Old 08-15-2013, 12:49 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Springs? What wheels/tires, do you rub?
I'm interested in a mild drop at some point. I was thinking to go STi pinks for simplicity.
Please post what springs you are running, what wheel and tire size. Also camber if you know. And of course do you rub?
Old 08-15-2013, 12:52 PM   #2
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Where did u get those STI pink from? I am interested.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 08-15-2013, 12:56 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I didn't but japan parts has them
Old 08-15-2013, 01:42 PM   #4
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
The STI pinks are mystery spring rates. I know STI makes them and they are probably fine, I really don't like the idea of going with springs without knowing the rates on them. It makes it harder to plan additional mods, unless you're just going to guess and call it good. I would recommend RCE, Swift, or Eibach before the VERY expensive STI Pinks. Maybe if they were similarly priced I would be more interested...
Now as far as rub... I'm running a fairly large wheel and tire setup. 18x8.5" +45 offset enkei raijins for the front and 18x9.5" +45 for the rear. I am running Kumho Ecsta LE Sport wheels in 245/35/18 for the front and 255/35/18 in the rear. My springs are RCE Yellows. They handle great and were very easy to install. I've taken them to a few autocrosses and many back road runs, and RCE knows their suspensions.
The wheels are almost perfectly flush, if that concerns you. I would personally go with a +40 offset in the rear if I were you. I had rubbing issues in the front with just crash bolt at -.09 deg of camber. To fix this, I installed the whiteline com-c top hats to give some additional camber and more clearance up front. This worked quite well and I am now at -1.2 up front with more than enough room to avoid rubbing. In the rear, I have had issue under VERY high g cornering with the parking brake guards rubbing. This only happens during certain curves in autocross, but it will be fixed soon. There is plenty of room to bend the brackets out of the way from what I can see. My rear camber settings are about -1.3 and have a slight toe-in set.
Hope that helps.
console_cowboy is offline   Reply With Quote
Old 08-16-2013, 08:09 AM   #5
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Eibach sportlines. Stock struts n shocks for now. 18x8 in the front 18x9 in the rears. Nitto 265/35 18 in the rear. Flush
sosick is offline   Reply With Quote
Old 08-17-2013, 07:03 PM   #6
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Any pictures of this?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 10:26 AM
Wheels or Springs? ChandlerSwyng Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-26-2013 10:32 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 03:21 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 01:42 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 11:26 PM
