Old 07-21-2013, 10:23 AM   #57
tennisfreak
Drives: 2018 BMW M240i
So from reading this thread I am gathering that most here think the dip is caused from the injection and intake system along with tuning.
What about all of the people that say it is the headers? Do the headers not really have anything to do with the torque dip?
Old 07-21-2013, 10:24 AM   #58
Mikem53
Drives: FR-S 6MT
Originally Posted by russv View Post
I'm surprised Subaru wasn't able to tune the torque dip out.
They made the most out of what they had to work with.. Everything is a compromise..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
EK_Golfer (07-21-2013)
Old 07-21-2013, 01:35 PM   #59
Mikem53
Drives: FR-S 6MT
Originally Posted by bkblitzed View Post
omg its a 2l NA motor. What the fuck do you guys expect.
Plenty of other 2L 4 bangers out there with more linear tq curves.. Just trying to understand why the FA20 has a hole..
Old 07-21-2013, 01:52 PM   #60
EK_Golfer
EK_Golfer's Avatar
Drives: 2013 Whiteout FR-S AT
There aren't too many 2L's banging out at least 200HP though. The ones that come to mind are the Acura RSX-S and the AP1 Honda S2000- VTEC sure is nice.
EK_Golfer is offline   Reply With Quote
The Following User Says Thank You to EK_Golfer For This Useful Post:
Mikem53 (07-21-2013)
Old 07-21-2013, 01:58 PM   #61
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
it wouldn't be a hole if you rev it out. Problem solved, idk why people are making these threads.
bkblitzed is offline   Reply With Quote
Old 07-21-2013, 02:08 PM   #62
Mikem53
Drives: FR-S 6MT
I'm not the one complaining about driving this car or the characteristics of the torque dip.. but there is no denying the fact that it exists..
nothing wrong with wanting to know why or trying to "fix" it..
Old 07-21-2013, 02:34 PM   #63
Opposed
Drives: 2013 Asphalt FR-S
I haven't seen anything about the intake casuing it. Its been a combo of tune plus a good header, but nothing by itself. My tune alone helped, but it was still there. Then adding the header helped even more, but it was still there. Once the tune was readjusted for the header, problem solved. It may have to do with cam and ignition timing with the header.
Here is an example of a good equal length header and a tune...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following User Says Thank You to Opposed For This Useful Post:
thill (07-21-2013)
Old 07-21-2013, 06:17 PM   #64
pmdc
pmdc's Avatar
Drives: Raven FR-S 6MT
That's quite impressive. What header?
pmdc is offline   Reply With Quote
Old 07-21-2013, 06:25 PM   #65
thill
Nicely done. I hope to meet up with you sometime, I would consider doing what you did. I am not looking for 300whp for a daily driver, this looks just about perfect.
Old 07-21-2013, 06:41 PM   #66
Opposed
This is the Nameless long tube header with 3" exhaust. This particular header is not out yet...but just showing an example of what the right header and tune can do.
Old 07-21-2013, 06:44 PM   #67
Opposed
That would be great! This isnt my exact set up thought. This header is not in production yet, but soon. I am running an equal length header and tune, the torque in the dip area feels pretty flat. This is the only dyno I have with the header and tune, but keep in mind, this was just slapping the header on. It has now been tweaked much more...I have yet to dyno it with the new tune.
Old 07-22-2013, 10:51 AM   #68
Metal_88
Metal_88's Avatar
Drives: GT86 First Edition
Well, in stock ECU there is a clear change in AFR and injection table, so there are 2 torque dip, one is caused by engine's component and geometry, the other is caused by ECU limitation, that's why changing parts and ROM makes the car rev much better.
And if you just check fluid dynamics parameters you can see that the stock car can't breath.
Toyobaru did a great engine and perfectly hit their commercial target! This is the funniest car ever with a 2.0 L NA engine!!
Besides it earns a lot of hp every time you look at it lol
Metal_88 is offline   Reply With Quote
Old 07-22-2013, 04:18 PM   #69
asnoir
Drives: An old Citroen Xantia TD
Hello. Since december 2011 i'm interesting by the new Hachi roku. You can't have port injection and direct injection between 3000 and 5000 rpm because the motor would overheat. I've seen a PDF from Toyota and it is said that the motor turn not enough quickly to refresh the combustion chamber. After 5000 rpm it turns very quickly and the exhaust valve open quickly to absorbe the heat. I research the pdf file see you soon! I think the D-4s system needs Toyota ingineers to be updated with Ecutek. The complexity from the system whith back pressure and injector heating is to complex for tuners. Toyota says that the injector could be damage by using DI and PI in the same time. The ijectors could reach 150°C and overheat.
asnoir is offline   Reply With Quote
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 07:56 PM
Wheel Re-Torque to 89 ft-lb Brzce Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-22-2012 11:55 PM
It has more power, but less torque. white_knight Scion FR-S / Toyota 86 GT86 General Forum 9 08-09-2012 02:46 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
