Old 07-28-2013, 12:26 AM   #673
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
It surprises me that this issue is still around considering it was supposedly fixed on the production line more than a year ago...
The gaskets still aren't being sealed to the housings. Given the design and how water runs down them, the crappy equivalent of a strip of scotch tape isn't going to prevent condensation forever. I'm still finding that using the better gasket foam and sealing it all the way around with weatherstripping adhesive gives the best results. Some of the aftermarket taillight companies are at least providing the better foam now. Sealing it to the housings is on the owner/installer to do.
Sent from my iPhone using Tapatalk 2
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 07-28-2013, 04:54 PM   #674
#288
Drives: Argento Scion FR-S
Don't use alcohol to remove water from inside the taillights. Saw some water in the tail lights, thought it would be easy to use some alcohol to dry out the water then allow the alcohol to weather off, to speed it up I used a hair dryer. Big, Big, Big mistake! The alcohol etched/stained the lens from the inside. Looks really bad, didn't want to go though the trouble of cutting the lens off to try to buff the stain off. I'm going to need to get some new tail lights. Until then I tinted the lens from the outside, can still see the stain when the brake lights illuminate. Yeech! Oh well lesson learned.
#288 is offline   Reply With Quote
Old 07-29-2013, 02:14 AM   #675
root
Drives: Raven FR-S
Suddenly got water in my right taillight assembly today, got mine in November. Time to finally make appointment! They can take care of window auto switch too. Crickets, maybe.
As for getting on service technicians cases? I don't, we have a single car that we have 24/7 and read all about on our free time. They have at least a dozen different models to work on. Helps that I'm a technician on registers and I know I have to look stuff up all the time.
root is offline   Reply With Quote
Old 07-29-2013, 07:07 PM   #676
FRStance
FRStance's Avatar
Drives: 2013 Whiteout FR-S
I've had this problem for a while but have been hesitant to take it in to the dealer. I redded my taillights out with paint but turned them back to clear after a while. Somewhere in between, the driver side taillight cracked a little bit.
Nothing major, if you run your finger over it, it feels smooth as if nothing happened. The passenger side is fine but still has condensation.
I'm just afraid that they'll see some of the paint that I couldn't get off and that the zip-tie clips are missing because I took them out to mess with them and decided not to give me new ones. Help?
FRStance is offline   Reply With Quote
Old 07-30-2013, 07:23 PM   #677
kodyo
Drives: Scion FR-S
Going to take the car to the dealer to get mine replaced. Anyone elses dealer request an overnight stay of the car to diagnose and confirm problem? Seems a bit excessive...
kodyo is offline   Reply With Quote
Old 07-30-2013, 08:06 PM   #678
DJCarbine
Thupercharged
DJCarbine's Avatar
Are they going to give you a rental?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-30-2013, 08:16 PM   #679
kodyo
Drives: Scion FR-S
They said something about picking me up and dropping me off at my work or something along those lines. I'll probably just turn that down and get a corworker to carpool with.
Old 07-30-2013, 09:55 PM   #680
DJCarbine
Thupercharged
DJCarbine's Avatar
My dealership has no appointments on the weekends for the rest of the year open... I asked if I could drop it off on weeknight and get a rental and they declined and said they can't drop me off at work either if I bring it in the morning because my job is too far.
That's when I decided to just drain them and drill vent holes. No problems now.
2013 FRS
Vortech V3 11psi
Old 07-30-2013, 10:09 PM   #681
kodyo
Drives: Scion FR-S
My plan is to get it fixed at least once now that the issues is well known and jump through the hoops to get it documented. If it happens again, I plan to do the repair myself with a new gasket.
Old 07-30-2013, 11:14 PM   #682
Dipstik-sportech
Dipstik-sportech's Avatar
Name:  ImageUploadedByTapatalk 21375240461.433415.jpg
My new fishbowl. Gets replaced next week.
Old 07-31-2013, 02:06 PM   #683
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Just got back from getting new tails and gaskets due to the TSB. I will update with further developments.
5hairpins is offline   Reply With Quote
Old 07-31-2013, 03:30 PM   #684
raptor87
Drives: 2013 DGM BRZ Ltd
Noticed mine are full of water today
raptor87 is offline   Reply With Quote
Old 07-31-2013, 06:11 PM   #685
kodyo
Drives: Scion FR-S
Got back from dealer, 1 month back order on gaskets is what they claimed. So I'll be waiting a bit to get mine replaced.
Old 07-31-2013, 11:14 PM   #686
tasinene
Drives: 2013 Scion FRS Asphalt
Originally Posted by Dipstik-sportech View Post
Attachment 46219
That's exactly what mine looks like. Saturday can't come fast enough
tasinene is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
