#141 |
I know you're a Honda guy but do you know roughly how fast the wheel bearings and other parts would go out if you're on low offset wheels? Not really sure but I would think tracking a car would see higher stress compared to normal street driving.
Ideally I want around 40 offset wheels but it seems the more popular wheels only come in mid 30s |
#142 | |
#143 |
Drives: AVO BRZ
My cars been on 98 and e85 it's lifetime, tracked & drifted and up to 17 psi on stock internals, and a bit of a delay in getting the injector fix flashed. Seals are fine still! Just a ray of hope in all the doom and gloom.
Setup question! Dialling out low speed rear wheel skip/lift?
#144 |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
This. I'm about to pull my rear bar this weekend and see what it does. I also am increasing front swaybar size, and softening the rear damping. I'm having the same problem.
Nick K.
NASA ST5/TT5 #130 Southeast Region |
#145 |
Drives: WRB Premium
Mike - stock tires nearing the end - if i want to go RS-3 what tire width would you recommend for stock wheels? 225?
#146 |
#147 |
Drives: WRB Premium
When the stars are aligned.
#148 |
Drives: Nevermorange FRS
Mike, I don't have a question.
I just thought I'd share this baby with you.. $28k, 733rwhp http://seattle.craigslist.org/see/cto/3966920765.html (car is in Utah) Few cars in my life have I wanted so bad.
PRO86 | WTCC | STL
#149 |
Drives: Nissan Versa
^ Why would anyone want a beat up racecar?
... because racecar! |
#150 |
Beat up?
PRO86 | WTCC | STL
#151 |
#152 |
Track Junkie
Drives: Faster than the Stig!
This thread reminds me so much of the tirerack random tire question commercial
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#153 |
Drives: 2013 Firestorm FR-S
I've got a question about gear shifting and letting out the clutch. One the street I drive pretty smooth (I think I may be over cautious) and release the clutch slow enough to minimize the driventrain lash/thunk/stress from quickly letting out the clutch.
In terms of performance driving, how much stress/thunk/lash can you put on the clutch/engine mounts etc...as you shift gears without long term damage? I don't ever drop launch the car from a stop but I'd like to know how far I can push the drivetrain with quick shifts from say 1st to 2nd, or quick downshifts from 4th, to 3rd or 2nd.
2013 Firestorm FR-S, MTX, build date 1/13.
#154 | |
That being said, as long as you're not SLAMMING gears, you should be okay. The stock clutch doesn't grab hard enough to REALLY shock the gears; you'll notice a screeching noise if you do really really hard shifts. This is the clutch slightly slipping on that fast shift, which is absorbing some of the shock load. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
