Old 08-12-2013, 10:05 PM   #1
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
toe links needed with lca?
Got swift springs with 1" drop and I ended up with -2.6/-2.7 degrees of rear camber after my spring install. I want to get back to stock -1.2-1.5. Will a LCA get me there or do I need to get toe links too?
Any recommendations for either?
garfull is offline   Reply With Quote
Old 08-12-2013, 10:38 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Lca will get you the camber correction by reducing length of the arm. If the toe link at the most inward position is greater than 0* toe, then you would need toe links to get alignment or you would have toe out in the rear.
Wouldn't hurt to get both at the same time for an alignment.
Sent from my SCH-I535 using Tapatalk 4
JDKane527 is offline   Reply With Quote
Old 08-13-2013, 04:16 AM   #3
OrbitalEllipses
Drives: Attitude
I could not get less than ~1.5 camber in the rear without messing up toe, even with offset toe bushings. You may as well buy toe links, unless you wanna gamble.
Old 08-13-2013, 04:22 AM   #4
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
How far did you lower?
Turkish is offline   Reply With Quote
Old 08-13-2013, 05:13 PM   #5
garfull
garfull's Avatar
I got swift springs which are 1" drops.
The Following User Says Thank You to garfull For This Useful Post:
Turkish (08-13-2013)
Old 08-16-2013, 01:34 PM   #6
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
a friend of mine ran LCAs and got UP TO* -5 degrees of camber without needing aftermarket toe links. That being said im sure the OEM toe adjustment range can handle going from -2.6 to -1.5
Goodluck
SLICVIC is offline   Reply With Quote
The Following User Says Thank You to SLICVIC For This Useful Post:
garfull (08-17-2013)
Old 08-16-2013, 02:42 PM   #7
empower-auto
Kouki-Monster
empower-auto's Avatar
at -1 camber in the rear with a pretty good drop I do not have proper toe adjustment on factory bits. you should definitely get new links
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Old 08-16-2013, 06:37 PM   #8
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
I also have swift springs and I did the SPC control arms which resulted in ~-1 camber without needing the toe kit.
1010110 is offline   Reply With Quote
The Following User Says Thank You to 1010110 For This Useful Post:
Old 08-17-2013, 02:00 PM   #9
1010110
Forgot to mention, toe was 0 degrees.
End Links Chen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-14-2013 12:08 AM
Links to frs for sale? Please help DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 17 01-18-2013 06:41 PM
Links to used FR-S DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 0 01-18-2013 12:12 AM
Rear Toe Links? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-05-2012 06:29 PM
