go_a_way1
Old 08-21-2013, 04:48 PM   #183
CSG Mike
CSG Mike's Avatar
Originally Posted by kiichiro View Post
Is it a full on track animal or do you street it like that? I'm seeking something between the two I think. How does that much camber feel in straight line at high speed like over hundred?
The car is mixed duty; it has 26k miles on it!
Camber won't affect feel as much as tire itself and toe. A hint of toe-in front/rear will add stability, but isn't ideal for raw grip.
kiichiro (08-21-2013)
Old 08-21-2013, 05:32 PM   #184
Sonolin
Hi Mike, there's an open track event at Willow Springs next month and I was planning on going to this. After reading the first thread, I'm a little concerned with 1) brakes and 2) tune.
Do you recommend I hold off on track days altogether until I can purchase the above items? You mentioned there stock tune "destroys injection collars" is it really that bad?
Was hoping to just try to get some seat time as I've been really itching for a track day but I can't afford any costly mods (>$200) for a few months. I could probably swing a cheap-ish set of brakes but a tune would be a little out of my price range for now.
Thanks
Sonolin is offline   Reply With Quote
Old 08-21-2013, 05:47 PM   #185
CSG Mike
CSG Mike's Avatar
Thanks
If you're not very experienced, you'll *probably* be okay, but it does eventually cause damage over the long term.
I would highly recommend you get a set of pads to swap on just for the track day.
Sonolin (08-21-2013)
Old 08-21-2013, 05:59 PM   #186
Sonolin
OK thanks for the info.
Does a tune prevent the long term damage? Or is this something that Toyota needs to fix?? Also, does it throw a CEL?
After reading more I'm getting more and more concerned about this DI failure.
Old 08-21-2013, 06:07 PM   #187
CSG Mike
CSG Mike's Avatar
Correcting the transient timing table prevents the long term damage, and that correction is currently included in ANY tune that begins with a recent base map released by Ecutek.
Ideally, Toyota/Subaru/Scion need to fix it.
There is no CEL when you get the DI seal failure, only symptoms.
E.g.:
[ame="http://www.youtube.com/watch?v=450Pov98STg"]BRZ bad idle + misfire, no CEL, stock engine - YouTube[/ame]
Old 08-21-2013, 06:57 PM   #188
Sonolin
E.g.:
Scary, thank you for the info. Happy to hear a tune will fix.
Old 09-14-2013, 10:57 AM   #189
BRZ NA
Drives: WR blue
What's the best wheels /tires set up for stock brz for track used? 255/40/17 or may be 235/40/18?(will use coilover later)
BRZ NA is offline   Reply With Quote
Old 09-14-2013, 11:12 AM   #190
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Flashing cel under wot is caused by what?
448hpsti is offline   Reply With Quote
Old 09-14-2013, 01:14 PM   #191
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
This happened in my legacy and it was from overheating.
Old 09-14-2013, 01:21 PM   #192
torqdork
torqdork's Avatar
Drives: RV-7
Mike, I read every post but still aren't sure. Are the newer (post 02/13 production I think) ECU cars still having DI issues?
Also, about trail braking. Every HPDE instructor I've had including two this year says to complete all braking in a straight line before corner entry. Maybe it's a CYA thing so they don't need to explain why I spun trail braking when I tried it solo. But really, what's to be gained trail braking? Is it a speed advantage or ability to rotate? How long should braking be carried into the corner? When should it be avoided (like an off-camber corner or rain)?. Isn't slow in fast out the safer, more predictable, repeatable way to lower lap times?
torqdork is offline   Reply With Quote
Old 09-14-2013, 01:52 PM   #193
BRZ NA
Drives: WR blue
Originally Posted by track_warrior View Post
Yeah you can definitely hear it in my car if you pay attention in the video:
Doesn't seems like u get understeer due to the big wing at the back?
Old 10-04-2013, 12:27 AM   #194
Pabloc
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
Spring Rates - Noob Question:
Some springs are rated at 8k, 10k, 14k, etc.
Others are rated at Lbs/in (ie -RCE Yellows)
What gives?
How does one convert to the other?
Pabloc is offline   Reply With Quote
Old 10-04-2013, 12:40 AM   #195
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
What gives?
Use this:
http://www.hraefn.net/projects/spring_rates.php
KKaWing is offline   Reply With Quote
Old 10-04-2013, 08:50 AM   #196
ZDan
ZDan's Avatar
Drives: '23 BRZ
It is almost impossible to drive a car anywhere near its limits "braking only in a straight line". This type of advice or instruction is totally counterproductive and slows down the learning process. As a newb driver years ago, I didn't get anywhere my first track day until I quit trying to "brake only in a straight line".
It is much much easier to gradually trade braking for cornering than to get totally off the brakes and then try to turn in. The car just wants to push. Very awkward, very unnecessary.
Trail braking is NOT an "advanced technique"! As an instructor, I often have to reteach beginning drivers to get them over the brainwashing they've received about how to enter a corner.
At a ZCar convention a few years back, I was asked to go out on the autoX course with a friend's wife who was having a hard time. At the very first corner, which she entered just fine, she apologized for not "braking in a straight line"! I told her she was doing fine, not to worry about it. I did practically nothing else, and she was 2 seconds faster and had a helluva lot more fun driving the course, vs. being forced to "brake only in a straight line" which her previous two instructors had totally insisted on.
Trail-braking is faster because it is smoother, and it makes it infinitely easier to hit the apex as it takes advantage of the front grip you get from increased load on the fronts under braking, and of course it also allows you to carry more speed a bit deeper into the braking zone.
That's not to say that braking deeper is always better or faster overall, you can go too far. But if you aren't trail-braking some amount at corner entry, you're doing it wrong. You pretty much *have* to trail-brake to execute a proper line into most corners. This business about getting completely off the brakes before turning in is stupid, makes the car much more difficult to drive, and is totally unnecessary. I expect my students to be trail-braking pretty much immediately. It's easier, feels more natural, and is faster.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
amram (03-28-2014), autobrz (10-04-2013), torqdork (10-04-2013)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
