Old 06-12-2013, 07:48 PM   #1
Hotchkis
Hotchkis's Avatar
DIY - Sway Bar (Stabilizer Bar) Installation
Hey everyone! I haven't seen a DIY for installing sway bars yet, so I figured we can help out in case you guys needed any info on this subject. This install depicts the installation of our Hotchkis sway bars, but the the same concept applies to any sway bar you install. Hopefully this can be a good reference for anyone interested in replacing their sway bars.
Good Luck!
-Aaron
On to the install...
Front Stabilizer Bar Install
1F. Raise the front end of the vehicle either by using a lift or using a floor jack. Use jack stands to secure the vehicle if you are using a floor jack. Drive-on floor ramps may also be used. This installation will depict using an alignment rack. It is not required to droop the suspension for the front bar installation.
2F. Remove the two engine under covers. The silver aluminum cover is held in by 8 bolts and 7 push clips. The black cover is held in by 11 bolts. (10mm, 12mm Socket, slotted screwdriver)
3F. Unbolt the end links from the OE stabilizer bar. (17mm wrench, 6mm allen)
4F. Undo the single push clip on each side. It is located just below the stabilizer bar bushings. (Pick or slotted screwdriver)
5F. Unbolt the 2 frame mount brackets. There are 4 bolts per bracket. (14mm socket)
6F. Remove the stabilizer bar assembly from the vehicle.
7F. Unbolt the bushing brackets on each side. Retain the bolts for reinstallation, but you may discard the OE bracket, bushing and nut when installing the Hotchkis bar. (14mm socket, 12mm wrench)
8F. Grab your new front stabilizer bar and install the included polyurethane bushing and bracket as shown. Be sure to apply the included silicon grease to the inner surfaces of the bushings before installing onto the bar.
9F. Install the stabilizer bar and brackets onto the frame mount brackets. Reuse the OE bolt for the front and use the Hotchkis flange bolt/washer/nut for the rear. IMPORTANT: TIGHTEN THE REAR BOLT & NUT BEFORE YOU TIGHTEN THE FRONT BOLT. This will allow the bracket to position properly when tightening. (Front bolt: 55 ft-lb. Rear bolt and nut: 25 ft-lb)
[IMG]http://farm4.staticflickr.com/3750/9029694074_977a1***06_o.jpg[/IMG]
10F. Reinstall the stabilizer bar assembly in the same manner as removal.
11F. Repeat steps 1F-5F in reverse order. See below for proper torque specs.
Hotchkis is offline   Reply With Quote
The Following 12 Users Say Thank You to Hotchkis For This Useful Post:
b rawr z (10-25-2016), BE4VER (05-26-2014), C4RBON (09-23-2017), Choco (01-21-2015), DocWalt (10-09-2015), EN2_Squirrel (07-03-2013), finch1750 (02-13-2017), JohnJuan (04-28-2016), Prmspen (07-18-2016), qoncept (07-16-2013), slim blanco (07-22-2015), swarb (02-15-2015)
Old 06-12-2013, 07:49 PM   #2
Hotchkis
Hotchkis's Avatar
Rear Stabilizer Bar Install
1R. Raise the rear end of the vehicle either by using a lift or using a floor jack. Use jack stands to secure the vehicle if you are using a floor jack. Drive-on floor ramps may also be used. This installation will depict using an alignment rack. It is not required to droop the suspension for the rear bar installation.
2R. Remove the OE end links from the vehicle. (14mm socket/wrench, 5mm allen)
Use a 14mm wrench and 5mm allen to detach the end link from the sway bar
Use a 14mm socket wrench to detach the end link from the control arm
3R. Unbolt the bushing brackets and remove the bar from the vehicle. (12mm socket)
4R. Grab your new rear stabilizer bar and install the included polyurethane bushing. Be sure to apply the included silicon grease to the inner surfaces of the bushings before installing onto the bar.
5R. Position the rear bar onto the vehicle. Insert the bridge plates between the frame mount and the polyurethane bushing. Then install the bushing bracket onto the bushing. Reuse the OE bolts to secure the bushing brackets. Bushing Bracket Bolts: 22 ft-lbs
6R. At this point, the rear bar can shift side-to-side. Shift the bar side to side until it is perfectly centered with the car. You should have equal distance between the stabilizer bar lever arms and the frame mounting point. Install the aluminum collars on the inboard side of each bushing. Butt the collar all the way to the bushing, no gap. This will keep the bar centered during operation.
7R. Assemble the end links as shown in the diagram.
When choosing the lever hole on the stabilizer bar, it is important to mount the end link correctly in the lower control arm. See diagram for all configurations.
