Old 09-03-2013, 10:06 PM   #127
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
...and then.
Update with some pics....
http://www.ft86club.com/forums/showp...postcount=1070
Old 09-04-2013, 12:24 AM   #128
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
What engine oil should i be running now that im boosted?
brz2013 is offline   Reply With Quote
Old 09-04-2013, 09:07 AM   #129
Sportsguy83
Drives: Limited BRZ
I'm running 0w-30. YMMV. It gets complicated if you try to find the perfect oil, it doesnt exist.
Read here and don't overthink it.
http://www.ft86club.com/forums/showthread.php?t=44900
Old 09-04-2013, 12:04 PM   #130
AVOturboworld
I've done some experimentation with different oils, from motul to mobil 1 to Driven. Also did different weights, from the OEM 0w20 to Motul 10w40, all full synthetic. Currently doing testing on the Driven 0w20 and 5w20 full synthetic race oils with high zinc. I've put about 3000 miles on the Driven, and the oil in the car is still rather clean. In comparison, the OEM 0w20 was black and loose after about 3000 miles.
I've gone back and forth a bit on what exact weight to run, but right now I'm swinging back towards running a 0w20 or 5w20 for street use. If you are going to be tracking it extensively, or are in extreme heat conditions, heavier weight oil is certainly viable - or just do shorter oil change intervals.
Old 09-04-2013, 12:47 PM   #131
ftc~brz
Done
Drives: WRB BRZ
drove a relatively stock brz today after being boosted for a week......good god it felt slow!!
tell me about it…. This wait is painful
ftc~brz is offline   Reply With Quote
Old 09-05-2013, 11:53 PM   #132
Sportsguy83
Drives: Limited BRZ
Robispec total cooling solution install review on my car is up starting with this post!!
http://www.ft86club.com/forums/showp...postcount=1102
Old 09-06-2013, 01:26 AM   #133
DAMotorsports
Drives: 2013 Scion FRS "Raven"
@sportyguy83 thanks for keeping things real in your review. It help the rest of us have some guidance.
DAMotorsports is offline   Reply With Quote
Old 09-06-2013, 02:00 AM   #134
nix
nix's Avatar
Drives: AVO BRZ
I heard a lot of reports of cavitation based bearing damage from running overweight oils on Fb20s over the past couple years so we decided on the eneos sustina 0w20. My car sees heavy combined street & track use with peak oil temp with a cooler of ~120c.
nix is offline   Reply With Quote
Old 09-07-2013, 05:03 PM   #135
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Avo kit
Cat less front pipe, catback, dw 700 injectors, 3 bar map
Tuned by ptuning, manassas VA
93 pump, Max boost of 10.5, dropped to 8.5 5500 to redline (need higher wastegate actuator)
Old 09-07-2013, 05:09 PM   #136
M1K3
M1K3's Avatar
Drives: vrooom...
Originally Posted by spitfire481 View Post
Avo kit
Hey spitfire, you running stock Fuel pump?
M1K3 is offline   Reply With Quote
Old 09-07-2013, 05:21 PM   #137
spitfire481
Drives: 2JZ FRS
Yes. Was told there was no need at my boost level on 93 pump by the tuner. Just map and injectors
Old 09-07-2013, 05:24 PM   #138
M1K3
M1K3's Avatar
Drives: vrooom...
Awesome! That's nice to know.
Old 09-07-2013, 06:04 PM   #139
FRSRAVEN
Avo kit
Could you elaborate on this please? If the Wastegate was too small, wouldn't boost creep upwards at higher RPM? If you are loosing boost, could it be due to a boost leak, or possibly the turbo running out of flow?
FRSRAVEN is offline   Reply With Quote
Old 09-07-2013, 06:21 PM   #140
spitfire481
Drives: 2JZ FRS
The 5psi internal wastegate actuator has so weak of a spring, exahaust manifold pressure at higher rpm is enough to force the flap to creep open and bleed off exhaust pressure pre turbine. A overall stiffer wastegate actuator spring will help keep it from creeping open
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
