Old 08-07-2013, 11:34 AM   #925
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Unichip Jack.....Finding a stable tune for my new header??
I'm running a P&L header, Perrin overpipe, 2.5" Isis pipe/muffler with a 2nd cat delete, and a drop in filter with a Perrin silicone intake tube. I'm uding 93 octane and have tried the appropriate 'all header/all cat-back/all drop-in tunes with fuel+ and fuel-. I've also tried advancing the timing on these. I tired timing- for one run, but I'm not getting anywhere.
I notice very little difference between the tunes. They all seem to run rather well at first, but after a couple hours of driving I start having a rough idle, some hesitation when I hit the gas and an inconsistent engine running up the RPMs.
I had things working well before I added the header, but now....??? Help!
mtimney is offline   Reply With Quote
Old 08-07-2013, 11:52 AM   #926
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I had this exact same problem when I added my rev works header while using the unichip. It worked great for a while but started having the same issues that you are. My solution? Take off the unichip and get a tune. The unichip is a great product, but it can only do so much. :/
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 08-07-2013, 12:01 PM   #927
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
I'd like to believe the problem isn't the Unichip itself, but rather the lack of tuners.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
IceFyre13th (08-07-2013)
Old 08-07-2013, 12:10 PM   #928
ML
ML's Avatar
Drives: 13 White MT FR-S
there is a tuner near me (4 hours) and they want $300-400 an hour to tune the car.
Old 08-07-2013, 03:06 PM   #929
If_TheShoe_Fitz
Drives: 2013 GBS Subaru BRZ Limited
Any word on getting a set of e85 map? I was following a thread on that for a while, but I believe it died off.
If_TheShoe_Fitz is offline   Reply With Quote
Old 08-07-2013, 03:38 PM   #930
ML
ML's Avatar
Seems unlikely in the foreseeable future.
Old 08-07-2013, 04:47 PM   #931
ScionFrsFan
No.
My guess is sometime next year.
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 08-07-2013, 05:13 PM   #932
enwave
enwave's Avatar
@Unichip Jack has said that providing an e85 map is technically illegal and the fine is pretty outrageous, but that they are working with the EPA to have a valid legal way to do this. I don't know how accurate that is, but that's just what they have said so far and they have been pretty trustworthy to date.
Old 08-07-2013, 08:59 PM   #933
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Thanks for the posts.
enwave… spot on, thanks… although “completely” is more accurate than “technically.” As he says, we are and have been in e85 discussions with the EPA; we just spoke with them again this morning.
Rough running after installing a header isn’t a “tuning” issue… the header’s impact on an airflow based tune is actually pretty minor. It is an emissions issue.
It's not even really the header per se, if you use the same header with a cat (with a stock front pipe cat) you won’t have a problem. That’s why the header companies recommend you keep the cat.
Unfortunately, when you delete one or both cats, the OEM ECU quickly declares a cat efficiency fault (which all street legal vehicles must do) that results in a CEL and poor performance on some vehicles.
Beyond the timing and fueling changes for a header with cat, what the “no cat tune” does is turn off the cat code. Only problem is that’s completely illegal and what cost Edge Products better than 7-figures in fines and penalties… http://www.dieselnet.com/news/2013/01epa.php.
If you use an O2 spacer or spark plug non-fouler on the downstream O2 sensor port, you’ll avoid the fault code and should be golden.
Cheers
Unichip Jack is offline   Reply With Quote
Old 08-09-2013, 02:45 PM   #934
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Originally Posted by UniChipJack
We’re scheduled to put the FA20 Club intake back on the car next week and complete the maps. As soon as they’re done, we’ll get them posted.
Any update?
IceFyre13th is offline   Reply With Quote
Old 08-09-2013, 02:54 PM   #935
Unichip Jack
Thank for the post.
The car is literally out right now finalizing things... should be posted early next week.
Cheers
The Following 2 Users Say Thank You to Unichip Jack For This Useful Post:
IceFyre13th (08-09-2013), Lytheum (08-10-2013)
Old 08-09-2013, 03:15 PM   #936
IceFyre13th
Drives: Mazdarati
Sweet!!!
The Following User Says Thank You to IceFyre13th For This Useful Post:
BuBlake (08-09-2013)
Old 08-09-2013, 03:30 PM   #937
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Originally Posted by swift996 View Post
Jack - I wanted to confirm that the 5-way switch will work with our kits? Is the cable long enough to port through the sound tube tunnel in the firewall? I was thinking of keeping in my glovebox.
I'd also recommend extending the USB flash cable. I'd love to pipe both through so I can remap and select from within the cabin. I think it was mentioned there might be a bluetooth adapter available soon?
I opted not to go with the flux2 just because I use the OBD2 port for data logging and frankly just didn't have much use for it.
No sure if it is legit .. BT Module $237*. But the app is available*
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 08-09-2013, 06:58 PM   #938
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Not sure about the 5-way, but I use the 3-way switch from Unichip Wholesale and it works great.
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
