#183 |
Drives: really slow...
Going back to my dilemma... I love the stock suspension dynamics but I want to look cool and lower my car.
Evidently adjusting the lower shock mounting point like this can effectively lower the rear end 20mm at the shock and 25mm at the wheels. This will allow me to achieve my desired ride height while using the stock suspension system. Sounds rather brilliant. What am I missing? How about the front? I hate mixing and matching but not sure how best to go about thinking thru a setup like this. Help Mike and Andrew! (I'm thinking maybe... mild lowering springs in the front coupled with the stock shock to give me a spring rate of 250lb and a drop of 20mm out front... and a stock FRS spring rate in the rear on the stock shock to get to a close-enough balance as possible) Last edited by RYU; 09-05-2013 at 01:41 PM. |
#184 | |
Drives: FR-S Whiteout
Correct me if I wrong, cause I'm trying to understand how offset can have 0 effect on a strut suspension. If that were true then I can run +48 offset and still have the same rate to the tires as if I had -48mm offset. Last edited by solidONE; 09-05-2013 at 01:48 PM. |
#185 |
Vtec Jesus
I like this thread.
#186 | |
You might want to look into roll-center correction as well, to compensate for the sluggishness you introduce into response by dropping the car without correcting it. Disclaimer: The CSG BRZ doesn't have roll-center correction (yet). Our spring rates are high enough that the sluggishness is more than offset, but we do plan on eventually adding adjustble RCAs to maximize the effectiveness of our suspension. |
#187 | |
Using this type of setup and assuming the use of the stock shock, as long as there are no clearance issues (i.e. lower spring perch hits something) then I can't see why the spring would be any more compressed than normal? Agree with the roll-center issue. |
#188 | |
#189 | |
So assuming using the stock FRS (I have a BRZ cuz it's the best! ) rear spring rate on the FRS rear damper... What do I do about lowering the front? hmmmm.. |
#190 |
Ground control top mounts?
#191 |
just took a quick peek at those. thanks for the suggestion. it seems they do not raise the spring height; just raises/increases the stroke. I might still end up with a spring problem.
thinking out of the box a little.. what if I use a stock BRZ front shock. use a conservative lower spring like the RCE yellow. This will get me the 20-25mm drop out front with the stock damper rate. (I never really had a problem with the front dampers. It's the rears that are just so short.) With this combo maybe I can tune the understeer with a stiffer rear sway bar. Oh man... What a pain. I really need to ride on your latest Tein SRCs. |
#192 | |
![]() OT: waiting for adapters to arrive... (grr). You'll get a ride soon enough. Coming to the track 9/14-15 or 9/28-29? |
#193 | |
Kuruma Otaku
Offset affects track width and roll resistance, I believe.
Because titanium. |
#194 | |
I'm picturing a longer lever on the spring as a result of positive offset vs. negative offset, therefore requiring less force (but longer distance of travel) to compress the spring which stays in the same position relative to the inner pivot. Edit: I'm just going to leave this link here for @Dimman , @Wepeel and @ZDan. According to this guy that created the PDF file linked, motion ratio on a mac stut system is dependent on the centerline location of the wheel, thus wheel offset. [backs away slowly]
#195 | |
OT Reply: awesome! I'm waiting to receive my final version for the NSX. As soon as I get it i'll join you out there on whichever day. |
#196 | |
That Guy
Drives: 2013 asphalt FRS MT
Also you might want to look into the robispec rear mounts. And finally Koni's might be worth looking into. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
