Old 08-20-2013, 08:37 PM   #1
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
My Smartphone Mount Solution
Not the prettiest, but it works. I don't like anything on the top of the dash or on the windshield, and the CD-slot mount would block part of the headunit screen.
Yes, I do have nav, but I use my phone in the car for Waze, a navigation app that shows accidents, real time traffic and most important, user-reported police activity, so I need it where I can easily see it.
TheseColorsDontRun is offline   Reply With Quote
The Following User Says Thank You to TheseColorsDontRun For This Useful Post:
Hanakuso (08-21-2013)
Old 08-20-2013, 08:44 PM   #2
FRS1010
Drives: 2013 FRS
Looks good. I will have to check out that app. Thanks!
FRS1010 is offline   Reply With Quote
Old 08-20-2013, 08:46 PM   #3
zoomzoomers
zoomzoomers's Avatar
Waze is an awesome app and now that Google has bought Waze, you can get all the Waze info on Google maps too and vice versa with Waze.
The Following User Says Thank You to zoomzoomers For This Useful Post:
Old 08-20-2013, 09:08 PM   #4
rba
Drives: Whiteout FR-S
Are you running the cable under the carpet? If you are, would you mind posting a picture with the door open?
rba is offline   Reply With Quote
Old 08-20-2013, 09:31 PM   #5
TheseColorsDontRun
It's really not complicated. It's a 10' iPhone extension in red (because racecar). I ran it down the side of the tunnel, under the carpet then up against the wall near the dead pedal, tucked it between the dash and the body and up to it's current location. I have an Exomount, though I'm not sure I will stick with it. I haven't driven with this setup, I need to see if the phone will vibrate out of the claw. I'm thinking I'm going to try and find a mount similar to what I had in my old car, a Bracketron (supports the bottom of the unit). Problem is, I need to find a female version that takes the ball (hehe) of the Exomount. Everything that I have seen from Bracketron and similar products is a male, made for a female mount.
Old 08-20-2013, 10:02 PM   #6
rba
I have a RAM mount and it is unbelievably good. It doesn't rattle at all.
Old 08-21-2013, 09:59 AM   #7
mid_life_crisis
Drives: FR-S 10 #103 AT
...and here I was thinking it was to match the stitching.
Seriously though, I never would have thought of sticking the thing on the door.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-21-2013, 11:00 AM   #8
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
My flux2 is on that door panel so im stuck with my phone sitting in the cup holder
I went out and bought a Pioneer HU with that AppRadio function so I could have my phone displayed on the HU.... What an F***ing gimick that is guys. Slow, glitchy and you cant do anything even close to multitask. PLus you need to be friggin stopped to do anything...
RandomHero is offline   Reply With Quote
Old 08-21-2013, 11:09 AM   #9
TheseColorsDontRun
As Waze gets bigger I bet it will find its way into cars from the manufacturer, similar to Pandora. At least that's my hope, then I'll have no need for mounting the phone anywhere.
Old 08-21-2013, 11:31 AM   #10
Zippy
Drives: 2013 Subaru BRZ WRB AT
Take a look at the Pioneer head units that feature app radio. They can pass waze through to the the display of the head unit. All touch features work. And you can put your iPhone anywhere at that point.
Zippy is offline   Reply With Quote
Old 08-21-2013, 12:25 PM   #11
bggns
Drives: 2013 Scion FR-S 6AT, Asphalt
Isn't there an airbag in the A pillar?
bggns is offline   Reply With Quote
Old 08-21-2013, 04:44 PM   #12
Hanakuso
This is true. I have the X mount and it looks flimsy but its actually very good.
Thanks for the waze app recommendation. I just downloaded it and it looks great.
Hanakuso is offline   Reply With Quote
Where/How do you mount your smartphone? Mpowered Electronics | Audio | NAV | Infotainment 53 06-07-2015 07:20 AM
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Audio/Visual, Electronics, Infotainment, NAV 23 04-18-2015 09:43 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 02:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 11:58 AM
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Tracking / Autocross / HPDE / Drifting 4 04-30-2013 01:09 AM
