Old 08-09-2013, 01:28 PM   #1
BlackyRose
Drives: 2013 Raven FR-S
Door speaker mounting bracket help
I somehow found a company that was manufacturing speaker conversion mounting plates for 6.5 door speakers. The opening is too big to plug and play so they designed a bracket that allowed us to buy a regular over the counter speaker and mount in on their bracket and then mount into the door.
Cant seem to find the product or company.
Can someone help with this?
EDIT: http://www.subaruaudio.net/subaru-sp...nd-scion-fr-s/
Can someone confirm that they are still selling these and that they work as advertised?
Also, can someone reccomend a decent 6.5 that would mate nicely with the factory head unit, a plug and play speaker that will match the wiring and amp. I think we have 2 ohm right?
[ame="http://www.amazon.com/Infinity-Reference-6032cf-6-5-Inch-High-Performance/dp/B002BZFSYA/ref=sr_1_3?ie=UTF8&qid=1376065914&sr=8-3&keywords=6.5+2+ohm"]Amazon.com: Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance 2-Way Speakers (Pair): Car Electronics[/ame]
BlackyRose is offline   Reply With Quote
The Following User Says Thank You to BlackyRose For This Useful Post:
PatrickSAN (08-27-2013)
Old 08-09-2013, 01:35 PM   #2
infinite012
Drives: 13 DGM BRZ Ltd
That guy is a member on NASIOC. I think his sn is something like phenryv1 or something?
Anyways, shoot him an email/PM and ask him if he is selling them.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
BlackyRose (08-09-2013)
Old 08-09-2013, 01:40 PM   #3
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
If you're going to keep using the stock door speaker amp then yes you will need a 2ohm speaker.
That limits you to pretty much either JBL or Infinity (both made by H/K) for mainstream speakers. Not sure about smaller niche manufacturers.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
Old 08-09-2013, 03:17 PM   #4
BlackyRose
Ok cool, probably go with Infinity, still not sure but thanks for the info regarding the 2ohm speakers brands.
Old 08-27-2013, 04:31 PM   #5
PatrickSAN
Drives: SWP GR 5DR
Subscribed.
PatrickSAN is offline   Reply With Quote
Old 08-27-2013, 05:01 PM   #6
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
A 4 ohm speaker with a high sensitivity will sound cleaner and still be just as loud.
supramkivtt2jz is offline   Reply With Quote
Old 08-27-2013, 05:15 PM   #7
mid_life_crisis
Drives: FR-S 10 #103 AT
It is okay to use a 4 ohm speaker with an amp that is rated for use down to 2 ohms. You just don't use the amp to its full advantage.
The reverse is not so true. You can burn out an amp by making it push more current than it is designed for.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
FRS door speaker vibration? hislargeness Electronics | Audio | NAV | Infotainment 12 08-19-2013 06:22 PM
Door speaker mounting bracket help BlackyRose Electronics | Audio | NAV | Infotainment 0 08-09-2013 01:27 PM
Door speaker question BlackyRose Electronics | Audio | NAV | Infotainment 2 07-26-2013 11:45 PM
rear license plate mounting bracket fiveoneoh Cosmetic Modification (Interior/Exterior/Lighting) 10 03-24-2013 10:35 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 08:25 AM
