Old 07-17-2013, 01:31 AM   #71
D-Smith
I like ice cream...
D-Smith's Avatar
Drives: 10 Series FR-S
probably 1.5 2 hours so like $150-200 would be my guess but i can ask one of the guys tomorrow
D-Smith is offline   Reply With Quote
Old 07-17-2013, 11:31 AM   #72
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by regal View Post
Surely there will be TRD shocks offered with these? Warranty or not I don't want to deal with blown shocks. Even my slug Yaris has TRD shocks on it. Unbelievable that there are no struts/shocks available for this car yet, the Koni inserts are a joke.
Care to elaborate on that one?
was385 is offline   Reply With Quote
Old 07-17-2013, 11:35 AM   #73
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Do you wish to elaborate on the "Koni" portion?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-17-2013, 12:02 PM   #74
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Originally Posted by indesign View Post
TRD USA springs are made by Eibach. Not sure if these will be rebranded pro-kits are a different type manufactured by Eibach. At least it will be warrantied by Toyota.
Aren't RCE yellows manufactured by Eibach too? Sounds like Eibach does a lot of aftermarket OEM stuff (oxymoron?). We need specs - drop distance and spring rates!
mit_peid is offline   Reply With Quote
Old 07-17-2013, 12:05 PM   #75
mit_peid
Boosted Noob
mit_peid's Avatar
Why are the Koni inserts a joke? Cause you're not sure how to install them?
Old 07-17-2013, 12:09 PM   #76
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I doubt these will be lower than 0.6" front and rear, just like the STi pinks.
raul is offline   Reply With Quote
Old 07-17-2013, 12:11 PM   #77
CharlieChaos
Drives: FRS
So I called my local dealer and was told he had no record of any being shipped yet and that he saw some stop sales on them and that he couldn't place an order. Anyone else run into this?
_____________________________________________
http://genometuning.com
http://www.BlackHandGaming.com
CharlieChaos is offline   Reply With Quote
Old 07-17-2013, 12:42 PM   #78
morrisxd
Drives: 2013 whiteout FRS
If they cover the shocks/struts, and have a similar to OEM spring rate, im in! After riding on stiff coilovers for 2 years im loving this ride to much lol
morrisxd is offline   Reply With Quote
Old 07-17-2013, 01:10 PM   #79
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Is it true that coilovers are generally stiffer (even at their softest setting if damping is adjustable) than a spring/strut combo?
Is it true that coilovers wear out faster (they are generally smaller) than correctly matched springs/struts?
The only advantage I see with coilovers is if you need adjustability to slam/stance your car and/or stiffness for track use.
Originally Posted by Pekingduck View Post
They eibach springs
Got proof?
Old 07-17-2013, 01:42 PM   #80
Racecomp Engineering
Got proof?
The short answer is it depends. You can't lump all springs together, and you can't lump all coilovers together. There's a wide range of both.
Also, our car technically comes with coilovers, they just aren't adjustable. It's a coil over the shock.
Generally, yes...a coilover has firmer spring rates than a regular spring set-up and can feel stiffer if the valving is not good. But sometimes it is good.
For longevity it depends.
I'm gonna write a post on springs vs. coilovers soon.
- andy
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
amram (07-31-2013), buzznasa (07-17-2013), HatchetBurial (07-23-2013), switchlanez (07-17-2013), Turdinator (07-17-2013)
Old 07-17-2013, 02:37 PM   #81
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Man and i just pulled the trigger on some Eibach R1's... I was going to get the Pro kits but i said to myself that if im going to void the suspension warranty might as well go all out.. haha now TRDs are gonna be on the market...
Lakers86 is offline   Reply With Quote
Old 07-17-2013, 03:10 PM   #82
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
nice price. thanks!
Old 07-17-2013, 03:49 PM   #83
knaa
Drives: FRS
Originally Posted by tennisfreak View Post
Ok I could not resist and had to pull the trigger. I want to lower the car and dont want to spend the money on coil-overs. This seems like an affordable way to lower the car and possibly avoid warranty issues (if I have my local dealer install).
I payed $257 via paypal and everything seemed to go smoothly. Once you create an account you can log back in and view your order status and invoice. Mine currently says pending.
Will keep everyone posted.
link? it wasnt in the OP
knaa is offline   Reply With Quote
Old 07-17-2013, 03:59 PM   #84
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
now with these springs installed and also if you have aftermarket wheels would you be voiding the warranty since you have aftermarket wheels? i mean i guess if anything happened i could always swap out and put on my winter wheels that have winter tires with stock wheels ... anyone know if this price of 210 is legit ? i wonder what the installation cost would be
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-24-2013 12:42 AM
Stock springs and sway bars Spencer Brakes, Suspension, Chassis 3 04-25-2013 10:41 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 03:32 PM
