| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: WR Blue BRZ, 240Z
I know this might seem waaaay out there, but why not run what the factory (you know, the one that spent millions of dollars and thousands of hours testing this very same engine) recommends. Remember, they have to warranty the engine. The do have a vested interest in the longevity of your engine.
I'm fairly certain that they gave a bit more thought to this then the collective here has. I know, I'm crazy.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#16 |
Drives: GT86-JDM
Dennis,
ya agree those 300v is good. I hv it in my current STI 15w50 as well as in another endurance track car. as for the 5w50 so far is ok car will not feel dragging..... may be the 15w50 will be too thick for a N/A, but the Honda Civic (FD2R) like it. Or may be the NEW FB20 is diff from the old EJ207?? Here when we track the car in noon time the oil temp can easily went to 120+degC some time can touch 130C, W/ the 300v 15w50 oil press still hold at ~ 2par (w/o engine load). BTW, my GT86 don't hv any warranty from local Toyota dealer. as both 86 & STI are a JDM (bring in by used car dealer). |
#17 |
Drives: 2013 BRZ Limited AT
There was a pretty extensive thread on NASIOC a while back discussing using various non-recommended viscosities in engines. The consensus ended up being increased engine wear and tear because the oil pump and ports aren't designed to handle thicker oils. Think about it. 0w20 is like you sucking water through a straw. Now put 10w40 in and it's like sucking a thick milkshake through the same straw. Increased pressure on the pump and the oil is flowing through the engine slower which means your internals aren't getting lubricated as quickly. That's why others have seen a big power loss when running thicker oils.
Long story short, do your research before increasing viscosity. |
#19 | |
Drives: Subaru BRZ Sport Tech Satin White
#20 | |
#21 |
Viscosity is not relevant to bearing protection. Oil protects bearings due to hydraulic pressure developed by rotation shear effects. The bearing floats on an oil wedge in similar fashion to a power boat planing over the surface of the water.
The W viscosity rating is very important for cold start and cold running. The main viscosity number should be used for all other engine protection considerations. Heavier viscosity may be desirable for extended track use, otherwise 0W 20 is the only oil to use. |
#22 | ||
Drives: 2004 Subaru Forester 2.5XT
I do believe that you should go as thin as possible and only as thick as necessary for your application, but a turbo EJ engine is a completely different animal. Up until model year 2011, Subaru recommended 5W-30 for fuel economy and required thicker viscosities in higher temps with grades up to an xW-50 being allowed in severe conditions. My owner's manual allows 10W-40 down to -4F. A thin 0W-40 or medium 5W-40 is probably perfect for an EJ turbo with a few or little mods.The BRZ/FR-S manual does allow thicker viscosities in certain condtions, although they don't define the conditions or the thicker viscosities like the older Subaru manuals did. -Dennis |
#23 | |
If I find the other thread, I'll post up another reply, but one of the forum members went pretty in-depth about brand comparisons, track vs street, etc and basically said the only time you'll need to consider changing weight from the manual's recommendation is if you're running long races or for extended periods in a very hot environment, like Death Valley hot. If you're doing that, you should have an oil temp gauge like you mentioned above. Most people aren't running in extreme environments and they shouldn't worry about changing weights. He also cited and showed various examples of engines which ran heavier weights and ended up causing engine damage over time. It wasn't pretty, but it was pretty informative. My POV after owning around ten cars and four motorcycles is to just stick to the stock weight and go with a really good quality full synthetic and oil filter. Better to spend an extra $20 per oil change than risk thousands of dollars in engine damage. IF the manual recommends a specific weight for hotter or colder conditions, I'd say go for it, but otherwise stick to 0w20. Keep in mind turbo cars also share their oil with the turbo, so that tends to cook the oil faster than NA. |
#24 |
Drives: GT86-JDM
yeap... best to get oil press & oil temp gauges to monitor the oil performance.
also in my country is not easy to get a good 0w20 oil. |
#25 |
Drives: Altezza RS200-Z 6MT
www.motul.com/MY/en = good 0W-20
#26 |
Motul 300V 0W-20 from Zhapalang Motorsport:
http://motul-malaysia.blogspot.com/p/where-to-buy.html http://www.zhapalangmotorsport.com/2...synthetic.html :happy0180: -Dennis |
#27 |
Drives: FRS(sold), AP2, R35, FJC, ED9
what about 0W-30
#28 |
Good stuff...
On a tangent. I'm on my 3rd fill of oil. 1st factory, 2nd Royal Purple 0w20 and now my 3rd another fill of RP 0w20. When I replaced the factory fill my motor took a solid 6 quarts of oil, which I though was a little strange since the manual lists 5.4 quarts (is it?). Anyway, on my most recent change the motor took another solid 6 quarts. Have any of you guys out there noticed this? Or is my motor just got a slightly larger oil pan than what the factory states?
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
| Eneos 0w20 | Hayashi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 154 | 10-27-2014 05:04 PM |
| Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 5 | 12-29-2012 04:25 PM |
| Delete | driver01 | CANADA | 5 | 08-30-2012 04:58 PM |
| Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 3 | 07-08-2012 01:04 PM |
