Old 07-17-2013, 07:33 AM   #127
Patrick@Ptuning
Patrick@Ptuning's Avatar
Drives: Firestorm-red Ptuning turbo FR-S
Originally Posted by 86 FRS View Post
Nice is it SP Spec also or just the standard one?
Sent from my SCH-I545 using Tapatalk 2
Just the standard set.
Patrick@Ptuning is offline   Reply With Quote
Old 07-20-2013, 08:24 PM   #128
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
BAAAMMM!! sorry crappy photos.
57Xtreme Gramlights SP Spec 19 x 8.5 & 9.5 with Yokohama S Drive 235/35 F | 265/30 R
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 07-20-2013, 11:16 PM   #129
Code:Red
Code:Red's Avatar
Drives: 2013 Firestorm 6MT
They look really nice, man! The design flows more better than the 5AD wheels you had. And...I didn't know S drives came in 235/35s. That is most likely the size i'll do when the time comes.
Code:Red is offline   Reply With Quote
The Following User Says Thank You to Code:Red For This Useful Post:
86 FRS (07-21-2013)
Old 07-21-2013, 09:53 AM   #130
NIKDENG
Drives: RED BRZ
Maganda pare. I have almost the same wheel set-up but I went with the face-2 in front which has a more concave face to match the rears.
NIKDENG is offline   Reply With Quote
The Following User Says Thank You to NIKDENG For This Useful Post:
86 FRS (07-21-2013)
Old 07-24-2013, 03:14 AM   #131
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
My Other baby and FRS
Old 09-08-2013, 10:23 PM   #132
VictorKassil
[||•(==(86)==)•||]
VictorKassil's Avatar
Drives: WRB Subaru BRZ Series.Blue
Send a message via Yahoo to VictorKassil
Finally! FiveAxis Complete Kit Installed.
NorCal Custom Door Sills
Where did you get those door sills?
"Guys, I'm bringing the party to you!"
-Tony Stark
______________________________________
VictorKassil is offline   Reply With Quote
Old 09-08-2013, 10:37 PM   #133
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
from jr. 86_ZN6 forum vendor.
The Following User Says Thank You to 86 FRS For This Useful Post:
VictorKassil (09-12-2013)
Old 10-30-2013, 03:13 AM   #134
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I'm curious why the Gram lights sit better than the 5 Axis wheels. Both were on Eibach Pro-Kit, correct? And both are 19"?
The Gram lights look way better! Good choice of wheel.
I have Sportlines on my car but I feel like the drop is a little too much. I've been looking at pics of the Pro-Kit and I stumbled across your car. When I saw the 5 Axis wheels I thought, "I'm glad I went with Sportlines. Even with 19's the car doesn't sit that well with the Pro-Kit."
But then I saw your car with the Gram lights and it just blew my mind. It looks like perfection.
ericmpena is offline   Reply With Quote
The Following User Says Thank You to ericmpena For This Useful Post:
86 FRS (12-02-2013)
Old 10-30-2013, 11:23 AM   #135
aminninja
aminninja's Avatar
Drives: gt86
awesome 19" man!!
aminninja is offline   Reply With Quote
The Following User Says Thank You to aminninja For This Useful Post:
86 FRS (12-02-2013)
Old 10-30-2013, 12:25 PM   #136
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
The new wheels suit the car better, great choice!
andrewFT86 is offline   Reply With Quote
The Following User Says Thank You to andrewFT86 For This Useful Post:
86 FRS (12-02-2013)
Old 10-30-2013, 12:27 PM   #137
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
My guess is the tires, looks like a more square setup on the gram lights which fill the gap better compared to a bit of stretch on the 5axis He had 225-35's on the 5axis and has 235-35 & 265-30's on the gram lights.
Edit: Offset could also be different.
Anomie is offline   Reply With Quote
Old 12-02-2013, 06:37 AM   #138
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
yes its the tires makes it difference. 5ad tires are little bit stretched. they got the same offset except for the fronts (+43 gramlights; 5Ad +45)
eikond's WRB premium BRZ - Review and Journal eikond Member's Car Journals 74 07-16-2014 01:03 PM
GrimmSpeed Engineering's Daily BRZ Journal GrimmSpeed Member's Car Journals 34 11-13-2013 10:09 AM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 01:50 AM
Request for a Member's Journal forum? ryude Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 05:47 PM
Wall Street Journal reports 2.5 l engine Sport-Tech Engine, Exhaust, Transmission 8 10-11-2010 11:44 PM
