#43 |
Not trying to be a ****
Drives: BRZ - 6MT - GBS
nominate this for DIY directory.
@WingsofWar ?
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
| The Following User Says Thank You to EvilBeaverFace For This Useful Post: | WingsofWar (08-31-2013) |
#45 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#46 |
Drives: Scion FR-S 2013 Raven
DIY - Whiteline Rear Crossmember Mount Insert Bushings
o= FR-S =o Last edited by Mikepage; 03-16-2014 at 01:44 PM. |
#47 |
FR-S Owner!
Drives: 2013 FR-S Ultramarine 6AT
After staring at the bag of bushings I bought for months I finally got to install them today. This guide was immensely helpful. Thanks!!!
| The Following User Says Thank You to Moshpit37 For This Useful Post: | Mikepage (07-02-2014) |
#48 | |
Do you love the new feeling?
o= FR-S =o |
#49 |
FR-S Owner!
I'm stuck on an Air Base for a couple more hours (Speed limit 30)... I'll let you know once I have a chance to really drive it.
#50 | |
Then who do you love the ride now?
o= FR-S =o Last edited by Mikepage; 09-15-2014 at 11:36 AM. |
#51 |
Just did this install tonight.
I also had strange salt water build up on the passenger side front bolt. I live in California so the car's never seen an ounce of road salt. Weird. Got my car December 2012. I really appreciate the walk through, it was very helpful, particularly with the vague directions from Whiteline. Only problem I had was threading the rear bolts in, but adjusting my jack a bit up and down took care of that. Thanks! |
| The Following User Says Thank You to YouShallKnow For This Useful Post: | Mikepage (02-17-2015) |
#52 | |
Am sure you will love the new feeling and yes rear subframes bolts are tricky...
o= FR-S =o |
#53 |
Señor Member
Drives: BRZ SWP
so does this guide differ when lifting the car up with the wheels off the ground?
#54 |
Drives: 13' Scion FRS Track car
thanks for the post, it was very helpful making it is less scary
![]() It is actually quite simple. One important thing though, because of my Tarmac2 suspension I actually had to remove the lower strut bolt, if not the subframe was not coming down more than a 1/4 inch. The suspension strut keep the assembly pushed up. Once I removed the lower strut bolt, I was able to lower everything easily. Also I had to unscrew all bolts a little: rear subframe, front rear submarine and also differential bolt, if not everything was to tight and even without any jack support and with the two most rear screw removed, the subframe would only drop a 1/4 inch. I suppose my bushing were all in super tight shape ![]() Car is only 12,000 miles. anyways, very easy to install after all. I only wish whittling included more grease, one pack was really the strict minimum ! ideally use your own grease and put as much as you need to.
2013 Scion Frs Track Car - Sold.
#55 |
Drives: 14 BRZ Red premium
Do you need an alighment after installing the insert ?
Ive noticed the hole for the bushing is not round is oval. I when i was reinstall the bolt back in, i have to push the the subfram a bit to get the hole to light up before bolting back the back in. So this might have shifted the subframe a bit. or is this too minuscule to throw the alighment off ? |
#56 |
Drives: Hyper Blue BRZ
extra grease in case anyone is interested
http://www.ebay.com/itm/171386890790 |
| Tags |
| bushing, crossmember, diy, whiteline |
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| Installed the Whiteline crossmember bushing(no pics sorry) | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-26-2013 02:00 PM |
| ++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ | genometuning | Transmission and Driveline | 4 | 10-12-2012 09:23 PM |
