#43 |
Drives: 2013FRS-FIRESTORM
I was still averaging 27 miles. I took the weight out when ever the roads were finally cleared of snow and ice, and no snow storms in the forecast... that's why I decided to put the sand in light weight tool box.
94 EJ1 Civic w/8psi Super Charger.
03 GGA WRX @16psi 04 SG Forester N/A 13 ZN6 FRS N/A |
#44 |
I like Blizzaks, but I picked up some Firestone Winterforce tires because they were so much cheaper and they performed beautifully here in Minnesota. Really comes down to budget, I think Blizzaks are probably the better tire, but the Winterforce tires more than got the job done for a lot less.
#45 |
Drives: White FR-S
27 is still good, this car is really impressing me fuel consumption wise!
| The Following User Says Thank You to R3d For This Useful Post: | Greenhorn (12-09-2013) |
#46 |
The Answer
Drives: Mazda 2
Snow + FRS = Match made in heaven. Drove it all winter on good snow tires and I never had a single problem, always in control.
| The Following User Says Thank You to Rayme For This Useful Post: | hmong337 (09-11-2013) |
#47 |
Drives: BRZ Limited WR Blue Pearl 6MT
I absolutely need snows. I'm really debating on if I should mount on the stock rims or buy some steel to use for the winter... If I were to go with steel, does anyone recommend an alternate width/diameter that may provide improved performance in the snow?
#48 | |
17" steelies are 72 bucks a pop. http://www.discounttire.com/dtcs/fin...rw=&vid=022253
#49 |
Aloha!
Drives: Whiteout
#50 |
Ashes to ashes.
Drives: Asphalt FR-S
Went with general altimax. Didn't really have a problem in deep ass Chicago snow.
Sent via my mind using telekinesis.
It is in change that we find purpose.
#51 |
Aloha!
Drives: Whiteout
#52 |
The Answer
Drives: Mazda 2
16" steelies that my friend had on a celica. Tires are BF Goodrich Winter Slalom, they have a very shitty sidewall (they're balloony) but wear very slowly and have GREAT grip in the snow. 4th car I use them on and never been stuck.
| The Following User Says Thank You to Rayme For This Useful Post: | Carticular (08-12-2013) |
#53 |
Drives: Hot Lava FR-S 6MT
I would also like to +1 getting dedicated snow tires. I drove all winter with the stock tires, and it was not a pleasant experience. My poor FR-S was getting stuck in the most unfortunate places
#54 |
Keep calm and drive on
Drives: 2013 WRB BRZ Limited 6M
I have had great success with General Altimax Arctic. Never let me down on previous cars. This winter I'll be getting 16" steelies with these tires.
#55 |
Stuck like Glue
Drives: WRB BRZ Limited
Took the plunge! After saving up enough pennies and waiting a lot, I got it. You guys surely gave me the confidence to drive her on snow (or be able to!) and thanks for that!
\So now to the main point! Definitely planning to get snow tires for her, but not decided between getting steelies or just replacing them on the stock wheels. What do you guys recommend? Also, if I do change to steelies, wouldn't I need to install new TPMS sensors too? |
| The Following 2 Users Say Thank You to ZeHeadBanger For This Useful Post: | Evil Jesus (09-22-2013), Scionshaun (09-22-2013) |
#56 | |
ProCrastinationConsultant
i've been told by an alberta, can guy that dd's a modded g35 that the nokians are the best in snow, and their tread depth doesn't change their performance as drastically as the blizzaks.
| Live in MI and MUST get snow tire for next winter!!!!! | ShowTime_DW | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 06-03-2013 04:42 PM |
| Winter / Snow track day? | project d | CANADA | 4 | 01-02-2013 10:14 PM |
| Snow in Virginia, Kentucky, or Ohio with Winter Tires??? | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 10-30-2012 10:55 AM |
| Will this Portable Tent Work in NY winter (snow) | whitefrs | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-22-2012 10:26 PM |
| what tires will you be using this winter for snow? | denverizzles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 08-01-2012 11:20 PM |
