Old 06-01-2013, 06:52 PM   #29
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
Originally Posted by switchlanez View Post
I just saw that episode last weekend,
haha nice. this is probably the only thread where this reference works lol
mezdup is offline   Reply With Quote
Old 06-13-2013, 12:49 AM   #30
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
Awesome write up! Can't wait to try this.
Terran is offline   Reply With Quote
Old 07-25-2013, 07:49 PM   #31
altezza280t
altezza280t's Avatar
Drives: Ultramarine FR-S
curious to see an FR- S with this...
altezza280t is offline   Reply With Quote
Old 07-25-2013, 08:26 PM   #32
DIM
I just got some KJ magnets, and will try do this DIY soon.
DIM is offline   Reply With Quote
Old 07-26-2013, 12:18 AM   #33
EastBayCanuck
curious about the FR-S too, my buddy insisted I get the dealer to not drill my front bumper so now I need another way to put the plate on.
EastBayCanuck is offline   Reply With Quote
Old 07-26-2013, 03:49 AM   #34
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Several local FR-S owners I hang out with told me they aren't supposed to be drilled. The plate secures to the grille somewhow.
Old 07-26-2013, 10:03 AM   #35
DIM
It's optional to be drilled. There's 2 marking's on the grill where to drill at.
Old 07-28-2013, 01:17 AM   #36
Inersha
Drives: Subaru BRZ Black Silica
Nice, I may try this. I definitely dont want to drill holes into the bumper
Inersha is offline   Reply With Quote
Old 08-26-2013, 01:51 AM   #37
cintari
FR-S Mod
I just did this mod for my FR-S. Removing the side lights for the bumper were the tricky part but easy once I figured it out.
Also, the bumper has markers on where to put the magnets - no measuring required. Just use the markers for where you're expected to drill. There are additional screw holes for the bottom screws but I just used the top ones.
Name:  IMG_20130824_183226 copy 2.jpg
cintari is offline   Reply With Quote
Old 09-12-2013, 12:32 PM   #38
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by SoCal_86 View Post
What feature does the grimmspeed have to prevent theft?
Threadlocker?
This is a great idea, had I seen it before the Grimmspeed I would have done it. Although, I'm completely happy with the Grimmspeed.
For scratch protection, I would have used some shoe goo or rubber cement/liquid nails and made some simple raised beads around the hole. Nice and tacky, doesn't catch all the debris that felt does, and won't come off.
DoomsdayJesus is offline   Reply With Quote
Old 10-26-2013, 04:21 PM   #39
Howardwei
Hi My OEM license plate mount, held by the bolt dealer put on, is turning but does not seem to come off. Any ideas?it sees like one of those screws you stick it in the wall that wont come off and keep turing.
Howardwei is offline   Reply With Quote
Old 10-31-2013, 10:09 PM   #40
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
How hard is it to get to the magnets with the bumper on? I would rather not risk lightly scratching the bumper while I try to mount the magnets, and if they can be reached without too much difficulty, I might even consider just using the force of the plate's magnets to keep the back ones in place.
Luckrider is offline   Reply With Quote
Old 11-01-2013, 10:02 AM   #41
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
the styrene/foam pad inside the bumper makes it difficult, plus every time you take off the license plate the magnets will drop. you'd have to use something flexible to insert them from the bottom every time. also, i'm thinking that without the rear magnets held in place, the license plate bracket can shift from side to side more, and maybe scratch up the bumper. the magnets keep it in position/centered since they're fixed.
shiumai is offline   Reply With Quote
Old 11-02-2013, 02:37 AM   #42
Luckrider
Luckrider's Avatar
Thanks for the input, I am just going to order them tonight and pop the bumper when I get some time on a weekend. I overlooked the sliding concern, and I wasn't too terribly worried about pulling the front bumper.
front license plate mount? Jeong Cosmetic Modification (Interior/Exterior/Lighting) 16 02-13-2014 10:54 PM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
