Old 07-21-2013, 11:25 AM   #1
phloozy
phloozy's Avatar
Drives: Scion FR-S
How restrictive is the stock midpipe
I did a lot of searching but couldn't find a good answer so I am putting it up for discussion. I know Nameless decided to only go with an axle back because they didnt find much gains in the mid pipe but what are others results?
Would it be smarter to save money and just go with an axle back and then save for a front pipe/over pipe? Has anyone gone from an axle back to a cat back and noticed any gains?
Thoughts?
phloozy is offline   Reply With Quote
Old 07-21-2013, 11:59 AM   #2
jonbonazza
Fluid dynamics states that best results (however minimal) will be seen when the size of the channel (in this case, the pipe) is consistent throughout and as strait as possible. Most axle-backs are 2.5", while some are 3" and the greddy unit is 2.75" OD. I forget the stock mid-pipe OD, but it's somewhere around 2.15 or something, which is tiny and when mated to a 2.5"+ axle-back, results in turbulent air flow. With that said, the exact gains from having consistent sized piping will depend on things such as the way the pipe is routed (number of bends, etc..) and the shape and construction of the muffler. With that said, unless your build is purely aesthetic, then you should strive for piping diameter that is consistent as possible.
The only cat-back I have direct experience with is the FT86SpeedFactory V2 single-exit cat-back. It's 2.5" (which has the most aftermarket support) and has the straitest mid-pipe I have seen for our cars. Being single exit means less turbulence and, theoretically, should result in better flow, thus better gains. I have no dyno sheets or anything else to go by other than pure speculation since I do not know how the muffler was constructed, but my gut told me it was the best choice for a functional cat-back. Again, if aesthetics are of a higher priority, then you probably don't want the single exit design.
To summarize, the answer to your question depends entirely on your goals and personal taste.
jonbonazza is offline   Reply With Quote
Old 07-21-2013, 12:07 PM   #3
phloozy
phloozy's Avatar
Drives: Scion FR-S
This is kind of how I felt, thanks for the extensive input.
Old 07-22-2013, 12:41 AM   #4
Fast_Freddy
Drives: Passat
If I had to guess I'd guess that replacing the ~2.12" mid-pipe with a 2.5" pipe should add 2whp. More with supporting mods like FI.
Fast_Freddy is offline   Reply With Quote
Old 07-22-2013, 02:19 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
here is a comparison of a stock midpipe vs. a modified midpipe
my test car showed 5-6 hp gains with the modified mid pipe
click here for more info ---> http://www.ft86club.com/forums/showthread.php?t=24472
and here to order ---> http://www.86-zn6.com/WORKS-EXhale-M...aust_p_50.html
86_ZN6 is offline   Reply With Quote
Old 07-22-2013, 10:36 AM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I was wondering samething as OP. hmmm i still can't decide if i should go with full-catback or axleback
Old 07-22-2013, 10:43 AM   #7
velin86
velin86's Avatar
Drives: 2013 Raven FRS 6MT
I'm going nameless axelback with that works midpipe.
2013 Raven FRS
velin86 is offline   Reply With Quote
Old 07-22-2013, 11:03 PM   #8
Alabang 86
Alabang 86's Avatar
Drives: GT86
for what it's worth, Nameless said.....that the original mid pipe is lighter and has the same performance as the midpipe Nameless built and tested.
Nameless recommends using the original mid pipe which is what I did.
Nameless axle back + nameless header back front pipe with high flow cat.
dyno numbers coming soon.
...my turn...
Alabang 86 is offline   Reply With Quote
Old 07-22-2013, 11:37 PM   #9
phloozy
phloozy's Avatar
Drives: Scion FR-S
please let me know the numbers, I will probably be going nameless headerback>stock mid>greddy sp elite. I imagine your numbers will be slightly higher
Old 07-23-2013, 12:15 AM   #10
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
let me know when your ready to get the midpipe. ill hook you up with a good deal
Old 07-23-2013, 12:25 AM   #11
velin86
velin86's Avatar
Even so.....I'd feel more comfortable having a full 2.5" system haha. Can't hurt?
2013 Raven FRS
Old 07-23-2013, 07:21 AM   #12
Alabang 86
Alabang 86's Avatar
Drives: GT86
correct, just knowing it's there is part of the fun.
...my turn...
Old 07-23-2013, 07:52 AM   #13
Gardus@Supersprint
Drives: Clio TCE
In terms of performance the stock midpipe is ok, unless you go turbo with high boost (300+hp).
The real bottlenecks are the cats on the headers and front pipe.
Gardus@Supersprint is offline   Reply With Quote
Old 07-23-2013, 09:25 AM   #14
Raven604
I feel you bro. I'm gonna contact nameless and see if they will fab me up a mid pipe when I order. If not... Well Works it is.
Raven604 is offline   Reply With Quote
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 01:39 PM
F/S stock exhaust and midpipe, in Pacific NW HotLavaMann Engine, Exhaust, Bolt-Ons 1 11-25-2013 01:02 PM
Perrin non res midpipe for resonated? Tylub Engine, Exhaust, Bolt-Ons 23 06-17-2013 02:38 PM
Selling stock overpipe, midpipe, and exhaust for anyone interested markmatley Hawaii 0 02-20-2013 09:37 PM
Stock Exhaust and Midpipe Xdragonxb0i Engine, Exhaust, Bolt-Ons 0 02-13-2013 01:22 AM
