ZionsWrath's Avatar
more underbody rust pics plz
Old 09-11-2013, 03:11 PM   #50
Pbrown
Drives: 2013 Scion FRS Raven
Did you get it sprayed? (Krown) The reason I ask is mine has 0 rust.
Pbrown is offline   Reply With Quote
Old 09-11-2013, 03:11 PM   #51
ZionsWrath
Thanks
ZionsWrath's Avatar
pics
Old 09-11-2013, 03:51 PM   #52
frs10
Drives: tezla
all i see is a car with snow on it...??
Old 09-11-2013, 04:17 PM   #53
Minhtyfresh
What's going on with that driver side window?
Also: 1 winter, no rust protection, no rust so far on my car.
Old 09-11-2013, 04:23 PM   #54
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
What parts are rusting? Don't we have a lot of Aluminum on our body?
Books is offline   Reply With Quote
Old 09-11-2013, 05:06 PM   #55
Dezoris
Dezoris's Avatar
Salt = corrosion rust.
I have been under my car about 100 times with it on the lift probably twice that. Taken more things apart than probably most, thats how I find it when things don't come apart.
I have plenty of under body rust. Some surface some like my suspension frames and arms already lost coating and with rust bubbles and parts eaten away. Here is the sway bar sub frame cancer already started.
I am not saying the car is rusting apart its just worse than my past cars. I don't see it holding up well long term in my application, my area.
Really don't want to get into another debate about something else.
Books (09-12-2013)
Old 09-11-2013, 05:14 PM   #56
Taro
You call him Dr. Jones!
Taro's Avatar
Drives: 2013 Twin Mish-Mash
Glad I got the rest protection now.
Taro is offline   Reply With Quote
Subaru BRZ New Car Prep TimAD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-16-2013 03:00 AM
First Trackday Prep solidONE Tracking / Autocross / HPDE / Drifting 40 03-23-2013 11:54 AM
Detailer's Domain: Subaru STI - Winter Prep - Auto Finesse Tough Coat DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 12-01-2012 11:04 AM
XSXV: BRZ Re-New Car Prep goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 10-16-2012 12:57 PM
FR-S New Car Prep by Hamza7 Hamza7 Cleaning and Detailing 30 06-12-2012 12:26 PM
