Old 05-19-2013, 04:00 PM   #29
Xenith
Drives: Scion FR-S Raven
Here is a quick model I made that can be made out of sheetmetal (aluminum would be best to keep it lightweight).
I need to get some foam to get more accurate dimensions, but this is the general idea. I would paint it (probably black) and add rubber to sides to prevent scratching of the car interior, as well as rubber to the two flanges that hold the top of the nexus 7 in place.
Let me know your thoughts and I can go a different direction if you want.
Cheers
Xenith is offline   Reply With Quote
Old 05-19-2013, 09:08 PM   #30
ijuliusx
ijuliusx's Avatar
Drives: 2013 Scion FRS (ARGENTO)
Check out @corradooo work on INSTAGRAM about this!
ijuliusx is offline   Reply With Quote
Old 07-31-2013, 05:49 PM   #31
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Cheers
I totally missed this, I like the idea and if fitment was good I'd use it, to prevent scratching i was thinking maybe spraying the sheet metal with a coat of plasti dip,
Sorry I never replied to this but if you can make it happen, it would be awesome!
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 07-31-2013, 08:46 PM   #32
Cesium Rainbow
Cesium Rainbow's Avatar
Drives: '13 dgm brz
I missed this the first time around too, pretty dope concept. If it wasnt too pricey it might give me a reason to actually get a tab. If anybody's thinking about seriously making something like this, just make sure the climate control cutout is shaped to provide access for both center console types and include a slot or something for the push button start so Subaru and Toyota owners aren't excluded.
Cesium Rainbow is offline   Reply With Quote
The Following User Says Thank You to Cesium Rainbow For This Useful Post:
Brody602 (07-31-2013)
Old 08-01-2013, 04:26 AM   #33
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
3 things:
1: isnt that angle abit low to get a good view of the screen?
2: wouldnt the shifter get in the way of tapping or viewing?
3: what is the purpose of the tablet? if movies, wouldnt the first two things be a big issue? and wouldnt sound quality be pretty bad unless you plan to route it through the car speakers somehow
mrlewistan is offline   Reply With Quote
Old 08-01-2013, 04:35 AM   #34
Brody602
Drift King
Brody602's Avatar
Originally Posted by mrlewistan View Post
3 things:
The viewing angle isn't too low, it's a little out of sight but nothing serious, for myself anyways, but I'm not a tall guy.
The shifter should stay clear of the tablet by quite a bit, There is quite a bit of room there.
Personally myself, the tablet is for Torque, just to monitor some readings on my car, and possibly for gps depending how hard it is to see. I have no intentions of using it to play audio or movies.
The Following User Says Thank You to Brody602 For This Useful Post:
mrlewistan (08-01-2013)
Old 08-01-2013, 04:39 AM   #35
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
good luck n i hope it comes together then
The Following User Says Thank You to mrlewistan For This Useful Post:
Brody602 (08-01-2013)