8R. Once you've chosen your configuration, tighten the end link to lower control arm mount point to 28 ft-lbs. Tighten the end link to stabilizer bar point to 50 ft-lbs.
9R. Make sure all hardware is tight and lower the rear end of the vehicle.
The Following 7 Users Say Thank You to Hotchkis For This Useful Post:
Baldoak (10-04-2017), C4RBON (09-23-2017), Choco (01-21-2015), EN2_Squirrel (07-03-2013), mla163 (06-30-2013), slava (10-08-2014), slim blanco (07-22-2015)
Old 06-12-2013, 07:50 PM   #3
Hotchkis
Hotchkis's Avatar
Reserved....
Old 06-30-2013, 12:39 PM   #4
mla163
Overthinking it
Drives: BRZ in CS
How many hours for front/ rear?
mla163 is offline   Reply With Quote
Old 07-03-2013, 01:38 PM   #5
Hotchkis
Hotchkis's Avatar
Hi mla163,
Front should be about 1-1/2 hrs and the rear is 3/4 hr when doing it on the floor with jack stands/floor ramps.
I've done this install so many times though, I've gotten it down to under an hour for the whole car when using a lift. Compared to other car makes we deal with, this is one of the easiest sway bar installs.
Good Luck!
-Aaron
Old 07-03-2013, 02:13 PM   #6
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Great Write up! Very glad to see those front brackets drop so you aren't snaking in and out the front bar. What is your recommendation for the rear bar adjustment for a neutral handling setup?
FastLane1000 is offline   Reply With Quote
The Following User Says Thank You to FastLane1000 For This Useful Post:
Hotchkis (07-03-2013)
Old 07-03-2013, 03:16 PM   #7
swift996
swift996's Avatar
Thanks for sharing, wish I had this before my install
Very happy with the product, game changing upgrade.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 2 Users Say Thank You to swift996 For This Useful Post:
Hotchkis (07-03-2013), Strife26 (03-19-2019)
Old 07-03-2013, 05:55 PM   #8
Hotchkis
Hotchkis's Avatar
Hi FastLane1000,
Yes, Subaru did us a favor by making those front sway bar bushing mounts modular. Dropping subframes are never fun.
With OE springs and tires, you can achieve neutral handling with the front on stiff and the rear on medium soft hole setting (2nd hole from the end). With some better tires you can have plenty of stability even on the medium stiff hole setting (3rd hole from the end). If you have Hotchkis springs, these settings apply as well. When introducing higher/varying spring rates, more aggressive alignment settings and shock damping adjustability, you will have to adjust the sway bars accordingly to suit your needs.
Cheers!
Old 07-16-2013, 04:39 PM   #9
FastLane1000
Mine just arrived today. No collars needed on the front bar to prevent the side to side movement?
Edit: never mind collars are built in on front bar
Last edited by FastLane1000; 07-17-2013 at 04:59 PM. Reason: answered my own question
Old 07-16-2013, 05:04 PM   #10
qoncept
qoncept's Avatar
Huh. I did mine without unbolting from the subframe. It was a PITA of course.
qoncept is offline   Reply With Quote
Old 07-16-2013, 05:59 PM   #11
nickmaster
me
i have clunking issue using the stiffest settings for the front swaybar with stock endlink. (adjustable endlink possibly will fixed this though)
nickmaster is offline   Reply With Quote
Old 07-16-2013, 06:21 PM   #12
qoncept
qoncept's Avatar
I can't speak for any other bars but my Whiteline and a buddy's Hotchkis bar both clunk. Something needs to be done with the endlinks, either replacing or cutting and shortening stock.
Old 07-16-2013, 08:33 PM   #13
FastLane1000
You mentioned fixing this by adding washers in another post. Was this not a permanent fix?
@Hotchkis have any input?
Old 07-16-2013, 08:37 PM   #14
tonytduc
tonytduc's Avatar
Thanks!
tonytduc is offline   Reply With Quote
The Following User Says Thank You to tonytduc For This Useful Post:
Hotchkis (07-17-2013)
TRD Door Stabilizer Kit AL008 Australia Classifieds 3 03-17-2013 09:53 PM
FS; TRD DOOR STABILIZER photomike Brakes, Suspension, Chassis 1 03-07-2013 05:05 AM
EOI - TRD Door Stabilizer kit AL008 AUSTRALIA 2 02-28-2013 03:21 AM
TRD Door Stabilizer scioneric Canada Classifieds 15 01-22-2013 09:49 PM
Rear Sway Bar Stabilizer Bracket Bolt replacement? Books Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-19-2012 04:55 PM
