#183 | |
Camber won't affect feel as much as tire itself and toe. A hint of toe-in front/rear will add stability, but isn't ideal for raw grip. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | kiichiro (08-21-2013) |
#184 |
Hi Mike, there's an open track event at Willow Springs next month and I was planning on going to this. After reading the first thread, I'm a little concerned with 1) brakes and 2) tune.
Do you recommend I hold off on track days altogether until I can purchase the above items? You mentioned there stock tune "destroys injection collars" is it really that bad? Was hoping to just try to get some seat time as I've been really itching for a track day but I can't afford any costly mods (>$200) for a few months. I could probably swing a cheap-ish set of brakes but a tune would be a little out of my price range for now. Thanks |
#185 | |
I would highly recommend you get a set of pads to swap on just for the track day. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Sonolin (08-21-2013) |
#186 | |
Does a tune prevent the long term damage? Or is this something that Toyota needs to fix?? Also, does it throw a CEL? After reading more I'm getting more and more concerned about this DI failure. |
#187 | |
Ideally, Toyota/Subaru/Scion need to fix it. There is no CEL when you get the DI seal failure, only symptoms. E.g.: [ame="http://www.youtube.com/watch?v=450Pov98STg"]BRZ bad idle + misfire, no CEL, stock engine - YouTube[/ame] |
#188 | |
#189 |
Drives: WR blue
What's the best wheels /tires set up for stock brz for track used? 255/40/17 or may be 235/40/18?(will use coilover later)
#190 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
Flashing cel under wot is caused by what?
#191 |
Drives: Scion FR-S
#192 |
Drives: RV-7
Mike, I read every post but still aren't sure. Are the newer (post 02/13 production I think) ECU cars still having DI issues?
Also, about trail braking. Every HPDE instructor I've had including two this year says to complete all braking in a straight line before corner entry. Maybe it's a CYA thing so they don't need to explain why I spun trail braking when I tried it solo. But really, what's to be gained trail braking? Is it a speed advantage or ability to rotate? How long should braking be carried into the corner? When should it be avoided (like an off-camber corner or rain)?. Isn't slow in fast out the safer, more predictable, repeatable way to lower lap times? |
#193 |
Drives: WR blue
#194 |
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
Spring Rates - Noob Question:
Some springs are rated at 8k, 10k, 14k, etc. Others are rated at Lbs/in (ie -RCE Yellows) What gives? How does one convert to the other? |
#195 | |
Drives: Nissan Versa
http://www.hraefn.net/projects/spring_rates.php |
#196 | |
Drives: '23 BRZ
It is much much easier to gradually trade braking for cornering than to get totally off the brakes and then try to turn in. The car just wants to push. Very awkward, very unnecessary. Trail braking is NOT an "advanced technique"! As an instructor, I often have to reteach beginning drivers to get them over the brainwashing they've received about how to enter a corner. At a ZCar convention a few years back, I was asked to go out on the autoX course with a friend's wife who was having a hard time. At the very first corner, which she entered just fine, she apologized for not "braking in a straight line"! I told her she was doing fine, not to worry about it. I did practically nothing else, and she was 2 seconds faster and had a helluva lot more fun driving the course, vs. being forced to "brake only in a straight line" which her previous two instructors had totally insisted on. Trail-braking is faster because it is smoother, and it makes it infinitely easier to hit the apex as it takes advantage of the front grip you get from increased load on the fronts under braking, and of course it also allows you to carry more speed a bit deeper into the braking zone. That's not to say that braking deeper is always better or faster overall, you can go too far. But if you aren't trail-braking some amount at corner entry, you're doing it wrong. You pretty much *have* to trail-brake to execute a proper line into most corners. This business about getting completely off the brakes before turning in is stupid, makes the car much more difficult to drive, and is totally unnecessary. I expect my students to be trail-braking pretty much immediately. It's easier, feels more natural, and is faster. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
