Old 08-06-2013, 04:57 PM   #729
ayau
Drives: Some rust bucket
Originally Posted by jjaisli View Post
David, I'm just curious. The specific wording of the TSB from Toyota South Africa mentions, and I quote:
It then includes a graph that highlights only shifts from 3->4, 4->5 & 5->6, not specifically stating but certainly alluding that shifts from 1st to 2nd and from 2nd to 3rd are not an issue. From your experience, do you believe this problem occurs during rapid gear shifts within 0.6 secs and on-off-on WOT applications, regardless of which gear? I honestly don't know if the ECU accounts or adjusting the timing according to what gear you're in. Or were. But I think it is (or at least could be) a key distinction.
For the record, I'm still trying to get a straight answer from my service tech if the wording on the same TSB is correct and cars with post January 21st build dates no longer have this issue.
From my understanding, they didn't list shifts from 1->2 and 2->3 being problematic because the rpms fall below 5,200 RPM.
The Following User Says Thank You to ayau For This Useful Post:
jjaisli (08-06-2013)
Old 08-06-2013, 05:01 PM   #730
ayau
Originally Posted by Superhatch View Post
The most frustrating part is that eventually this type of failure will have to be TSB'ed by Toyota and Subaru which will in the long run prove you right. Unfortunately they won't go back and credit you for a new motor. We as a community will likely see justice, you as an individual owner likely wont.
I thought Subaru hasn't fixed the ringland issue on the WRX STi. If the percentage affected is low, I wouldn't be surprised Subaru/Toyota not announcing a TSB. So far, it seems like only a very very small percentage of people are affected by this.
Old 08-06-2013, 05:07 PM   #731
ayau
Originally Posted by CSG David View Post
Now if Toyota decided to step up and really back the community, they will be loved and hailed as king of the automotive world. Subaru did not care for their Impreza community, they will likely not care for the BRZ community.
The sad part is that the track enthusiasts only make up a very small percentage of the ft86 cars. These cars will still continue to sell like hot cakes, but the track rats will stick to their trusty Miatas/S2000s.
Old 08-06-2013, 05:12 PM   #732
CSG David
CSG David's Avatar
Subaru will always tailor the cars to the general market.
Old 08-06-2013, 08:07 PM   #733
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
That only makes sense for any car company. The percentage of owners who will actually track or even drive their cars at the limit for extended periods of time is tiny. That even goes for companies like Porsche, Ferrari or BMW. Why would any company spend the money to over engineer their cars just in case they were tracked? They won't, especially if it is a sub $50K car. I am not defending Subaru but rather pointing out that they are no different from any other major manufacturer.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-06-2013, 08:08 PM   #734
CSG Mike
CSG Mike's Avatar
Ferrari and Porsche have HUGE track clientele...
Old 08-06-2013, 08:11 PM   #735
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showp...&postcount=709
Porsche has the same disclaimer (and even goes as far to single out events sanctioned by themselves as cause for voided warranty).
-alex
Old 08-06-2013, 08:13 PM   #736
CSG Mike
CSG Mike's Avatar
-alex
May not =/= will not.
But, I'm not talking about Porsche guys that track GT3s... or Ferrari guys that track a 458.
Rather, CUPs and Challenges.
Old 08-06-2013, 08:16 PM   #737
Rampage
Rampage's Avatar
They may have a lot of people that track their cars but I am betting they have a lot more than do not. Also a lot of Porsche and Ferrari cars that are tracked are older models that have been out of warranty. And as I stated above the cars do not sell for less than $50K. They sell for a premium price and therefore can be over engineered to some extent. They could also afford to offer a better warranty on those premium priced cars. I wonder how Porsche views tracking the base model Boxster? Probably about the same way Subaru views tracking the BRZ.
Old 08-06-2013, 08:49 PM   #738
CSG David
CSG David's Avatar
Well there's a reason why people continue to track Miatas, Civics, and S2000s. They are the most reliable cars out there. Those cars fail in ways that Subaru could only dream of right now. The only time someone really blows an engine is mostly due to mis-shifting and neglecting maintenance. Most track guys maintain their cars many times better than the average car owner. It's just the nature of scope. If you were to place safety factors on engineering design, Civics/Integras/S2000s and Miatas would have a minimum safety factor of 3.5. Subaru decided to make the powertrain and drivetrain to work at an average of 1.25. Works for most, but when put into performance mode, it can't take anymore. This number scale is just a ballpark scale.
The Following User Says Thank You to CSG David For This Useful Post:
strat61caster (08-07-2013)
Old 08-06-2013, 09:31 PM   #739
CSG Mike
CSG Mike's Avatar
There's a whole different world of tracking outside of what you see with POC/PCA/SCCA/NASA...
Probably about the same way Subaru views tracking the STI.
FTFY
Old 08-06-2013, 09:56 PM   #740
AznBRZer
Drives: 16 CBS WRX Limited
One of these days, I'll own an S2000. It MUST be done.
AznBRZer is offline   Reply With Quote
Old 08-06-2013, 10:24 PM   #741
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
A company can say they will void a warranty because you drank a soda in your car. It does not make it right or necessarily legal.
clayrush is offline   Reply With Quote
Old 08-06-2013, 11:34 PM   #742
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Right and legal are of course two totally different things. Legal is whatever their lawyers write in the contract.
I agree with Dave about the safety factors. Honda way over designs its motors. I don't think Subaru does. I know a lot of Subaru guys who "race" their cars on the track and they flog the crap out of their cars. But go on a run with the Honda Challenge guys, it is a totally different story.
DylanFRS is offline   Reply With Quote
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
