| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Brz WRB - Europe LHD
DIY Rear Camera for T7019A
This is full compliance for T7019A Android. $14,95. Very small. Night vision it's ok.
http://www.ebay.com/itm/360633507954...84.m1423.l2649 Sideview and Frontview pictures. To install on BRZ: Hole of 19 mm (trunk fascia need to be removed) 1. wire red 12+ to red 12+ of HU harness (where is located fuse) 2. wire black (ground) to chassis or HU harness ground (black) connect VGA cable camera and HU 3. wire brown "reverse" on HU harness to pink wire no. 5 of primary harness (beside indoor fuse main unit). You need 50 cm of adding cable. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
I'm glad I came across your DIY, thanks just ordered. If you spray the camera, it won't even be noticed.
| The Following User Says Thank You to Ryan86 For This Useful Post: | Trap63 (07-31-2013) |
| Rear-view camera/reverse cam. What do you have? | joergasm | Audio/Visual, Electronics, Infotainment, NAV | 0 | 05-24-2013 01:25 PM |
| Rear sensors vs Camera | youngy | AUSTRALIA | 3 | 12-28-2012 10:48 PM |
| be spoke w rear view camera | xpicer | Electronics | Audio | NAV | Infotainment | 17 | 10-14-2012 10:26 AM |
| Scion FRS / BRZ Rear Camera Installed | SpecPer | Electronics | Audio | NAV | Infotainment | 30 | 09-05-2012 11:37 PM |
