#71 |
I like ice cream...
Drives: 10 Series FR-S
probably 1.5 2 hours so like $150-200 would be my guess but i can ask one of the guys tomorrow
#72 |
Drives: MT WRB BRZ Limited, 2007 911s
Care to elaborate on that one?
#73 | |
Drives: 2013 Scion FR-S Raven
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#74 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Aren't RCE yellows manufactured by Eibach too? Sounds like Eibach does a lot of aftermarket OEM stuff (oxymoron?). We need specs - drop distance and spring rates!
#75 |
Boosted Noob
Why are the Koni inserts a joke? Cause you're not sure how to install them?
#76 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
I doubt these will be lower than 0.6" front and rear, just like the STi pinks.
#77 |
Drives: FRS
So I called my local dealer and was told he had no record of any being shipped yet and that he saw some stop sales on them and that he couldn't place an order. Anyone else run into this?
_____________________________________________
http://genometuning.com http://www.BlackHandGaming.com |
#78 |
Drives: 2013 whiteout FRS
If they cover the shocks/struts, and have a similar to OEM spring rate, im in! After riding on stiff coilovers for 2 years im loving this ride to much lol
#79 |
Glorious BRZ Master Race
Drives: Subaru Libird
Is it true that coilovers are generally stiffer (even at their softest setting if damping is adjustable) than a spring/strut combo?
Is it true that coilovers wear out faster (they are generally smaller) than correctly matched springs/struts? The only advantage I see with coilovers is if you need adjustability to slam/stance your car and/or stiffness for track use.Got proof?
#80 | |
Also, our car technically comes with coilovers, they just aren't adjustable. It's a coil over the shock. Generally, yes...a coilover has firmer spring rates than a regular spring set-up and can feel stiffer if the valving is not good. But sometimes it is good. For longevity it depends. I'm gonna write a post on springs vs. coilovers soon. - andy |
| The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post: | amram (07-31-2013), buzznasa (07-17-2013), HatchetBurial (07-23-2013), switchlanez (07-17-2013), Turdinator (07-17-2013) |
#81 |
Drives: Asphalt FRS
Man and i just pulled the trigger on some Eibach R1's... I was going to get the Pro kits but i said to myself that if im going to void the suspension warranty might as well go all out.. haha now TRDs are gonna be on the market...
#82 |
RedBunny w/ Wing
nice price. thanks!
#83 | |
Drives: FRS
#84 |
Drives: Raven Scion FR-S
now with these springs installed and also if you have aftermarket wheels would you be voiding the warranty since you have aftermarket wheels? i mean i guess if anything happened i could always swap out and put on my winter wheels that have winter tires with stock wheels ... anyone know if this price of 210 is legit ? i wonder what the installation cost would be
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
| Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 06:41 PM |
| ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! | Boston Motorsports | Brakes, Suspension, Chassis | 84 | 07-24-2013 12:42 AM |
| Stock springs and sway bars | Spencer | Brakes, Suspension, Chassis | 3 | 04-25-2013 10:41 AM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 07:00 PM |
| **The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive | Pure Automotive | Brakes, Suspension, Chassis | 1 | 02-06-2013 03:32 PM |
