Old 08-20-2013, 04:14 AM   #1
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
koni inserts vs budget coil overs
Anyone with experience chime in.
Koni's with springs end up being more money than say kw1 or the st's.
Application: DD with autoX duty.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 08-20-2013, 11:35 AM   #2
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
You could look at Ground Control coilovers, they have options that range from basic koni shocks & springs on oem mounts and all the way to camber plates and Al mounts.
KKaWing is offline   Reply With Quote
Old 08-20-2013, 12:17 PM   #3
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Lets say I don't want a coil over, aside from the GC most basic setup, is there anything else to consider if I don't want to cut to install the Koni? Thanks to who ever can add options. The GC is nice for sure just looking at all, if any, other options.
kiichiro is offline   Reply With Quote
Old 08-20-2013, 12:19 PM   #4
KKaWing
KKaWing's Avatar
You could do RCE Yellows (maybe sways later on if you need to tweak it a bit more) and call it a day. They are set so that they match the stock shocks (really, the dudes there dyno'd the stock shocks and set the rates based on that, not guessing).
Old 08-20-2013, 12:39 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It seems that good springs and dampers is better than cheap coilovers.
Rayme is offline   Reply With Quote
Old 08-20-2013, 12:44 PM   #6
KKaWing
KKaWing's Avatar
You could consider Fortune Auto Coils, they do dyno them before sending it out (they should come with dyno sheets, and they should have a record of it as well).
You do get what you pay for, Koni having to cut unless you get Ground Control to build it for you and cheap coilovers being mismatched. The damper's performance aside, having them match is pretty important.
Old 08-20-2013, 12:45 PM   #7
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
All depends on if you want to be able to adjust the height. If you can find springs that lower you exactly where you want, get them. If not, buy a entry set of coilovers.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 08-20-2013, 12:53 PM   #8
vividracing
vividracing's Avatar
What do you want out of it. If you are budget minded and want good performance I would say shocks and springs. If you are gonna buy some coilovers don't go cheapo. Invest in a good set. It is an FRS/BRZ...
vividracing is offline   Reply With Quote
Old 08-20-2013, 12:55 PM   #9
KKaWing
KKaWing's Avatar
Oh right, there's the RCE Tarmac springs and you can match them with the fixed perch Bilsteins that are gonna be released in 6 months-ish. "Emphasis on the ISH" <<< qoute from RCE.
The Following 2 Users Say Thank You to KKaWing For This Useful Post:
kiichiro (08-21-2013), Racecomp Engineering (08-20-2013)
Old 08-20-2013, 01:40 PM   #10
mla163
Overthinking it
Drives: BRZ in CS
You get what you pay for. Cheap coilovers are made to a price point. Good dampers are made right, then priced.
Konis and springs are going to be more comfortable and probably faster on an autocross course than cheap coilovers.
mla163 is offline   Reply With Quote
Old 08-20-2013, 02:36 PM   #11
86_FRS
Drives: 2013 Asphalt FRS
Can you confirm this?
86_FRS is offline   Reply With Quote
Old 08-20-2013, 03:19 PM   #12
mike the snake
Even lower cost coilovers can be good IF they're properly valved and matched to the springs and the car.
KW is a known quality brand, and their V1 coilovers I think are accepted as good quality, and the ST coilovers are made by KW and are the same as the KW V1's and are VERY affordable.
Old 08-20-2013, 03:25 PM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
Just think, how can a low cost unit compare to a good higher priced one unless they stole the R and D? The difference in price is because of the time spent developing not the material costs. Look at OEM accessories, price gouging aside, they have to pay their employees to develop these parts and even thought they might be outperformed by cheaper aftermarket alternatives, they have to price it appropriate to the money they spent on development.
Case in point, our cars. Beat around tracks by many other same price or cheaper cars but you bought it didn't you?
Old 08-21-2013, 02:32 PM   #14
bakerr6
Drives: 2013 raven black fr-s
That makes no sense at all. The majority of the cost of different pieces has to do with 5 things:
1.) Brand - some brands cost more
2.) Process - The way an item is made can increase costs
3.) Materials - The better the material, usually the higher the cost
4.) Scale - How many people are going to be buying the product
5.) Supply/demand - always cause changes in price
One case in point, if you were to buy a set of wheels such as BBS wheels that are forged or varrosteins (not sure if that's how you spell it), the BBS wheels are much more expensive, but essentially for all the reasons above.
bakerr6 is offline   Reply With Quote
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
AutoX coil-overs what should i get? subaruferrucci Tracking / Autocross / HPDE / Drifting 4 02-19-2013 04:03 PM
Coil-overs \ Spring kit ????? v3rgil AFRICA 9 11-16-2012 09:27 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 10:12 PM
